Now closed! 10" JBL sub & box from tech12volts group buy.
Discussion in 'Deals & Group Buys' started by Pudge, Jan 4, 2019.
Thread Status:
Not open for further replies.
  1. Feb 5, 2019 at 7:50 AM
    #481
    Puba
    Puba Not New Anymore
    Blue Bell, PA
    MGM 2019 Crewmax LTD OffRoad
    RCI skid plates Curtis front hitch TracRac Ladder racks Truxedo Tonneau Cover BedRug bed liner Console Vault Tech 12volts complete audio system upgrade Bilstein 6112/5100 Coachbuilder Shackles Fuel Vector 18x9 Falkan Wildpeak 295/70/18 DirtyDeeds 8" Standard Husky XAct floor liners Color matched Bumper Shellz fronts Pop and Lock Tailgate SDHQ Hidden Winch Mount Smittybilt X20 Comp 12K RCI Rock Sliders Harrop SC - Stage 1
    Same here. Carpet wrapped up and over, stapled to to the back, bare wood exposed on rear. Still better than bed liner paint.
    Jagamov likes this.
  2. Feb 5, 2019 at 7:51 AM
    #482
    nakota
    nakota New Member
    Phoenix
    Yes. Mine was the same way re: screws just spinning. I emailed James and he said that it was fine. No carpet on the back of box either, not sure if that’s correct or not though.
    Jagamov[QUOTED] likes this.
  3. Feb 5, 2019 at 8:02 AM
    #483
    Jagamov
    Jagamov New Member
    Greg
    2017 White Tundra Platinum
    Thanks for the confirmation...for a minute I thought I got the "last one" and they ran out of carpet....LOL....
  4. Feb 5, 2019 at 9:55 AM
    #484
    Puba
    Blue Bell, PA
    They did. Had to order from Canada once he got to 70-80 orders from what I remember early on in this thread. Who knows. The resin coating, upper left port, internal cubic space inside is the key for best sound, carpet only for aesthetics. I'll never look behind my seat again so unless I tell my wife and our dog, no one is the wiser.
    BlueBottle likes this.
  5. Feb 5, 2019 at 10:17 AM
    #485
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    Makes sense. I "mounted" mine closer to the C pillar than in the center of the seat. I will try this. Thanks.
  6. Feb 5, 2019 at 1:23 PM
    #486
    james@tech12volts
    james@tech12volts tech12volts.com INNOVATIONS IN AUDIO ! Vendor
    james
    The carpet is not long enough to carper the back all the way around. No one sees it so we do not ever completely carpet the back.
    If you had one of the ones that was damaged by ups and have not shipped the sub back to me yet please Email ASAP. It will save you time and me money
  7. Feb 5, 2019 at 4:04 PM
    #487
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    no need for that... mine is within a stitch of flush. make sure your sub favors the drivers side but not so far that the seat wont fold back down.
    the trick is to insert the inboard aft bolt first (the one with the coarse thread) and run it down by hand as far as you can. then push on the seatback corner on the same side as the bolt. (or use an assistant to maintain pressure there and continue to run that bolt down, but dont torque it just yet. Now install the opposite back bolt but dont torque it just run it down by hand.
    then run in both forward bolts down by hand. now have your assistant push one last time on the seat back and torque both aft bolts and then torque both forward bolts.
    note make sure your seat can fold down before torquing as you may have to shift the sub inboard a bit.
    KnuckleHD and Jagamov like this.
  8. Feb 5, 2019 at 5:02 PM
    #488
    ZPMAN
    Minnesota
    J
    James if this will make you a little bettor, the UPS driver overshot the turn on my road and is in the bushes. KARMA
  9. Feb 5, 2019 at 5:09 PM
    #489
    james@tech12volts
    james
    Wow best post I have seen all day as long as he is ok. Do not wish anyone to get hurt.
    Pudge[OP] likes this.
  10. Feb 5, 2019 at 5:12 PM
    #490
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    I just sent mine back tonight. new one works like a champ. Thanks for the great support JRT. I used the label that was inside. I can send you the tracking number if needed.
  11. Feb 5, 2019 at 5:21 PM
    #491
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Waiting this weekend to install...Hopefully the sub made it through UPS unscathed. Can't wait!!
  12. Feb 5, 2019 at 5:45 PM
    #492
    trddriver
    trddriver New Member
    '14 1794
    open to discussion
    Got mine today.. Nothing visibly wrong, removed speaker packing. Install this weekend!
  13. Feb 5, 2019 at 5:53 PM
    #493
    ZPMAN
    Minnesota
    He's ok, might have been snow blinded because it's snowing heavy.
  14. Feb 5, 2019 at 6:20 PM
    #494
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
    I wonder if I could throw a JL Audio 10TW3 in here and replace the JBL Sub.
    tbrown likes this.
  15. Feb 5, 2019 at 6:25 PM
    #495
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    You would want an amp for sure and maybe a new box lol. James designed this box, for this sub, to be driven off the OEM JBL amp. So basically this I'd a custom designed set up for us OEM JBL guys. If a different sub would work better, I bet he would have used that sub instead of the JBL sub he chose.
  16. Feb 5, 2019 at 7:02 PM
    #496
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
    The specs aren't far off...I'm not sure of the cubic space needed with the box for either sub, looking for that info, but the wattage is similar and I wouldn't do the JL unless I was adding an additional amp with a DSR1, that's why I was wondering if I could swap, if I got more power in the future. I also think the reason James wouldn't run the JL oppossed to the JBL is that the JL is 3x the cost. $119 vs $319...
