North Idaho New Member
Discussion in 'New Member Introductions' started by SteveIdahoTundra, May 11, 2018.
  1. May 11, 2018 at 10:50 AM
    SteveIdahoTundra
    SteveIdahoTundra [OP] New Member
    2018 SR5 TRD Magnetic Grey
    AMP Power Steps
    Hi Everyone,
    I am new to the Tundra community and have already benefited from this forum. I had a AMP PowerStep installed by local dealer, but a glitch popped up with the passenger side step. It has a mind of its own and cycles at odd times while driving or sitting. Dealer had AMP send a new module, but no luck as the cycling continues. Called AMP and General responce was that the 2018 Tundra wiring for factory alarm system may be the problem.
    I found a great thread with detailed photos this website. I opened the kick panel and found the two hard wired wires were reversed. After switching them, I am waiting for the outcome over the next several days. So far there are no fantum cycling events, but it is early. Local dealer appointment is in a week (they are busy...) and by then will know if the reversed wiring caused the step cycling problem.
  2. May 11, 2018 at 10:51 AM
    Welcome from Texas, let's see your ride
    jewsNbrews likes this.
  3. May 11, 2018 at 10:53 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Welcome from NC!! Cool truck.... wait where is it :boink::boink:
  4. May 11, 2018 at 10:54 AM
    Welcome from CO!...pic???
  5. May 11, 2018 at 10:56 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO
  6. May 11, 2018 at 10:57 AM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona.
  7. May 11, 2018 at 11:11 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
    GNTundra likes this.
  8. May 11, 2018 at 12:02 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Welcome! Come let us show you what you need next :evil: :spending:
  9. May 11, 2018 at 12:22 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  10. May 11, 2018 at 5:15 PM
    N PLUS 1
    N PLUS 1 New Member
    2018 Silver Sky Metallic Limited Crewmax TRD OR
    Welcome from the midwest!
  11. May 11, 2018 at 5:19 PM
    Welcome from CO.
  12. May 12, 2018 at 3:56 AM
    Welcome from Ohio!
  13. May 12, 2018 at 4:39 AM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    Welcome from NC
  14. May 12, 2018 at 6:59 AM
    Grumpy Uncle
    Pat
    CO
    Welcome from CO.
  15. May 12, 2018 at 8:22 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Welcome!
  16. May 12, 2018 at 8:26 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome from Ca.
  17. May 12, 2018 at 1:48 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Welcome from CA
  18. May 12, 2018 at 1:51 PM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    Welcome!
  19. May 12, 2018 at 2:49 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  20. Jun 2, 2018 at 7:40 AM
    SteveIdahoTundra
    AMP Power Steps
    Overdue update...on AMP Powerstep issues on my 2018 Tundra. After several visits to local dealer the right side step’s propensity to wildly extend and retract randomly, the step finally revealed it’s crazy actions while in the shop. Thus it was determined that a new wiring harness was needed. And during this change a broken wire in the old harness was discovered. The break was intermittently connecting and triggering the step repeatedly and intermittently. Solved. Finally. I also understand AMP has changed installation instructions a number of times as witnessed by each newly received set by the dealer.
  21. Jun 2, 2018 at 11:47 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I'm a little late to the party but welcome!
    15whtrd likes this.
