North West BS Thread
Discussion in 'North West U.S.' started by JAMMDOGG, Jan 6, 2014.
  1. Dec 7, 2021 at 9:08 PM
    #5851
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Exactly. I mainly use it around the place here, which you have seen. But we’re living in a little valley in the forest, east of the coastal range, and frequently there’s trees down on the hiway after storms. I want to be able to clear the road
  2. Dec 7, 2021 at 9:53 PM
    #5852
    Blue Thunder
    Washington
    Looks like Warn does make their hidden bumpers/mounts in the US. The cross/baja bar is also low enough to avoid the sensor. That is good news.
    So I could grab one at a local 4WP shop down there when I’m shopping. Would prob just get one of their winches at the same time so I don’t have to mess with fitment issues. I really like that idea…
    Could even take it to my local Line-X shop for a proper treatment before install.
    jewsNbrews, RainMan_PNW and NWPirate like this.
  3. Dec 8, 2021 at 5:37 AM
    #5853
    NWPirate
    Zach
    WA
    jewsNbrews likes this.
  4. Dec 8, 2021 at 5:41 AM
    #5854
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Thanks!
    NWPirate[QUOTED] likes this.
  5. Dec 8, 2021 at 6:16 AM
    #5855
    Blue Thunder
    Washington
  6. Dec 8, 2021 at 6:20 AM
    #5856
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
  7. Dec 8, 2021 at 6:22 AM
    #5857
    Dsptundra
    Austin TX Area
    Yes, no coverage of that area of the bumper. Was looking at the SSO hybrid again last night. It does a really nice job of filling in the area between the front skid and the bumper as well. No more three plastic tabs connecting to the skid. I also like that it provides shackle points on the front versus the tow hooks. Might have to look at it a bit closer.
    Blue Thunder and NWPirate like this.
  8. Dec 8, 2021 at 6:31 AM
    #5858
    RainMan_PNW
    Casey
    Clark County, WA
    Thanks guys.
    Blue Thunder[QUOTED] likes this.
  9. Dec 8, 2021 at 7:53 AM
    #5859
    Gumbeaux
    Gumbeaux The new guy
    Chip
    Southern Washington
    Black 2010 Tundra Limited Crewmax TRD
    4 inch lift 20" Moto Metal Wheels 33x12.5x20 Duratracs Hooke Road Front Bumper with Bull Bar and LED Lights Smittybilt GEN 2 XRC 9500 Winch Black Fender Flares LED Headlights With Black Housing LED Taillights With Black Housing Pioneer DMH-WT8600NEX Digital Multimedia Receiver Boyo Front Camera Mounted In The Grill Toyota Logo K&N Cold Air Intake Tiger Tonneau Cover
    RainMan_PNW likes this.
  10. Dec 8, 2021 at 8:00 AM
    #5860
    Gumbeaux
    Chip
    Southern Washington
    Reading all of this great info about @Green Thunder bumper/winch search and my experience with the pallet of pellets, has made me start thinking about my suspension because of the weight I've added (armor bumper and winch). I know TJ Jeeps, and can build one from the frame up because I've bought 3 of them stock and done all mods myself (including suspension lifts with belly tucks).....the Tundra....I'm a total NEWBIE. I guess I assumed, like a TJ Jeep, when a lift is added, it replaces the entire suspension system. Is that the case with our Tundras?
    Blue Thunder likes this.
  11. Dec 8, 2021 at 8:08 AM
    #5861
    Dsptundra
    Austin TX Area
    Buckle up, you are about to head down a rabbit hole with this one…
    The common ways to lift the Tundra are new shackles in the rear and then new shocks with adjustable or fixed perches (not correct term) for the springs to sit higher. People also use spacers but those are usually not great for ride quality. Some also replace the rear spring packs which can give a lift without the shackle changes. Lots of different combos from there.
    Edit: Once you get into a lift above 2” in the front replacement control arms can come into play. The Pros come with a 2” lift and use the stock arms (as far as I know) and people do go slightly higher with the stock arms. However, caster and alignment issues can start popping up around there.