    Pudge[QUOTED][OP] likes this.
  17. Feb 5, 2019 at 7:15 PM
    #497
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    2017 TRD Blazing Blue
    Magnuson Supercharger Kooks long tube headers King 3.0 remote reservoir w/ clockers front King 3.0 triple bypass remote reservoir rear Deaver Custom leaf Method 312 Corsa Exhaust w/ custom stainless bro’s resonator tip Custom HP tune Viair 400c Dual Onboard Headlight Revolution Stealth Bar Baja design XL 80 ditch lights on SDHQ Ditch brackets Victory 4x4 sliders and bed Molle RCI Skids C4 fabrication overland front bumper Smittybilt x2o 12k winch Toyo Open Country RT 37’s Icon Billet Delta UCA’s Nitro 5.29’s ARB Air locker front and rear Switch Pros Leitner Designs Bed Rack ICS Fab Dash Mount Expedition One Dual Swing Rear Bumper Viper remote start Rosen in headrest DVD players
    http://www.jlaudio.com/10tw3-d4-car-audio-tw3-subwoofer-drivers-92184
    May or may not have been creeping that idea, or a kicker rt...
    Major[QUOTED] and Pudge[OP] like this.
  18. Feb 5, 2019 at 7:38 PM
    #498
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
    Exact same. I've always ran JL so I leaned towards that but the Alpine Type R and the Kicker got great reviews and the Kicker can be had for WAY cheaper..Once I decide my 5 Channel, decisions, decisions...
    tbrown[QUOTED] likes this.
  19. Feb 5, 2019 at 7:49 PM
    #499
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    Price on kicker has me leaning that way. I’m sure it will be plenty bass for me while I wait in the day care pickup line. Of course I ordered a single channel amp before the hertz group buy, so now I have a four channel waiting to be hooked up too lol
    ardnutoz and Major[QUOTED] like this.
  20. Feb 6, 2019 at 6:42 AM
    #500
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    Haha I find that the JRT sub thumps plenty of bass for the daycare pickup line.
  21. Feb 6, 2019 at 6:47 AM
    #501
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    I know, I should totally leave it alone. Mine was a damaged one so I’m just looking for instant gratification. James was awesome when I reached out. New one should be on the way in now time.
    BlueBottle and ardnutoz[QUOTED] like this.
  22. Feb 6, 2019 at 7:06 AM
    #502
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    I hear ya.. mine was a damaged one too. he shipped instantly friday and I received a new one Monday and installed yesterday. very painless process and well worth it. impressive what a quality sub will do vs the Mickey mouse one that the truck came with.
  23. Feb 6, 2019 at 10:16 AM
    #503
    Cthulhu
    I would imagine it might work, not too sure with the factory JBL amp. I can tell you this, if it does work at 4 ohms, the ouput would be considerably LESS.
  24. Feb 6, 2019 at 11:22 AM
    #504
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
    Repurposed my factory sub LOL, got to install the upgrade before the ice storm hit and so far loving it for the few seconds I listened....
    D3Tundra, Cfincke, tbrown and 4 others like this.
  25. Feb 6, 2019 at 7:04 PM
    #505
    West Texas Tundra
    West Texas Tundra 2016 Bronze Beast
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    20 inch CECO wheels Drop in K&N air filter 2 inch front leveling kit
    I’d be interested in the group buy on the remote start!!
  26. Feb 7, 2019 at 4:38 AM
    #506
    Freezy
    Freezy New Member
    I'd be in for that
    D3Tundra likes this.
  27. Feb 7, 2019 at 8:38 PM
    #507
    stephenreyes
    stephenreyes New Member
    Pensacola, FL
    2019 Platinum 4WD
    TRD sway bars front and back, color matched handles and mirrors, Leer topper, TSS Wheels
    Got my sub installed today. It literally took 35 min to install. Simply moved the driver seat all the way forward, removed the 4 bolts holding the drivers side back seat. Then removed the old sub (4 bolts) cut the wires that went to the plug on the sub side (did not want to alter the truck plug), striped the wires a bit and plugged them into the new sub. Reinstalled the seat and all was done.
    It did make a big improvement in the sound. It is not some ridiculous boom or anything, just a much better bass sound. Very happy with the purchase.
    Jagamov and Pudge[OP] like this.
  28. Feb 9, 2019 at 2:48 PM
    #508
    Jagamov
    Jagamov New Member
    Greg
    Just got mine in.
    Two words: Holy Sheeet. What a huge difference. The stock sub was barely audible, this one is at least twice to 3 times more bass. This is on XM and Bluetooth. I actually had to back the bass down 1 notch from center for a balanced sound.
    Best mod ever for the price.
    I did the same as the others 4 bolts out, leaned seat forward, removed old sub, removed wire from sub, installed new sub and put seat back down and bolt it back in starting with the inside rear bolt, then the outside rear bolt. Seat is perfectly aligned.
    Thanks everyone for the pics and tips. Thanks again @Pudge for doing this.
    T-Rex266 and Pudge[OP] like this.
  29. Feb 9, 2019 at 2:54 PM
    #509
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    Nice man. Any pictures of the sub ?
  30. Feb 9, 2019 at 3:16 PM
    #510
    Jagamov
    Jagamov New Member
    Greg
    Post #479 has a good pic of it in the truck. I didn’t take any pictures since it looks identical.
Thread Status:
