North West BS Thread
Discussion in 'North West U.S.' started by JAMMDOGG, Jan 6, 2014.
  1. Sep 5, 2021 at 10:19 AM
    #4741
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    I agree that it's not related to RPM's, so a heat shield vibrating sounds plausible. If that's it, it's either loose or rubbing on something and WD40 won't fix it. I'd crawl under there and feel around a bit with the shields, might be an easy fix.
    Blue Thunder likes this.
  2. Sep 5, 2021 at 11:05 AM
    #4742
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    A simple way to check and see what the problem is;
    Jack up the entire rear of your truck, getting both wheels off the ground.
    First, get under there and manually turn the drive shaft while you look and listen.
    If you don’t see or hear anything…
    (Insert here: solidly supporting the rear axle and with redundant blocking)
    Start the truck and put it in gear. Repeat the search.
    I have had to do this with all 4 wheels off the ground (not a tundra), and try in and out of 4x4 to diagnose a problem.
    NWPirate and Kratos like this.
  3. Sep 5, 2021 at 11:21 AM
    #4743
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
  4. Sep 5, 2021 at 11:35 AM
    #4744
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Definitely not just you. The front end proportions look similar to the current Titan, which totally ruins the look in my opinion.
  5. Sep 5, 2021 at 3:09 PM
    #4745
    Blue Thunder
    Washington
    Just strange. Maybe my audio is off, but doesn’t sound like a heat shield rattle. My other guess was a bearing, but that doesn’t seem like a solid fit either.
    Make sure you are there to drive with the Tech. You can drive and they can focus on the troubleshooting
    jewsNbrews and Kratos like this.
  6. Sep 5, 2021 at 3:14 PM
    #4746
    Kratos
    Kratos Woof
    Now that I listened to it again, it sounds like that polishing tool they use on your teeth at the dentists.
    If you listen closely at the beginning of the vid, it starts out completely silent and then there is distinct "click" when it starts up.
    Blue Thunder and TunsofFon like this.
  7. Sep 5, 2021 at 3:15 PM
    #4747
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    I'm almost certain it's the same issue another forum member is dealing with- a bad dust pinion seal/shield or rear diff dust deflector. It's definitely not a heat shield, rear brake shields and rotors are free and clear, doesn't have the clicking of a bearing. I listened to his audio video and it's the EXACT same noise. I think he said the dealership narrowed it down to the dust seal by spraying WD on it and the noise went away for a while.
    Blue Thunder[QUOTED] likes this.
  8. Sep 5, 2021 at 3:16 PM
    #4748
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Yes I have been hearing what seems to be a faint click or knock before it starts up.
  9. Sep 5, 2021 at 3:21 PM
    #4749
    Blue Thunder
    Washington
    So is all that inside the rear diff? Never heard of a dust seal
  10. Sep 5, 2021 at 3:24 PM
    #4750
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    haha no clue! I watched a few videos and looked at some images. I believe they have to pull the driveline and remove the nut that puts pre tension on the pinion gear, which is a bummer.
  11. Sep 5, 2021 at 3:26 PM
    #4751
    Blue Thunder
    Washington
    Do you have a GoPro by chance? Could mount it down by the rear diff and get better audio
    TunsofFon[QUOTED] likes this.
  12. Sep 5, 2021 at 4:04 PM
    #4752
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Yeah I did that with my 2002 limited that had a popping noise I chased for 5 years and never did find.
    It's a good idea to do it again, even if just for more info at the dealership.
    gosolo and Blue Thunder like this.
  13. Sep 6, 2021 at 1:48 PM
    #4753
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    Anybody else get out camping? Perfect weather. Great time with our daughter and grandson. He was covered in dirt like you should be when camping. Ohanapecosh campground Mt. Rainer.
  14. Sep 6, 2021 at 4:08 PM
    #4754
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Mowed the lawn and washed both cars. Time to clean up and find a happy hour somewhere. Hope everyone is having great Labor Day.
    Kratos, RainMan_PNW, gosolo and 3 others like this.
  15. Sep 6, 2021 at 4:13 PM
    #4755
    Blue Thunder
    Washington
    It was a painting weekend for me. Gotta do the interior doors next weekend…
    Anyone sell stuff on OfferUp? If you’ve got something posted I need to test my messenger system. I’ve pinged over a dozen people and zero replies so far.
