North West BS Thread
Discussion in 'North West U.S.' started by JAMMDOGG, Jan 6, 2014.
  1. Mar 12, 2022 at 4:26 PM
    #7561
    Blue Thunder
    Washington
    Beautiful. Too bad they will be hidden away and covered in grime soon
    gosolo and NWPirate like this.
  2. Mar 12, 2022 at 5:09 PM
    #7562
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    lol exactly
  3. Mar 13, 2022 at 8:27 AM
    #7563
    Blue Thunder
    Washington
    Yanked my cab steps yesterday as the finish was starting to fail. Truck looks like it has had liposuction. 7AF32B10-5034-4B8D-9BD9-4F98B4A02166.jpg
    gosolo, NWPirate and 20GR8 Super like this.
  4. Mar 13, 2022 at 8:42 AM
    #7564
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    Truck looks great! How you liking those KO2’s? I know they weren’t your first option.
    Edit: also are you leaving the steps off or getting new?
    gosolo and Blue Thunder[QUOTED] like this.
  5. Mar 13, 2022 at 8:48 AM
    #7565
    Blue Thunder
    Washington
    Thanks, I do like the cleaner look. Think I’ll be installing sliders next time around. Need the wife to dislike the current config before that purchase is authorized.
    So far the tires are great. I’m still messing with pressures but think I have that squared away now. I’m sensitive to the balance on these things and I have to tell myself the bumps I feel going down the road are the stiffer tires.
  6. Mar 13, 2022 at 9:01 AM
    #7566
    20GR8 Super
    Corey
    PNW Outskirts
    Let me know how that logic works out! I have stock steps and want sliders too. I thought I wanted the amp steps and bought a used set on Craigslist, but think I have changed my mind. Going to be even harder to convince the Mrs. now since I bought something I’m not going to use.
    What are you running for pressures? Low 30’s?
    gosolo likes this.
  7. Mar 13, 2022 at 9:25 AM
    #7567
    Blue Thunder
    Washington
    Running 40psi for normal driving. Have to bump it up to 50 for towing. The summer months will be jittery.
    gosolo and 20GR8 Super[QUOTED] like this.
  8. Mar 13, 2022 at 9:32 AM
    #7568
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Always gotta be thinking of the right angle for getting that authorization...
    :fistbump:
  9. Mar 13, 2022 at 9:34 AM
    #7569
    RainMan_PNW
    Casey
    Clark County, WA
    After a fair amount of dinking around, I found 38psi at about 50 degrees is where I'm happiest with the Falkens. Not too stiff, not to soft, good tread wear, and once I'm on the road they warm up to around 40.
  10. Mar 13, 2022 at 9:43 AM
    #7570
    20GR8 Super
    Corey
    PNW Outskirts
    I’m running 35psi in the front and 32 in the back since I spend 95%of the time with an empty bed. Seem to be getting good tread wear and not super rough. Having 35’s on 17’s helps though. If I tow I just pump up the airbags instead of the tires.
    gosolo and Blue Thunder like this.
  11. Mar 13, 2022 at 10:54 AM
    #7571
    Blue Thunder
    Washington
    My OCD cannot handle front and rear tires at different pressures.
    The tire’s load capacity is related to the pressure. The lower the psi, the lower the capacity. Max load is at max pressure, so you might want to check that.
  12. Mar 13, 2022 at 11:14 AM
    #7572
    20GR8 Super
    Corey
    PNW Outskirts
    My OCD deals cause the ride is better. Lol!
    Agreed! I’d be a bit more worried if I towed my boat more than 2 miles from my house to the dock and back. And most of the time the wife suv pulls it cause the car seats are in it.
  13. Mar 13, 2022 at 9:52 PM
    #7573
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
    Installed the Trigger 4 Plus, Rago ditch mount brackets and BD Squadron Pros this evening. Light output from the Pros is outstanding.
    Now I just need to muster up the time and cajones for the 40” S8 hood bulge install.
