North West BS Thread
Discussion in 'North West U.S.' started by JAMMDOGG, Jan 6, 2014.
  1. Dec 10, 2021 at 6:32 PM
    #5971
    NWPirate
    Zach
    WA
    Awesome man, thanks! It's that from center of the bolt hole?
  2. Dec 10, 2021 at 6:46 PM
    #5972
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Need to remove both bolts to put the bracket in. I tried to loosen enough for just one but couldn’t get it to work. Maybe it will work.
    gosolo likes this.
  3. Dec 10, 2021 at 6:48 PM
    #5973
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Yes sir. Center of bolt hole to where the pig tail starts.
    Edit: Also don’t worry about those set screws in the rings. They are allegedly for German laws. I never tightened ours.
    gosolo and NWPirate[QUOTED] like this.
  4. Dec 10, 2021 at 7:10 PM
    #5974
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
    Which brackets did you go with? Looks good btw. I have the Rago brackets but still waiting on the ditch lights to show.
    gosolo and Blue Thunder like this.
  5. Dec 10, 2021 at 9:12 PM
    #5975
    NWPirate
    Zach
    WA
    Perfect, really appreciate the effort! :hattip:
  6. Dec 10, 2021 at 9:20 PM
    #5976
    Dsptundra
    Austin TX Area
    I bought the combo of brackets and lights from Cali Raised. I did not want to invest a bunch in ditch lights until I was sure I liked them. The lights have a two year warranty so it gives me enough time to decide if I like them and can eventually upgrade to a better quality light.
  7. Dec 11, 2021 at 3:53 PM
    #5977
    Dsptundra
    Austin TX Area
    You are right. Took another look at this and could have done one bolt at a time. I blame the beer.
  8. Dec 11, 2021 at 4:53 PM
    #5978
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I agree 100%. I will choose who and where I’m going to advertise for. Isn’t that sort of the basic motive for de-badging?
  9. Dec 11, 2021 at 5:21 PM
    #5979
    Dsptundra
    Austin TX Area
    Also why the first thing I do with a vehicle is take off the dang dealer plate frame!
  10. Dec 11, 2021 at 5:23 PM
    #5980
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Supposed to drink AFTER.
  11. Dec 11, 2021 at 5:23 PM
    #5981
    Blue Thunder
    Washington
    YES!!!
  12. Dec 11, 2021 at 5:36 PM
    #5982
    Dsptundra
    Austin TX Area
    @gosolo Any snow up at your place from this latest storm?
    gosolo and jewsNbrews like this.
  13. Dec 11, 2021 at 5:45 PM
    #5983
    Dsptundra
    Austin TX Area
    That is not nearly as fun.
  14. Dec 11, 2021 at 6:05 PM
    #5984
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    same
    Blue Thunder likes this.
  15. Dec 11, 2021 at 6:14 PM
    #5985
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yesterday we had some big wet flakes and some ice. A few degrees warmer and it’s been all rain; 1 1/3” today.
  16. Dec 11, 2021 at 6:15 PM
    #5986
    Blue Thunder
    Washington
    Reported
  17. Dec 13, 2021 at 8:47 PM
    #5987
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Any of you NW fellas running a Snugtop and have leaking issues? I’m getting water in around the rear corners of the side windows and maybe a spot or two at the bed/canopy interface. My driveway has a slight grade to it and I think the water is all draining to the rear of the side windows and overwhelming the small drain holes in the track. Pretty sure it’s just building up and seeping in. I’m hesitant to take it into AA but I’m probably going to since my front window that opens up with gas struts doesn’t close easily either. I know it’s a COVID cap but I paid a dang pretty penny and waited a long time for this build quality to be what it is. I understand delays during this time but I feel like companies have taken advantage to use it as an excuse for quality issues and that should not be the case.
  18. Dec 13, 2021 at 8:57 PM
    #5988
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    I had one back in 2003/2004 that leaked like a sieve around the rear brake light from the first time it was mounted. It went back to SnugTop either 1 or 2 times and still leaked. I'm sure all the manufacturers have bad ones now and again, but that experience soured me on SnugTop.
