Nothing here, move along
Discussion in 'Towing & Hauling' started by Quartermeter, Jul 5, 2017.
  1. Jul 5, 2017 at 5:23 AM
    Quartermeter
    Quartermeter [OP] New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    H. A. N. D.
  2. Jul 5, 2017 at 6:01 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Is your trailer weighing in at 14k lbs or is that just the capacity of the trailer? 14k is over our towing capacity.
    Did you try stepping on the gas?
    Even when not towing, coasting downhill the truck will engine brake a bit. Nothing in the red though. Just pressing the gas a little makes it go away, same with the brake I believe.
    CM-LENNY and Backslider like this.
  3. Jul 5, 2017 at 8:03 AM
    15whtrd
    15whtrd Mr. Blonde
    Only 2500. Doesn't sound like it's over revving. It's doing it's job. If you say it didn't used to do it, it probably learned and adapted. Now if it was holding it at 5000 I'd be concerned.
    CM-LENNY and Wynnded like this.
  4. Jul 5, 2017 at 8:17 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    This sounds normal to me. BUUUT, in this situation, if you touch the brake it will almost certainly shift down a gear to increase the engine braking effect. I've experienced this up to 4k RPMs on steep (10%) grades. The truck won't over-rev, the ECU will shift to the next higher gear to protect the engine from damage, even in S-Mode.
    CM-LENNY and 15whtrd like this.
  5. Jul 5, 2017 at 10:42 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Sounds normal to me. Leave it in D, press the tow/haul button and let it do it's thing. It'll use the engine to brake a lot more in that mode to save your brakes and it will also hold lower gears so you're not chugging the engine.
    CM-LENNY, Black Wolf and Y0TA PR0 like this.
  6. Jul 5, 2017 at 10:50 AM
    15whtrd
    15whtrd Mr. Blonde
    Do you think it's wrong to use S mode with towhaul when towing? I use it to lock the truck out of 5th or 6th when towing unless it warrants a higher gear.
  7. Jul 5, 2017 at 12:58 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    I remember @ColoradoTJ telling me to leave it in D. He's never steered me wrong.
    15whtrd, MotoTundra and ColoradoTJ like this.
  8. Jul 5, 2017 at 3:14 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that the manual says that putting it in S-Mode defeats (cancels/turns off) Tow/Haul.
  9. Jul 5, 2017 at 3:27 PM
    15whtrd
    15whtrd Mr. Blonde
    It seems like everything still works. Tow haul in the third generations makes it act more like the second generation other than the shift points. The throttle response is better shift points extended etc. the only thing I don't know is, whether or not it does engine braking for you IE hold the gear or downshift when you touch the brake. I don't like having my truck in DC while towing. Maybe it's just a habit that came with the older vehicles, that you always just put in D or 3 instead of overdrive.
  10. Jul 5, 2017 at 7:38 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    I think you are fine using the S mode while in tow haul. The last time we did a mountain camping trip, the drive home was curvy and steep coming down. I used the shifter as some engine braking and it worked well. Our trailer is around 7500-8K fully loaded and I take it easy both up and down the grades. No reason to burn the brakes or trans up. Once I start the trip, my tow/haul mode stays on til we reach our destination.
    15whtrd[QUOTED] and ColoradoTJ like this.
  11. Jul 5, 2017 at 8:06 PM
    15whtrd
    15whtrd Mr. Blonde
    So do you put it back in D out on the highway? Reason I'm asking is I take the 62 out to Parker towing my friends boat and it's got a lot of up and down rolling hills. I didn't like the transmission shifting so often only to downshift again. So I would typically find the gear that would keep me in the RPMs I wanted and then upshift on the down hills and flats. I almost never use D and always use S mode, even unloaded every day driving. I came from alot of manual transmissions so i hate gear hunting.
  12. Jul 5, 2017 at 9:19 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Cleaned and back on topic.
  13. Jul 5, 2017 at 9:20 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    What you're doing here sounds reasonable to me, as I understand it.
    15whtrd[QUOTED] likes this.
  14. Jul 5, 2017 at 9:27 PM
    MotoTundra
    MotoTundra The Ocho
    Don
  15. Jul 5, 2017 at 9:31 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    MotoTundra, 15whtrd and Y0TA PR0 like this.
