Not sure how 4WD works? Check this thread on how to understand Toyota 4WD systems.
Discussion in 'Recovery & Gear' started by T-Rex266, Dec 17, 2016.
  1. Dec 17, 2016 at 11:13 AM
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Not sure how it works? Toyota 4WD systems explained
    Watch this video to find out more!
    4WD Operation and how it works
    How about an interactive one I can use, Sean? Come on, aren't you a mod that can find this for us?
    Here you go! (Need to be on computer for this)
    What types of Toyota 4WD systems are there?
    Find your answer here.
    Toyota Tundra 4WD General Information (2000-present)
    Toyota Part-Time 4WD explanation
    Toyota Tundra differentials. What do we have?
    Click here to find out!
    Should I turn off VSC and traction control in the snow or mud?
    Click here to read more.
    How do I operate my 4WD?
    2nd Gen: (2007-2013)
    Tundra How-To: 4WD Shifting Procedure
    3rd Gen: (2014+)
  2. Dec 17, 2016 at 3:15 PM
    For the record:
    Traction off + 4HI feels much safer on cornering and uphill starts. Traction doesn't freak out on you cutting your engine power down.
  3. Dec 17, 2016 at 3:17 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    @Sean266 You sir, are one of the best around!
    T-Rex266[OP] likes this.
  4. Dec 17, 2016 at 3:38 PM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
  5. Dec 17, 2016 at 3:40 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    This needs to be a sticky.
    T-Rex266[OP] and Krezz like this.
  6. Dec 17, 2016 at 3:57 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @Sean266 , you are handier than Velcro
  7. Dec 17, 2016 at 6:09 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I need to check these links out, thanks for the info Sean!
  8. Dec 17, 2016 at 6:14 PM
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    Also, 2WD and Auto LSD will take care of most everyday drives including these snow days.
  9. Dec 17, 2016 at 6:17 PM
    Morgan51
    Morgan51 New Member
    2016 Inferno CM Tundra TRD
    Good info, thanks for the post
  10. Dec 17, 2016 at 6:27 PM
    Great info Sean!!!
    T-Rex266[QUOTED][OP] likes this.
  11. Dec 17, 2016 at 6:29 PM
    Thanks
  12. Dec 17, 2016 at 6:44 PM
    scurdyness
    scurdyness One thing is sure, uncertainty is certain
    William
    Fort Smith, AR
    2017 MBM Platinum_BlackOps
    TRD CAI, TRD Dual Exhaust, TRD rear sway bar, TRD shift knob, T-Rex Sport grilles upper and lower, full window tint and brow, de-chromed, powder coat OEM wheels, blue LED interior, Winjet Tails, Retrofit headlights
    Sean, I actually READ the manual!!!...first time ever I have read a 'destruction manual', but hey, thanks for this!, great post
    Sunnier and T-Rex266[OP] like this.
  13. Oct 11, 2017 at 10:40 AM
    Bump for pre-winter season.
    htw_hawaii and Krezz like this.
  14. Oct 11, 2017 at 12:14 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    Thanks for the info
  15. Oct 11, 2017 at 12:51 PM
    Krezz
    Kevin
    Good bump. I always heard you were a sensitive lover.
    Sunnier and htw_hawaii like this.
  16. Oct 11, 2017 at 1:17 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    What’s winter?
    08sequoia and Krezz like this.
  17. Oct 13, 2017 at 9:08 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Not sure how i missed this bump a couple days ago...but this would have been a good refresher about 10hrs ago. Went up to Mt Hood and shifted to 4hi and got the flashing light..never seen that before. Well it was the answer to why 4wd wasn't working.
  18. Oct 10, 2018 at 2:52 PM
    matttowns509
    matttowns509 New Member
    Minneapolis, Minnesota
    2020 Army Green Toyota Tundra TRD PRO
    So here is one of my n00b questions. In 4HI what's an acceptable speed to travel? I know to turn the dial under 62MPH and in cold weather (I think it was 5°F they said) under 55MPH (from the University of YouTube). Also I see the manual says I should drive in it for 10 miles every month to keep things lubricated. Thanks in advance for replies!
  19. Oct 10, 2018 at 2:53 PM
    Safe as possible. if I’m in 4WD, I’m probably going no faster than 50’ish
    equin and matttowns509 like this.
  20. Oct 10, 2018 at 3:53 PM
    matttowns509
    OK. I should qualify. I'm the right lane guy who sets the cruise control for the speed limit and listens to A.M. radio. I just never knew what if there was a limit or what have you. As luck would have it we're looking at snow for the first time tonight. Though, it shouldn't stick around.
  21. Oct 19, 2018 at 10:09 PM
    Mithrandir
    Mithrandir New Member
    mike
    2018 4x4 Tundra Color of Victorville Dirt
    To the OP.... thanks for putting this together!!
    T-Rex266[OP] and matttowns509 like this.
  22. Jul 16, 2019 at 11:31 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    so what would be top speed in 4L ??????
  23. Jul 16, 2019 at 11:43 AM
    15whtrd
    15whtrd Mr. Blonde
    It won’t go past fourth gear in 4L So redline in fourth gear LOL probably only 20 to 30 miles an hour. If you’re gone that fast you should be in 4H. I probably go no faster than 20 in 4L
  24. Jul 16, 2019 at 12:04 PM
    Sonicbluerider
    Dennis
    2019 Tundra
    hay thanks, I've looked everywhere for a answer!! that's faster than I imagined!!
    T-Rex266[OP] and 15whtrd like this.
  25. Jul 31, 2019 at 9:51 PM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Heavy, unnecessary offroad stuff.
    You’re dealing with one of the best. Sean is a top notch guy.
  26. Oct 9, 2019 at 6:35 PM
    Bump for the snow approach.
    15whtrd, MAGDADDY and Pinay like this.
  27. Oct 9, 2019 at 6:56 PM
    As a reminder for white Tundras. We become the snow, and the snow becomes us. Together, we become one.
  28. Mar 3, 2020 at 4:51 PM
    Landrover
    Landrover New Member
    2019 Black Tundra TRD Sport
    Tires, leather Seats, Retrax Bed Cover, TRD Wheel Caps, Floor Mats, Leather Steering Wheel cover, interior accessory kit, Tailgate highlighter, bumper step,
    very good video!!
  29. Jan 24, 2024 at 1:46 PM
    CMTX 1794
    CMTX 1794 New Member
    Sheb
    2018 Silver 1794 edition 4x4
    Soon
    Excellent info.
    Still curious (because I didn’t find it specifically)
    on an ‘18 Tundra, pressing the trac button ONCE while in 2wd, dash displays “auto lsd”
    sorry for the likely silly question, but what the heck does auto limited slip differential do? Just “lock” the rear tires (like posi trac)?
    appreciate all the knowledge shared here. Y’all are freaking awesome.
  30. May 5, 2024 at 8:58 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    4L means 4Slow
