North West BS Thread
Discussion in 'North West U.S.' started by JAMMDOGG, Jan 6, 2014.
  1. Sep 3, 2021 at 9:00 PM
    #4711
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    I thought there was a state wide ban right now. Regardless mr TVFR friends would beat me with a big stick if I did that.
    WAtundra4x4 and gosolo like this.
  2. Sep 3, 2021 at 9:03 PM
    #4712
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    They still allow backyard fires 3’ in diameter and less and no more than 2’ high.
    https://tvfr.maps.arcgis.com/apps/i...999e911876c5&center=-122.9148,45.486&level=11
    I always spray it with water for about 20 minutes to be sure it was out cold before we come inside.
  3. Sep 4, 2021 at 7:59 AM
    #4713
    Blue Thunder
    Washington
    It is wood pellet fire pit. I’ve had a chub for a Solo stove for years, but don’t have (and don’t want) a giant pile of wood to feed it. I found this and decided to give it a try. It has the same secondary burner system so the output is nearly smokeless.
    Drop in a 40lb bag of pellets and stuff a few fire starters in. Then just wait.
    After 30min4F39908C-E453-4F25-AF8A-FD35F3A674CB.jpgThen you get about 60min of beautiful tall flame103ECF50-CF2C-4927-B747-5569796AFB2D.jpg
    You can see the secondary burn system feeding air into the burn chamber. 7C867E4A-42A4-48BB-8128-CF038B008F4E.jpgAfter an hour or so, the initial burn is complete and the fire dies back. But you are left with a cool blue flameF8128886-1338-411B-8BD8-19B4C96C1561.jpgWe started at 7:30 and it was still going at 10:45. Not as hot but still plenty warmB1BB552E-5475-45DD-8370-BDA5B9934477.jpg
    It is a pretty slick system. I like keeping a few 40lb bags of pellets in my garage and not messing with a pile of wood. The one drawback is if you want to add more pellets. Throwing more than a few cups in at once ruins the burn cycle and the smoke is epic. Then suddenly the fire catches again and things are good.
    Going to experiment this weekend with regular wood (it “should” work) and also dumping a second 40lb bag on top of the burned-down pellets to see how long it takes to refire (prob 30-45min).
    gosolo, jewsNbrews, Kratos and 3 others like this.
  4. Sep 4, 2021 at 11:30 AM
    #4714
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    Leaked photo's of the new Tundra in the 2022 thread, makes me very happy I decided to go with the '21.
  5. Sep 4, 2021 at 12:11 PM
    #4715
    Dsptundra
    Austin TX Area
    I agree. Is it just me or does the front end looker overly long? Might be the color, not a fan of red at all.
  6. Sep 4, 2021 at 12:13 PM
    #4716
    Kratos
    Kratos Woof
    The front end, the back door window, integrated rear bumper. Bleah.
    jewsNbrews likes this.
  7. Sep 4, 2021 at 12:15 PM
    #4717
    Dsptundra
    Austin TX Area
    Based on the bed space behind the rear door and the rear wheel I think that is a double cab, not a crew max. Not sure but that is what it looks like with the shorter back door.
    Edit: Found the crew max photo as well by looking through the thread more.
  8. Sep 4, 2021 at 12:19 PM
    #4718
    Kratos
    Kratos Woof
    RCI has a 15% off sale, and I really like their sliders but they will only deliver to a dock.
    jewsNbrews and Blue Thunder like this.
  9. Sep 4, 2021 at 12:22 PM
    #4719
    Blue Thunder
    Washington
    Road trip!
    jewsNbrews and Kratos[QUOTED] like this.
  10. Sep 4, 2021 at 12:24 PM
    #4720
    Dsptundra
    Austin TX Area
    Can you pick up at the freight company’s depot?
    Edit: Their site lets you add residential with lift gate service for only $75.
  11. Sep 4, 2021 at 12:38 PM
    #4721
    Kratos
    Kratos Woof
    I was wrong, they will deliver but it's an extra $75 for a truck with a lift gate.
  12. Sep 4, 2021 at 1:52 PM
    #4722
    Kratos
    Kratos Woof
    So what do you guys think of how these attach? Seems very beefy and solid, but is it overkill (weight)?
  13. Sep 4, 2021 at 3:00 PM
    #4723
    Blue Thunder
    Washington
    They are all heavy. Overkill is a matter of perspective.
  14. Sep 4, 2021 at 3:10 PM
    #4724
    Kratos
    Kratos Woof
    $363 Shipping = Nut Punch
  15. Sep 4, 2021 at 3:16 PM
    #4725
    Blue Thunder
    Washington
    Think the brand that @jewsNbrews recommended are made in ID. Road trip away
    jewsNbrews and Kratos like this.
  16. Sep 4, 2021 at 3:30 PM
    #4726
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I believe the WKOR are from Utah. Victory is in Michigan.
    Blue Thunder[QUOTED] likes this.
  17. Sep 4, 2021 at 3:47 PM
    #4727
    Blue Thunder
    Washington
    Hmmm. I thought there was one company in ID that a lot of guys used. Darn memory
    NWPirate and jewsNbrews[QUOTED] like this.
  18. Sep 4, 2021 at 3:50 PM
    #4728
    Kratos
    Kratos Woof
    On their website WKOR has a contact address in CA.
  19. Sep 4, 2021 at 3:50 PM
    #4729
    Kratos
    Kratos Woof
    Just wait a few years....
  20. Sep 4, 2021 at 3:50 PM
    #4730
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    Went out glassing and for early archery 2pt only.
  21. Sep 4, 2021 at 3:58 PM
    #4731
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    May bedrack is made near Boise Idaho.
  22. Sep 4, 2021 at 4:09 PM
    #4732
    Dsptundra
    Austin TX Area
    CBI is in Idaho.
  23. Sep 4, 2021 at 4:16 PM
    #4733
    Blue Thunder
    Washington
    Yep, that’s it! Thanks
  24. Sep 4, 2021 at 8:19 PM
    #4734
    NWPirate
    Zach
    WA
    Got to exercise 4Lo today heading up the West side of St. Helens. My girls did awesome on the hike, goats and elk were plentiful! :yes:
  25. Sep 4, 2021 at 8:30 PM
    #4735
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    CBI/Prinsu is down in Idaho Falls I think
    Blue Thunder[QUOTED] and gosolo like this.
  26. Sep 4, 2021 at 9:25 PM
    #4736
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
    Anyone ever hear or experience something like this? Only 250 miles and it sounds like the noise is coming from the driveline.
    https://youtu.be/1TWiilbixPg
  27. Sep 5, 2021 at 2:20 AM
    #4737
    Blue Thunder
    Washington
    That’s something new. Crazy noise. Not directly related to speed or engine rpm…but close. I have zero ideas on that one.
    Kratos likes this.
  28. Sep 5, 2021 at 2:47 AM
    #4738
    Dsptundra
    Austin TX Area
    Sounds like a dealer visit to me. No idea what that is.
  29. Sep 5, 2021 at 6:56 AM
    #4739
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Yeah I found a thread on this forum with a guy who says he had the exact same noise on his 21 with 600 miles. Says his ended up being the dust shield on the rear differential. I'm going to spray it today and see if that's it.
    250 miles on the odometer and needing a dealer visit isn't the greatest feeling.
    Blue Thunder and Leo's first like this.
  30. Sep 5, 2021 at 7:04 AM
    #4740
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Although I'm wondering if I should even spray anything on it. Don't want the dealership saying WD or PB caused it...
    WAtundra4x4 likes this.