  12. Dec 8, 2021 at 8:21 AM
    #5862
    Gumbeaux
    Chip
    Southern Washington
    Hmmm I'll need to crawl underneath and take a look at what they did. When I bought it, the 4" lift was already added, so I have no idea what type of lift was done. Mine is a limited but only a TRD Off Road, not a TRD Pro. So I'm assuming it was originally stock height?
  13. Dec 8, 2021 at 8:24 AM
    #5863
    Dsptundra
    Austin TX Area
    Yes, would have been stock height.
    jewsNbrews and Gumbeaux[QUOTED] like this.
  14. Dec 8, 2021 at 10:59 AM
    #5864
    Gumbeaux
    Chip
    Southern Washington
    In the Tundra world, if I were to upgrade my suspension lift; what are the brands I would look for?
    gosolo and jewsNbrews like this.
  15. Dec 8, 2021 at 11:02 AM
    #5865
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Fox, old man emu, Elka, kings, icon, and BDS.
  16. Dec 8, 2021 at 11:04 AM
    #5866
    Gumbeaux
    Chip
    Southern Washington
    Awesome; thanks!!
  17. Dec 8, 2021 at 5:33 PM
    #5867
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I would add: Alcan, for replacement spring packs and Coachbuilder for high quality replacement shackles
  18. Dec 8, 2021 at 6:13 PM
    #5868
    Blue Thunder
    Washington
    Anyone used/interfaced with Wanderlust Overland in Portland by chance? They're a local SSO dealer. I traded a few emails with them and SSO today and both were very responsive. Nice first impression.
    gosolo, jewsNbrews and NWPirate like this.
  19. Dec 8, 2021 at 7:43 PM
    #5869
    Dsptundra
    Austin TX Area
    I have seen some people post about them on IG. Seems like a good shop based on what I have seen but no first hand experience. At this rate it sounds like you are going to make a lap around the entire PDX metro area picking up parts!
  20. Dec 8, 2021 at 8:04 PM
    #5870
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    Slowly getting everything kitted, now I need to figure out tires.
  21. Dec 8, 2021 at 8:04 PM
    #5871
    Blue Thunder
    Washington
    Three stops for sure. Four if you count a lunch/coffee meet up. Five when I stop at Ray’s estate.
  22. Dec 8, 2021 at 8:04 PM
    #5872
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    :bananadance:
  23. Dec 8, 2021 at 8:04 PM
    #5873
    Dsptundra
    Austin TX Area
    So shiny! Nice.
  24. Dec 8, 2021 at 8:08 PM
    #5874
    Blue Thunder
    Washington
    Eibach was another name I’d seen recently in other threads. Never used them; couldn’t remember the name. Great timing @Kratos.
    Tires are getting rare these days. Maybe half of the tires I was looking at last week on DT were back-ordered. Good luck!
  25. Dec 8, 2021 at 8:13 PM
    #5875
    Kratos
    Kratos Woof
    Not a lot of Tundra reviews, but the Taco guys like them. US made with a great warranty, and they had them on sale. Figured they have to be heads and shoulders better than the black hitachi's on it now.
    The local Discount has pretty good selection as long as I give them a week.
  26. Dec 8, 2021 at 8:43 PM
    #5876
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
    A guy on YouTube named Edward Shin used to have a Tundra build for overlanding. He used and recommended Wanderlust as a great shop. I’ll try to find the video.
    here it is:
    https://youtu.be/Iv0SIwI3fjY
  27. Dec 8, 2021 at 8:59 PM
    #5877
    RainMan_PNW
    Casey
    Clark County, WA
    Where are they at? I had a buddy get an Ironman suspension installed by an outfit out east side but I can’t remember the name
  28. Dec 8, 2021 at 9:02 PM
    #5878
    RainMan_PNW
    Casey
    Clark County, WA
    I’m not looking forward to figuring out what to do when i need my TRD Pro Fox shocks rebuilt. If it’s indeed 50k miles, that’s gonna be just over a year from now
    gosolo and Blue Thunder like this.
  29. Dec 8, 2021 at 9:07 PM
    #5879
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Off 99E by Oregon City
  30. Dec 8, 2021 at 9:07 PM
    #5880
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    I called wanderlust for cab chop in the 4Runner. They were 2-3 times as expensive as everyone else. They seem to put out good work. Never had anything in there though. Couldn’t justify about $500.
    gosolo, NWPirate and Blue Thunder like this.
