North West BS Thread
Discussion in 'North West U.S.' started by JAMMDOGG, Jan 6, 2014.
  1. Sep 29, 2021 at 12:09 PM
    #5101
    Explorer
    Explorer New Member
    Battle Ground WA
    2019 Silver Tundra SR5 TRD Offroad
    Blue Thunder likes this.
  2. Sep 29, 2021 at 12:10 PM
    #5102
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    I will PM you my address for the commission if he buys them!;)
    Blue Thunder and NWPirate like this.
  3. Sep 29, 2021 at 12:11 PM
    #5103
    Explorer
    Explorer New Member
    Battle Ground WA
    :rofl::rofl: Sounds good
  4. Sep 29, 2021 at 12:15 PM
    #5104
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I was actually surprised how well the stock Michelin tires did in the snow. If it was me, I wouldn't worry about snow tires unless planning on going over the pass were it maybe required to have them or chains. We had a foot of snow here and they did well in the snow.
  5. Sep 29, 2021 at 12:18 PM
    #5105
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    285/65/18 is a size up from the 275/65/18 stocks. Looks good without a lift. Pic of my 17 SR5, stock suspension. 20190609_064405.jpg 20190509_174403.jpg
  6. Sep 29, 2021 at 12:20 PM
    #5106
    Dsptundra
    Austin TX Area
    No rubbing or other issues?
  7. Sep 29, 2021 at 12:21 PM
    #5107
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Nope. Had to remove front mud flap that's connected to the bumper is all. But that was probably more so because I had new wheels with +20 offset compared to +60 stock off road rims.
  8. Sep 29, 2021 at 12:29 PM
    #5108
    Dsptundra
    Austin TX Area
    Offset confuses me. Higher the number pushes the tire out or in?
    Kratos and jewsNbrews[QUOTED] like this.
  9. Sep 29, 2021 at 12:30 PM
    #5109
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    The higher the positive offset, the further they are in the wheel wells.
    Kratos, jewsNbrews and Dsptundra like this.
  10. Sep 29, 2021 at 12:34 PM
    #5110
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    In. Zero means the center of the wheel is in the middle of the width of the rim. + Offset pushes the center of the wheel outward on the wheel, meaning it sucks the wheel/tire into the wheel well. - offset means the center of the wheel pushed inward on the rim which pushes the wheel/tire out of the wheel well.
    Kratos likes this.
  11. Sep 29, 2021 at 12:42 PM
    #5111
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    I'm seeing that very few after market wheels have an offset of +20 or greater. I think the factory wheel is +60?
  12. Sep 29, 2021 at 12:45 PM
    #5112
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    That's another confusing subject. Everyone talks offset, but really should talk back spacing. Off set tells you about the wheels off set. But the offset on wheels can be different. A +20 offset on a 8" wide rim isn't the same as a +20 offset on a 9" rim. Backspacing should be the true way to know how far your wheel tire setup will be pushed out.
    NWPirate and Kratos[QUOTED] like this.
  13. Sep 29, 2021 at 1:54 PM
    #5113
    NWPirate
    Zach
    WA
    I'll try and find it
  14. Sep 29, 2021 at 2:10 PM
    #5114
    Blue Thunder
    Washington
    Check out OfferUp. There are a ton listed there. These are not TRD… https://offerup.co/mAmHUOvkXjb
  15. Sep 29, 2021 at 3:26 PM
    #5115
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
    Good news....picked up the truck on my lunch break. It looks fantastic (pictures to come) and no BMC was needed as of yet. They said it was super close and may be needed depending on how it settles but that they didn't want to do it if they weren't 100% sure it was needed. Really happy with all of it.
  16. Sep 29, 2021 at 4:00 PM
    #5116
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    Happy with the shop and the work they did? If so, I will give them a call.
  17. Sep 29, 2021 at 4:04 PM
    #5117
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    For sure. They worked on my 2002 Tundra a while back too. I really appreciated what he said about doing the BMC- "We didn't want to spend 350 of your dollars if we didn't 100% have to". They also fit me in early since they could keep it a few days and finished over a day earlier than expected.
    jewsNbrews likes this.
  18. Sep 29, 2021 at 4:25 PM
    #5118
    RyeHog
    RyeHog New Member
    2014 MGM Sr5 Tundra
    NWPirate likes this.
  19. Sep 29, 2021 at 4:36 PM
    #5119
    NWPirate
    Zach
    WA
    Kratos, jewsNbrews and RyeHog[QUOTED] like this.
  20. Sep 29, 2021 at 4:38 PM
    #5120
    point08
    point08 New Member
    Kyle
    2014 Toyota Tundra 5.7L SR5 4WD DC
    AirLift LoadLifter 5000 Ultimate Plus, AirLift Wireless One 2nd Gen, TRD Rear Sway Bar, Bakflip G2 Tonneau Cover, Running Boards, Tint, Power Tailgate Lock, Hike-It X9 Throttle Controller, Tekonsha P3 Brake Controller with Custom In-Dash Housing, Method 701 Wheels, Toyo Open Country III Tires, 3WLiner Window Mod, External Fuse Box, Dash Cam, Pioneer DMH-1500NEX
    For the beach goers in here, I spent the weekend up at Ocean Shores and drove out on the beach several times. Never went into the ocean or over deep sand outside of wet sand being tossed up from the tires or existing tracks. What's the proper 'cleaning' routine one should follow for this? Thx!
  21. Sep 29, 2021 at 5:14 PM
    #5121
    Dsptundra
    Austin TX Area
    I hook up the hose and spray the heck out of everything underneath. That sand sticks so you have to hit it with the “jet” setting on the nozzle to get it off. I also try to give the whole truck a wash as soon as I can to get it clean and also suck out the ten pounds of sand my kids have likely tracked into the back door mats.
    NWPirate, jewsNbrews and Blue Thunder like this.
  22. Sep 29, 2021 at 5:14 PM
    #5122
    RyeHog
    RyeHog New Member
    2014 MGM Sr5 Tundra
    I just noticed your location, I’m going to have to try that haha. It seems like Seattle is the only city anyone knows about in Washington lol
  23. Sep 29, 2021 at 5:59 PM
    #5123
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Unfortunately
  24. Sep 29, 2021 at 6:12 PM
    #5124
    NWPirate
    Zach
    WA
    Yep, lol
  25. Sep 29, 2021 at 6:14 PM
    #5125
    Dsptundra
    Austin TX Area
    Wait. You don’t all live in Seattle?
    :boink:
  26. Sep 29, 2021 at 7:46 PM
    #5126
    Blue Thunder
    Washington
    To anyone outside the PNW, yes I am from Seattle
    RainMan_PNW, jewsNbrews and NWPirate like this.
  27. Sep 29, 2021 at 11:25 PM
    #5127
    TunsofFon
    Pacific NW
    2021 MGM Platinum
  28. Sep 29, 2021 at 11:50 PM
    #5128
    Blue Thunder
    Washington
    Oh. Hell. Yeah.
  29. Sep 30, 2021 at 12:36 AM
    #5129
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    The stock tires, struts, shocks, and UCAs were in the bed but not sure how much that all weighs. I'm hoping the front settles a bit since I'll have the canopy on too. I'm currently rub free with no chopping so that's sweet.
  30. Sep 30, 2021 at 6:23 AM
    #5130
    BrunoTheRescuePup
    SW Portland Metro
    This is awesome. Well done.
    gosolo and TunsofFon[QUOTED] like this.
