North West BS Thread
Discussion in 'North West U.S.' started by JAMMDOGG, Jan 6, 2014.
  1. Oct 9, 2021 at 6:53 PM
    #5281
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Did I hear knives?
    Knives?
    got my attention!
    Kratos, NWPirate, jewsNbrews and 2 others like this.
  2. Oct 9, 2021 at 7:01 PM
    #5282
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Get some rest Ray!
  3. Oct 9, 2021 at 7:37 PM
    #5283
    Blue Thunder
    Washington
    Nothing much. I rinse the sewer hose really well when I do the final dump. I always drain and dry the freshwater hose so that just gets tucked away. I’ll probably soak it in something come spring.
    Atta boy
    gosolo[QUOTED] and NWPirate like this.
  4. Oct 10, 2021 at 8:10 AM
    #5284
    NWPirate
    Zach
    WA
    Favorite so far.
  5. Oct 10, 2021 at 10:27 AM
    #5285
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Do you pull your battery or just disconnect it?
    gosolo likes this.
  6. Oct 10, 2021 at 11:27 AM
    #5286
    Blue Thunder
    Washington
    Neither actually, as I have a disconnect switch. Kinda like a boat. So I charge it up, flip the switch and let it go. I'll plug it in every few months for 2-3 days to top off.
    NWPirate and jewsNbrews like this.
  7. Oct 10, 2021 at 11:55 AM
    #5287
    Dsptundra
    Austin TX Area
    I have a disconnect too with a dual battery setup. Since I have it in storage offsite I’ll need to pull the batteries on occasion or go over and plug in the truck and let it idle for a bit.
    jewsNbrews likes this.
  8. Oct 10, 2021 at 12:06 PM
    #5288
    Blue Thunder
    Washington
    I'm not a battery nerd, but I've always thought the charge off the truck was pretty slow/low and won't make much difference in a short period. I have twin 6Vs, but when we went on a two-week trip a few years ago without service, I didn't see much of a change in charge even after a 60 min drive between camps. I like to keep mine charged up in case we need to use it during the winter (say the house is w/o power and we need heat), but I bet your batteries will be fine for 3-4 months if they don't have any of the parasitic draws on them.
  9. Oct 10, 2021 at 1:03 PM
    #5289
    NWPirate
    Zach
    WA
    Not that you asked, but I'll give you my routine. :D
    I've got dual 6V Trojan batteries, I like to pull them over the winter and store them in the garage. Mostly because we can see negative temps here for part of the winter. My garage stays in the 40-50°range and I'll trickle charge them a couple times in the off-season.
  10. Oct 10, 2021 at 1:23 PM
    #5290
    Dsptundra
    Austin TX Area
    I’ll take all the help I can get! This is my first trailer so trying to avoid completely screwing things up.
  11. Oct 10, 2021 at 1:28 PM
    #5291
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    The best way to learn is to not do anything in the fall, just park it somewhere under the maple trees. Then, next summer, when you are ready to go camping you make a list of all the stuff that broke. That’s what I’ve always done, lol.
  12. Oct 10, 2021 at 1:33 PM
    #5292
    NWPirate
    Zach
    WA
    Hard to completely screw up the batteries unless you have a draw on them all winter. Like @Green Thunder said, top them off and switch your disconnect off. Worthwhile to check the water level too before you walk away from them.
    Blue Thunder and jewsNbrews like this.
  13. Oct 10, 2021 at 1:33 PM
    #5293
    NWPirate
    Zach
    WA
    Solid advice!
  14. Oct 10, 2021 at 2:40 PM
    #5294
    Blue Thunder
    Washington
    Expensive but effective
  15. Oct 10, 2021 at 4:08 PM
    #5295
    Blue Thunder
    Washington
    I’ll do a brain dump…
    - If you drain the water for the winter, find the pump and empty the filter catch (where @NWPirate found the shavings). It doesn’t self-drain even when you blow air through the system. It will freeze and crack very easily.
    - If you add the anti-freeze stuff, don’t get cheap. I put a full gallon thru the hot water heater to displace all water. Once I drained the holding tanks I pour a full gallon into each. I’d rather spend a few extra bucks now than pay a Tech to chase a leak in the spring. Used 6 gallons total for my small trailer.
    - Cover your RV if you can during the winter. It will look much better come spring and be easier to clean
    - I put 5 gallon bucket’s on the roof between the vents and a/c to hold a peak in the middle of the cover. Then I leave my vents open to encourage airflow. This seems to stop mildew under the cover, especially on the roof.
    - Check the desiccants every few weeks. They seem to be empty for a month and then full within a few days.
    - Batteries are tough…. But we have already covered that.
  16. Oct 10, 2021 at 4:12 PM
    #5296
    Dsptundra
    Austin TX Area
    This is good stuff. I appreciate the input @Green Thunder and @NWPirate! Rather source tips here then on YouTube or some other source.
  17. Oct 10, 2021 at 4:21 PM
    #5297
    NWPirate
    Zach
    WA
    No problem.
    Don't forget to flush the toilet if you are using antifreeze or air to blow out the lines. I forgot once on my last trailer, had to replace the valve. :D
  18. Oct 10, 2021 at 4:41 PM
    #5298
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Generally speaking, never forget to flush the toilet. And another thing I’ve noticed is, “how often does she leave the seat up for you?”
  19. Oct 10, 2021 at 5:10 PM
    #5299
    NWPirate
    Zach
    WA
    Not enough!
  20. Oct 10, 2021 at 5:23 PM
    #5300
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Just trying to level the playing field
  21. Oct 10, 2021 at 5:49 PM
    #5301
    Blue Thunder
    Washington
    Glad to see you online. I assume you are in the mend. Hope your wife is holding steady too
  22. Oct 10, 2021 at 5:54 PM
    #5302
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Definitely in and out of it
    Kratos, Blue Thunder and jewsNbrews like this.
  23. Oct 12, 2021 at 11:30 AM
    #5303
    NWPirate
    Zach
    WA
    Anyone else see the northern lights?
  24. Oct 12, 2021 at 11:31 AM
    #5304
    RainMan_PNW
    Casey
    Clark County, WA
    It's been a long time since I have. Pretty awesome.
  25. Oct 12, 2021 at 11:39 AM
    #5305
    NWPirate
    Zach
    WA
    Me too, wife took this picture. I didn't feel like getting out of bed. :rofl:
  26. Oct 12, 2021 at 11:41 AM
    #5306
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Nope, cool picture.
  27. Oct 12, 2021 at 1:51 PM
    #5307
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    Nope. We looked but didn't catch them. Cool pic though!
  28. Oct 12, 2021 at 6:24 PM
    #5308
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    My RCI skid showed up today, I ordered it during their sale and they got it here in in 5 weeks. Damn good pack job also, zero damage.
    jewsNbrews, Dsptundra and NWPirate like this.
  29. Oct 12, 2021 at 6:25 PM
    #5309
    Blue Thunder
    Washington
    From this side of the state? Haha. No. But that is top five on the bucket list. Ideally when I’m staying at an ice hotel in the far North drinking a coffee cocktail.
    jewsNbrews and NWPirate[QUOTED] like this.
  30. Oct 12, 2021 at 6:27 PM
    #5310
    NWPirate
    Zach
    WA
    That would be an epic time!
