Not starting issue
Discussion in '2nd Gen Tundras (2007-2013)' started by Wakeem, Oct 31, 2019.
  1. Oct 31, 2019 at 6:27 AM
    Wakeem
    Wakeem [OP] New Member
    I have a 2008 Tundra that had a recent frame replacement. Since the swap the truck has had moments where the starter will not crank, I am not sure if it just a coincidence or just truck age. The truck has 280k on it, when it runs it is strong. My mechanic said the battery needed to be replaced, we swapped it but the starter is still intermitantly not working. The starter does not crank always when the key is turned. When the starter cranks, it cranks as it should with no struggle. The truck can sit for either a minutes or days and either work or not. Does anybody have a direction to start looking? My regular mechanic said a ground wire is loose somewhere from the frame swap.
  2. Oct 31, 2019 at 6:33 AM
    15whtrd
    15whtrd Mr. Blonde
    Start by tracing out the grounds. Maybe even remove and scuff the paint where any body grounds may be. I like to install a little grease so it doesn’t rust. It may be time to replace the wires as well.
    JohnLakeman likes this.
  3. Oct 31, 2019 at 6:45 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    did The starter click, if the starter click then it’s starter, if it doesn’t even click then it’s ground.
    Don’t really have to chase for ground wire, just add a few 0 gauge wire to the frame
  4. Oct 31, 2019 at 7:01 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I began thinking it's probably a bad ground from frame replacement before I even got to your last sentence. :D
    They probably left a ground loose, or the fresh paint on the frame is preventing good ground contact. Insuring a good ground contact area is probably out of mind when replacing a frame...until it bites the owner in the butt. It will be highly coincidental if it isn't a bad ground.
  5. Oct 31, 2019 at 9:17 AM
    Mr. Seven
    Mr. Seven New Member
    Rolla, MO
    07 DC 4x4 4.7
    Eibach Lift Level 8 MK6 18x9 ET12 295/70R18's 4.88's Auburn JBA exhaust
    I'd recommend using Ox-gard (available in electrical section at Lowes/ HD) on your ground connections after a good paint removal/ scuff as others have suggested...its the goodness. Coat threads of grnd screw/underside off connection & top of conn....Ox-gard is conductive.
  6. Oct 31, 2019 at 9:38 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    I would also try a different key as well as ground continuity.