  16. Sep 6, 2021 at 4:38 PM
    #4756
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Never used it. Maybe because of holiday weekend they'll get back to you tomorrow.
    Blue Thunder[QUOTED] and gosolo like this.
  17. Sep 6, 2021 at 5:12 PM
    #4757
    Blue Thunder
    Washington
    I wish that was it. But I’ve pinged folks for months on various topics. Even a guy with a Tundra exhaust! Nothing back from anyone
    gosolo and jewsNbrews[QUOTED] like this.
  18. Sep 6, 2021 at 5:15 PM
    #4758
    NWPirate
    Zach
    WA
    Night 6 of 6 for us.
    KOA in Castlerock, probably won't return here but for a last minute booking I'll take it. According to the locals there are several longterm campers here that cashed in on the housing bubble with nowhere to go. It's got that vibe, oh well..
    Just poured a cocktail, waiting for it to cool off and I'll light a fire.
    This was last night for all you picture whores like myself. :D
  19. Sep 6, 2021 at 6:25 PM
    #4759
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Well…it is Castle Rock. ;)
    gosolo, Kratos, Blue Thunder and 2 others like this.
  20. Sep 6, 2021 at 6:42 PM
    #4760
    NWPirate
    Zach
    WA
  21. Sep 6, 2021 at 6:45 PM
    #4761
    RainMan_PNW
    Casey
    Clark County, WA
    Surprised you don’t have a few of these in that camp
  22. Sep 6, 2021 at 6:47 PM
    #4762
    NWPirate
    Zach
    WA
    Close.. one temporary permanent resident was out running his chainsaw for shits and gigs.
  23. Sep 6, 2021 at 7:09 PM
    #4763
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    I don't feel I've narrowed things down with this, but here is the undercarriage video of the noise.
    https://youtu.be/tif0-m4CN7k
    https://youtu.be/BbWbFs-cPKc
    I'm taking it to the dealership tomorrow morning. A little nervous about the whole situation on a brand new truck. On the other hand I'm glad it happened before the lift, wheels and tires went on. Nothing I've done yet should be an issue.
  24. Sep 6, 2021 at 7:41 PM
    #4764
    NWPirate
    Zach
    WA
  25. Sep 6, 2021 at 10:28 PM
    #4765
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    i hope I’m wrong, but it sounds like a dry bearing. I’d bet a cup of coffee.
    gosolo, Blue Thunder and NWPirate like this.
  26. Sep 6, 2021 at 10:44 PM
    #4766
    Blue Thunder
    Washington
    I’d be all kinds of rage, but chit does happen. The good news is it appears to be very repeatable. The GoPro confirms it’s coming from the diff area, so that should help the Tech.
    And you are right, better now than after all the suspension mods. That kind of stuff gives dealers a reason to avoid work
    gosolo likes this.
  27. Sep 7, 2021 at 7:12 AM
    #4767
    Blue Thunder
    Washington
    While we all wait for a sitrep from @TunsAFun, I’m happy to report I got my OfferUp account fixed. Thanks to generous help from @InTheRough, I/we were able to confirm my messages were not going thru. Tech Support confirmed my account was “locked” (no reason given) and promptly fixed.
    There are two things I’ve been trying to buy all summer. One was a Camp Chef burner cooktop. The other was a Tundra exhaust take-off to replace the drone-filled TRD. Scored a great deal last night on a Camp Chef…now just need someone to post an OEM exhaust!
  28. Sep 7, 2021 at 9:20 AM
    #4768
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Are you only needing the muffler section? Or do you need the tail too?
  29. Sep 7, 2021 at 10:15 AM
    #4769
    Blue Thunder
    Washington
    Looking for the whole thing. The TRD is fun around town, but the drone drives me nuts. Especially when I’m towing. Rumor on the forum is the exhaust also robs a bit of power, so a quieter cabin and more power is a good thing.
  30. Sep 7, 2021 at 1:10 PM
    #4770
    RyeHog
    RyeHog New Member
    2014 MGM Sr5 Tundra
    A friend just reminded me why I love my tundra. He was towing is fifth wheel home yesterday and this happens. 2014 ram 3500 6.7 Cummins with 140k miles.
    WAtundra4x4, gosolo, NWPirate and 2 others like this.
