Not sure what the problem is
Discussion in 'General Tundra Discussion' started by kayamor, Feb 23, 2020.
  1. Feb 23, 2020 at 4:28 PM
    kayamor
    kayamor [OP] New Member
    Rhonda
    2011 Toyota Tundra 5.7
    I have a 2011 Tundra about a month ago I drove my truck to the school and back home were it was parked for the day. Late that same afternoon came back my truck would not start. Hooked it up to the scanner and nothing it was not communicating to the ECU no check engine light on but would not start. Worked on it for a day and it has been sitting for almost a month. Went out yesterday to try my luck and it started with the check engine light on. My truck is normally loud but I could barely hear it running when I tapped the gas it sounded like a burst of air came out before it would rev up after about 1 hour it died again ANY IDEAS? I have read a lot about possible secondary air pump but only code it showed yesterday was a break light switch and the trac control light was on. Help please if you have any ideas need my truck for work
  2. Feb 23, 2020 at 4:34 PM
    Welcome from NY.
    Hopefully someone will chime in with the answer.
  3. Feb 23, 2020 at 4:36 PM
    kayamor
    Rhonda
    Thank you
  4. Feb 23, 2020 at 4:46 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    What have you work on, what things you checked
  5. Feb 23, 2020 at 6:11 PM
    kayamor
    Rhonda
    So far plugs coils crankshaft and camshaft position sensors and relays
  6. Feb 23, 2020 at 6:23 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    If the Check Engine Light is on, there will be codes set. You'll need to get and share those otherwise there is no starting point and everyone would simply be making random guesses.
  7. Feb 23, 2020 at 6:24 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    got gas?? air filter clean?? mass air flow working did you disconnect any vacuum hose?? got sparks on all plugs??
  8. Feb 23, 2020 at 6:26 PM
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    Where is the mass air flow sensor located on the truck ? Is it at the air box top of the air cleaner top housing ? If so check cold air piping from box to intake minifold , make sure it isn’t cracked or broken . Also what is the fuel pressure ?
  9. Feb 23, 2020 at 6:27 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    Also is that the timing belt engine ? Did the belt jump ?
  10. Feb 23, 2020 at 6:31 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    2011 should be timing chain
  11. Feb 23, 2020 at 6:44 PM
    kayamor
    Rhonda
    Gas yes clean air filter mass air flow sensor good only code is brake light sensor. No vacuum leaks could it possibly be the secondary air pump??? If I cannot fix it I am going to take it to a Machanic shop just thought someone could have possibly been through this and would have a definitive answer
  12. Feb 23, 2020 at 6:54 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    If it were the secondary air pump, it would still start and run. You'd have way more lights lit on your dash though, and more codes.
  13. Feb 23, 2020 at 6:57 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    you try both keys??
  14. Feb 23, 2020 at 7:02 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Shot it the dark here, and I don't remember if this is something I've actually read on here or making up in my mind, but don't brake light issues throw the truck into limp mode? Can you troubleshoot the brake light sensor error and see what happens?