  14. Mar 13, 2022 at 11:18 PM
    #7574
    Blue Thunder
    Washington
    Where are the brackets for this coming from? I’ve been wanting to do this but can’t seem to find a good kit.
    gosolo likes this.
  15. Mar 13, 2022 at 11:26 PM
    #7575
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    They’re the SDHQ brackets. I’ve seen plenty of mixed experiences with them here on the forum. That and (partially) the weather has had me dragging my feet on the install. Ooh and winter steelhead fishing.
  16. Mar 13, 2022 at 11:28 PM
    #7576
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    gosolo, reywcms and RainMan_PNW like this.
  17. Mar 14, 2022 at 7:02 AM
    #7577
    Blue Thunder
    Washington
    Sorry, now that you mention SDHQ I remember you’ve told me that before. My bad!
    Think I couldn’t find the mounts last time but I just dug around and found them finally. Nuts they don’t always work.
    gosolo and TunsofFon[QUOTED] like this.
  18. Mar 14, 2022 at 8:59 AM
    #7578
    RaginTxn
    RaginTxn New Member
    Ya done messed up..
    Cypress, TX
    2018 SR5 X Series Tundra (sold) - why, why, why
    I've been very pleased with my Toyo OC AT3s - running at 37 and no complaints. I'm considering the n-fab RKR with the steps you can remove - anyone had experience with them? I had the nerf step on my 4R and was pretty pleased. I like the thought of having the removable steps for when you need them out of the way.
    Also - @reywcms where did you get those sensor protectors?
  19. Mar 14, 2022 at 11:48 AM
    #7579
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    From here.https://snsdesigns.biz/collections/aftermarket-car-parts/products/toyota-abs-sensor-guard
    Awesome product, even down to the packaging.
  20. Mar 14, 2022 at 12:07 PM
    #7580
    Blue Thunder
    Washington
    SDHQ has a set too. I’m running these and they fit great. Actually, they all look the same. https://sdhqoffroad.com/collections...21-toyota-tundra-sdhq-built-billet-abs-guards
  21. Mar 14, 2022 at 12:10 PM
    #7581
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    gosolo, RaginTxn, TunsofFon and 4 others like this.
  22. Mar 14, 2022 at 2:01 PM
    #7582
    20GR8 Super
    Corey
    PNW Outskirts
    Something else that I didn’t know I needed until this forum. Add it to the list! Lol!
    gosolo, Blue Thunder and NWPirate like this.
  23. Mar 14, 2022 at 2:14 PM
    #7583
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LOL. Just let it happen
  24. Mar 14, 2022 at 2:22 PM
    #7584
    20GR8 Super
    Corey
    PNW Outskirts
    How much is an abs sensor? I’m guessing it’s cheap insurance. That’s my angle at least.
  25. Mar 14, 2022 at 2:33 PM
    #7585
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    $340 each from toyota. But also if it happens to get ripped off the rig won't move I believe. As the sensor has input into other aspects on the ecu etc
  26. Mar 14, 2022 at 4:52 PM
    #7586
    Blue Thunder
    Washington
    I was surprised how exposed the sensors are under the truck. Maybe all vehicles are like that but to me they are just begging to get whacked by something.
    gosolo, RainMan_PNW, NWPirate and 2 others like this.
  27. Mar 14, 2022 at 6:43 PM
    #7587
    RainMan_PNW
    Casey
    Clark County, WA
    dammit...something else I need to go bookmark now.
    Pulled the trigger on a CBI rear bumper. Still trying to figure out how exactly to beg for forgiveness with SHMBO on that one...
  28. Mar 14, 2022 at 6:56 PM
    #7588
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Hopefully you get it soon. Can’t wait to see it. Scheduling the bed linex since someone’s coming to get the bed rug this weekend. Then I can finally get the y strap for the spare and molle panels going.
  29. Mar 14, 2022 at 8:56 PM
    #7589
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
  30. Mar 14, 2022 at 9:37 PM
    #7590
    Blue Thunder
    Washington
    reywcms and NWPirate like this.
