North West BS Thread
Discussion in 'North West U.S.' started by JAMMDOGG, Jan 6, 2014.
  1. Oct 12, 2021 at 6:34 PM
    #5311
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Make sure you install a Fumoto valve first. The last bit of oil drains onto the skid plate if you don’t.
  2. Oct 12, 2021 at 7:08 PM
    #5312
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
  3. Oct 12, 2021 at 7:50 PM
    #5313
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    Appreciate the tip!
    jewsNbrews likes this.
  4. Oct 12, 2021 at 7:54 PM
    #5314
    Kratos
    Kratos Woof
    @gosolo
    I know your into damascus and figured you'd get a kick out of this Caspian slide.
  5. Oct 12, 2021 at 8:00 PM
    #5315
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    Great googly moogly that kicks ass.
  6. Oct 12, 2021 at 8:03 PM
    #5316
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    That’s beautiful. I wish I had machine tooling skills and a lathe and a mill!
    I do what I can with the tools I’ve got.
  7. Oct 12, 2021 at 8:34 PM
    #5317
    Blue Thunder
    Washington
    I might have just creamed my pants…
  8. Oct 13, 2021 at 11:48 AM
    #5318
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    No idea when my sliders will be here and my Valhalla shields are caught in FedEx hell but this made it though. Just need to find time to install and for the lights for it to actually show up…
  9. Oct 13, 2021 at 2:08 PM
    #5319
    Explorer
    Explorer New Member
    Battle Ground WA
    2019 Silver Tundra SR5 TRD Offroad
    Nice. I just got mine installed this last weekend.
  10. Oct 13, 2021 at 3:01 PM
    #5320
    Dsptundra
    Austin TX Area
    Did you wire direct to the battery or did you tap into a ignition powered circuit/fuse?
  11. Oct 13, 2021 at 3:04 PM
    #5321
    Explorer
    Explorer New Member
    Battle Ground WA
    I've got a dual battery so I have it wired directly. I think I would wire it directly anyway. The app has a battery level shut off that you can make sure it doesn't drain down the battery.
  12. Oct 13, 2021 at 8:56 PM
    #5322
    SSPey
    SSPey .
    Oregon
    2021 DinoSR5
    What are you gonna run with this? I’m curious when enough stuff warrants it.
  13. Oct 13, 2021 at 9:04 PM
    #5323
    Dsptundra
    Austin TX Area
    Starting with ditch lights and currently researching light bars for the grill. I am also looking at some LED light for the bed that could be controlled from this controller. Lastly, if I convert to on board air or add a winch I’ll control the relays with this controller.
    I thought about the 4 channel version but was afraid I’d find myself short in the future and the 6 channel was only a little bit more.
  14. Oct 14, 2021 at 8:48 AM
    #5324
    NWPirate
    Zach
    WA
    New brakes on the '04 yesterday.
    Fun fact: Sequoia rear brakes have disk and drum pads. The inner drum pads are for the E-brake only.
  15. Oct 14, 2021 at 10:23 AM
    #5325
    Dsptundra
    Austin TX Area
    Looks clean under there! Did you coat the frame recently?
    jewsNbrews and NWPirate[QUOTED] like this.
  16. Oct 14, 2021 at 10:43 AM
    #5326
    NWPirate
    Zach
    WA
    Thanks, yeah just cleaned it and put on a coat of moly grease, @PHM style.
    Trying to keep this thing on the road for another 18 years. :fingerscrossed:
    The frame is in great shape but the rear diff needed some love, took a wire wheel to some rust and coated it also. I plan on doing a re-grease every fall.
  17. Oct 14, 2021 at 12:25 PM
    #5327
    Kratos
    Kratos Woof
    Looks great, did you do it yourself?
    gosolo likes this.
  18. Oct 14, 2021 at 12:28 PM
    #5328
    Kratos
    Kratos Woof
    Visited a local Service Dept yesterday, and to go with a winter set of wheels/tires you need to program the truck each time to accept the new TPMS. $55 twice a year, plus the hassle of taking it to the dealer. I may just stick with the wheels I have and put on something better suited for the winter like the Toyo AT3.
  19. Oct 14, 2021 at 12:33 PM
    #5329
    NWPirate
    Zach
    WA
    Yes sir, thanks :hattip:
    Kratos[QUOTED] likes this.
  20. Oct 14, 2021 at 12:35 PM
    #5330
    NWPirate
    Zach
    WA
    Yeah, that bill adds up.
  21. Oct 14, 2021 at 12:39 PM
    #5331
    Kratos
    Kratos Woof
    How long did it take with that set-up, and how did you bleed the brakes?
    gosolo likes this.
  22. Oct 14, 2021 at 12:59 PM
    #5332
    NWPirate
    Zach
    WA
    If I was just doing the rotors and pads, 2 hours. I didn't crack the bleeders, just hung the calipers out of the way.
    The cleaning and greasing took the most time!
    gosolo, Kratos[QUOTED] and jewsNbrews like this.
  23. Oct 14, 2021 at 1:30 PM
    #5333
    Blue Thunder
    Washington
    Can we reprogram the system at home?
    jewsNbrews and Kratos[QUOTED] like this.
  24. Oct 14, 2021 at 1:32 PM
    #5334
    Kratos
    Kratos Woof
    I think you can with the Techstream software. That isn't something I've looked at.
    gosolo and Blue Thunder[QUOTED] like this.
  25. Oct 14, 2021 at 4:32 PM
    #5335
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    yes, with bootleg techstream and a cable you can
  26. Oct 15, 2021 at 1:04 PM
    #5336
    RainMan_PNW
    Casey
    Clark County, WA
  27. Oct 15, 2021 at 1:12 PM
    #5337
    Kratos
    Kratos Woof
    I thought this was funny, but then again I'm not a cat guy.
  28. Oct 15, 2021 at 1:28 PM
    #5338
    NWPirate
    Zach
    WA
    Blue Thunder and jewsNbrews like this.
  29. Oct 15, 2021 at 1:30 PM
    #5339
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Anyone know if you live in Idaho but work in Washington if they'll still take out that tax?
  30. Oct 15, 2021 at 1:34 PM
    #5340
    Blue Thunder
    Washington
    Did you get a notice or just had to check your account!?
    NWPirate and jewsNbrews like this.