    TunsofFon and Blue Thunder like this.
  19. Dec 13, 2021 at 9:29 PM
    #5989
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    My Snugtop doesn’t leak, so I can’t really help
    NWPirate and TunsofFon like this.
  20. Dec 13, 2021 at 9:31 PM
    #5990
    Blue Thunder
    Washington
    Whelp, I’ve owned two Snugtops before. One was on my 2005 F150 and the other was on my 2016 F150. My ‘16 had leaking issues (one of its many problems) on the side window. Not sure what model you have, but mine had the pop/swing out windows (not the sliders).
    When I opened the right side (good) window, the glass had a nice curve to it that matched the contour of the canopy. The left side window was flat when opened. It leaked because the clasp that held the window closed was in the middle of the glass, so the corners wouldn’t get snug (haha) to the weather seal. The clasp also wasn’t strong enough to make it super tight. When they replaced the window, it stopped leaking.
    As for leaking at the bed, of the three I’ve owned (the 3rd was a Leer), the only one that didn’t leak was my ‘16. The dealer covered the bed rail in two rows of weather stripping before dropping the canopy down onto the truck. Not sure how your dealer prepped the bed rail, but if it is just sitting on top then water will get in.
    I had quality problems with all of my canopies. Snugtop is one of the most expensive units and unfortunately the worst in quality from my experience. Sorry to hear you got a bad one.
    NWPirate and TunsofFon[QUOTED] like this.
  21. Dec 13, 2021 at 9:42 PM
    #5991
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    I need to spend more time back there and really narrow down the issues I know of and make sure I take a close look at everything before I take it in. Probably take photos and videos too. I definitely tend to lean on the side of dealing with things myself but with how much this thing cost…
    Blue Thunder and NWPirate like this.
  22. Dec 14, 2021 at 6:00 AM
    #5992
    Blue Thunder
    Washington
    Post a pic for sure. I’m curious if it is the same issue I had
    TunsofFon[QUOTED] likes this.
  23. Dec 14, 2021 at 6:38 AM
    #5993
    Dsptundra
    Austin TX Area
    A chilly 31 degrees this morning and a dusting of snow. Might actually make use of the remote start feature this morning!
  24. Dec 14, 2021 at 3:52 PM
    #5994
    RainMan_PNW
    Casey
    Clark County, WA
    about 1-1/2" on my truck this morning.
    Remote start was great!
  25. Dec 14, 2021 at 4:33 PM
    #5995
    RustyPNW
    RustyPNW New Member
    Oregon
    2018 Cement Tundra SR5 CM TRD
    5100 middle setting, stock rears
    Found 12/12 in Vancouver, WA. Neighbor reported to police. Said it's been parked on the street since early November.
  26. Dec 14, 2021 at 4:34 PM
    #5996
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Glad it was found!
  27. Dec 14, 2021 at 4:55 PM
    #5997
    RainMan_PNW
    Casey
    Clark County, WA
    Holy shit! That's amazing it was found in one piece!
  28. Dec 14, 2021 at 6:25 PM
    #5998
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    That’s wild. Glad it was found!
  29. Dec 14, 2021 at 7:33 PM
    #5999
    Gumbeaux
    Gumbeaux The new guy
    Chip
    Southern Washington
    Black 2010 Tundra Limited Crewmax TRD
    4 inch lift 20" Moto Metal Wheels 33x12.5x20 Duratracs Hooke Road Front Bumper with Bull Bar and LED Lights Smittybilt GEN 2 XRC 9500 Winch Black Fender Flares LED Headlights With Black Housing LED Taillights With Black Housing Pioneer DMH-WT8600NEX Digital Multimedia Receiver Boyo Front Camera Mounted In The Grill Toyota Logo K&N Cold Air Intake Tiger Tonneau Cover
    Yep, that's about what I had, 1.5" -2" this morning.
  30. Dec 15, 2021 at 9:23 AM
    #6000
    Gumbeaux
    Chip
    Southern Washington
    Wow, the snow is coming down fast and furious, all of a sudden!
    gosolo, NWPirate and jewsNbrews like this.
