North West BS Thread
Discussion in 'North West U.S.' started by JAMMDOGG, Jan 6, 2014.
  1. Oct 7, 2021 at 11:15 AM
    #5221
    NWPirate
    Zach
    WA
    Definitely not my scene then.
    If I may speak for @gosolo, yeah he is. It was mentioned in another thread.
  2. Oct 7, 2021 at 11:16 AM
    #5222
    NWPirate
    Zach
    WA
    :101010::oldglory:
    jewsNbrews and Blue Thunder like this.
  3. Oct 7, 2021 at 12:08 PM
    #5223
    Blue Thunder
    Washington
    I saw ads to shoot a 50cal. Think it was $30/rd. Nutty.
    NWPirate and jewsNbrews like this.
  4. Oct 7, 2021 at 12:09 PM
    #5224
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Just get a black powder .50 cal. No not the same, but still fun to shoot.
  5. Oct 7, 2021 at 12:53 PM
    #5225
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I've got enough friends with those... Unless it's the Browning Ma-duece
  6. Oct 7, 2021 at 12:57 PM
    #5226
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Does that thing use compressed air to run it or chilled water to keep it cool? What are all the lines for?
  7. Oct 7, 2021 at 1:07 PM
    #5227
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    Hope you get over it quickly.. My wife had cancer, and lost stamina etc... also, it's the only reason I got the jab.
    jewsNbrews, Blue Thunder and NWPirate like this.
  8. Oct 7, 2021 at 1:08 PM
    #5228
    Kratos
    Kratos Woof
    They allow weed in the Casino's?
    jewsNbrews likes this.
  9. Oct 7, 2021 at 1:31 PM
    #5229
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yeah it’s pretty messed up. Sorry to hear about your wife also.
    Blue Thunder likes this.
  10. Oct 7, 2021 at 2:20 PM
    #5230
    Blue Thunder
    Washington
    Didn’t see anyone smoking a blunt, but the vapor thingies with the space juice inserts were everywhere. Go outside and the skunk was worse than a college party. Dudes were rolling as they walked down the strip
  11. Oct 7, 2021 at 2:26 PM
    #5231
    Kratos
    Kratos Woof
    Guess I shouldn't be surprised, it's a party town. I've heard downtown Seattle is the same way.
  12. Oct 7, 2021 at 2:52 PM
    #5232
    Dsptundra
    Austin TX Area
    Currently I wish I was smelling weed each morning outside my house instead of damn skunks. Little bastards. My dogs got into one a couple years ago at like 5am in the morning. Not a good way to start your day.
  13. Oct 7, 2021 at 3:04 PM
    #5233
    Blue Thunder
    Washington
    Since weed is still illegal in most states (and countries), I think it becomes the thing to do when you cut loose in Vegas. Kinda like when you turn 21 and go get hammered.
    RainMan_PNW, NWPirate and jewsNbrews like this.
  14. Oct 7, 2021 at 4:27 PM
    #5234
    RainMan_PNW
    Casey
    Clark County, WA
    Electric power - that's what powers the rotation of the barrels and the actual firing. The toggle switch under the red cover flips it on, then the red buttons next to either handle are the "triggers". It's air cooled.
  15. Oct 7, 2021 at 5:20 PM
    #5235
    NWPirate
    Zach
    WA
    Got a lot done around the property today, despite almost losing a tractor wheel. My FIL isn't known for maintenance. At minimum, it needs a new hub and bolts.
  16. Oct 7, 2021 at 6:17 PM
    #5236
    Blue Thunder
    Washington
    @NWPirate got it installed tonight. Not happy with how far I got the lower hose onto the nipple, but will have to fix that this weekend. A split knuckle means it is time to step away.
  17. Oct 7, 2021 at 6:34 PM
    #5237
    NWPirate
    Zach
    WA
    It is isn't it!? Excellent quality.
    Did you have to rip the piece off foam above the pcv? I sure did, not worried about it though.
  18. Oct 7, 2021 at 6:55 PM
    #5238
    Blue Thunder
    Washington
    Yeah, I ripped bits by bits to not try and destroy too much. But it keeps your hands from really getting into the pocket to shove on the hose. Think I’ll get the heat gun out and warm up the hose so it is more pliable.
  19. Oct 8, 2021 at 10:58 AM
    #5239
    NWPirate
    Zach
    WA
    If your RV has an inline filter by the pump, check it out!
    Found some delicious plastic from the water tank sensors being drilled out at the factory.
  20. Oct 8, 2021 at 11:04 AM
    #5240
    Dsptundra
    Austin TX Area
    :monocle:I will have to take a look at mine. Just winterized it last week but need to take some stuff over to it for storage.
    jewsNbrews and NWPirate[QUOTED] like this.
  21. Oct 8, 2021 at 11:18 AM
    #5241
    Blue Thunder
    Washington
    That’s just bad. I’d be pissed to see that much crap in the filter.
  22. Oct 8, 2021 at 11:25 AM
    #5242
    NWPirate
    Zach
    WA
    Weirdly enough, not pissed about it. It's probably due to my low expectations of the minimum wage workers slapping these things together.
  23. Oct 8, 2021 at 11:34 AM
    #5243
    Kratos
    Kratos Woof
    If it has a clamp, you can use a touch of lube also.
  24. Oct 8, 2021 at 12:34 PM
    #5244
    Blue Thunder
    Washington
    It is super-lubed already. Just hard to shove it onto the nippleo_O
  25. Oct 8, 2021 at 2:47 PM
    #5245
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    Thanks for the heads up. Just getting ready to winterize.
  26. Oct 8, 2021 at 3:15 PM
    #5246
    NWPirate
    Zach
    WA
    You bet :thumbsup:
  27. Oct 8, 2021 at 3:58 PM
    #5247
    Blue Thunder
    Washington
    Ahead of a schedule for the weekend chores. Fixed the catch can, garage is about 75% cleaned and the trailer is tucked in…image.jpg So time to…C9F82390-0A39-4089-89D3-BA4C5663EC05.jpg
  28. Oct 8, 2021 at 4:14 PM
    #5248
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Just got gutters cleaned. No rain, everything was baked to the bottom. Came out easy enough though.
    NWPirate and Blue Thunder like this.
  29. Oct 8, 2021 at 4:39 PM
    #5249
    RainMan_PNW
    Casey
    Clark County, WA
    Two beers down - time to leave work.
    :D
    Blue Thunder, jewsNbrews and NWPirate like this.
  30. Oct 8, 2021 at 4:47 PM
    #5250
    NWPirate
    Zach
    WA
    Threw a little sunshine in mine, for taste. Good thing I don't have neighbors close, they would of called the padded van on me for taking yard beer pics.
