NorCal spotted and BS Thread
Discussion in 'California' started by dcsleeper408, Dec 15, 2017.
  1. Dec 5, 2018 at 7:35 PM
    #2791
    DMathys
    DMathys New Member
    Single.
    831Tun likes this.
  2. Dec 5, 2018 at 7:56 PM
    #2792
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  3. Dec 5, 2018 at 8:12 PM
    #2793
    DMathys
    DMathys New Member
    Unless I'm reading the pic wrong, That's how I had it the 1st time. Tried both 12v switch and 12v constant feeding the switch. Neither worked.20181205_201017.jpg
    831Tun and dcsleeper408[OP] like this.
  4. Dec 5, 2018 at 8:14 PM
    #2794
    DMathys
    DMathys New Member
    Also thanks for the help. Its much appreciated.
  5. Dec 5, 2018 at 8:24 PM
    #2795
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    This looks good. Feed the switch from the fuse box. Here's the available ignition circuit fuse location. 5 amp oughta suffice.
  6. Dec 5, 2018 at 8:29 PM
    #2796
    DMathys
    DMathys New Member
    I did and it didn't work. Also tried it straight to the battery, nothing. I thought maybe it was under pressure and the pressure switch was keeping it off so I hooked the airhose up and nothing.
    That's when I began making multiple different harness setups.
  7. Dec 5, 2018 at 8:53 PM
    #2797
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  8. Dec 5, 2018 at 8:54 PM
    #2798
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Sorry I haven’t hooked up an arb yet so I would have to study the wiring first. Warren got you it looks like it.
  9. Dec 5, 2018 at 8:57 PM
    #2799
    DMathys
    DMathys New Member
    Yeah the factory harness/instructions. Too many extra connections and wires, that's why I figured I could make my own, looked simple. Granted, a couple hours into the project I realized I had no idea what I was doing....
    dcsleeper408[OP] likes this.
  10. Dec 5, 2018 at 8:59 PM
    #2800
    DMathys
    DMathys New Member
    I might mess with it again this weekend. As long as my truck doesn't burn down between now and then....
    Again, appreciate the help.
    Sunnier, 831Tun and dcsleeper408[OP] like this.
  11. Dec 5, 2018 at 9:00 PM
    #2801
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    So, the drawing I did is the ARB harness w/o the extra stuff.
    joonbug and dcsleeper408[OP] like this.
  12. Dec 5, 2018 at 9:01 PM
    #2802
    BlueBottle
    '16 Platinum 4x4
    See fine print
    831Tun likes this.
  13. Dec 5, 2018 at 9:03 PM
    #2803
    DMathys
    DMathys New Member
    That's how I built the original harness. I thought it would work but it didn't. Maybe I had a bad solder joint or something, will make another the same way when I get around to it.
  14. Dec 5, 2018 at 9:04 PM
    #2804
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Maybe a bad connection or reversed something at the relay?
  15. Dec 5, 2018 at 9:07 PM
    #2805
    DMathys
    DMathys New Member
    Maybe. Even though it might not be 100% correct, after messing with it for 5 hours the relay, pressure switch and compressor were all working. Figured I needed to stop before I tried to wire it up with an axe.
    831Tun[QUOTED] likes this.
  16. Dec 6, 2018 at 2:21 PM
    #2806
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    joonbug, Sunnier and dcsleeper408[OP] like this.
  17. Dec 6, 2018 at 8:30 PM
    #2807
    dcsleeper408
    dcsleeper408 [OP] BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
  18. Dec 6, 2018 at 10:08 PM
    #2808
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Fess up. Who is this!
    joonbug, GodlessPro, Sunnier and 2 others like this.
  19. Dec 6, 2018 at 10:17 PM
    #2809
    Sunnier
    Sunny
    San Diego, CA
    Alright, it was me. :D
    joonbug, GodlessPro, sr5shark and 3 others like this.
  20. Dec 6, 2018 at 10:18 PM
    #2810
    BlueBottle
    '16 Platinum 4x4
    See fine print
    :facepalm:
  21. Dec 7, 2018 at 1:37 PM
    #2811
    Darren509
    Darren509 New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    Hello everyone. Going to take the kid to Donner before Christmas and just curious if need to bring chains or not? I have stock LTX tires. Thanks in advance
    GodlessPro likes this.
  22. Dec 7, 2018 at 1:50 PM
    #2812
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Not if you're 4x4.
  23. Dec 7, 2018 at 2:14 PM
    #2813
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Always good to have some on you, but you won’t need em. Have fun @Darren509
    joonbug, GodlessPro and TRD15559 like this.
  24. Dec 7, 2018 at 2:35 PM
    #2814
    Darren509
    Darren
    Dayton NV
    Thank you. So if you have 4wd you dont need them at all ?
    GodlessPro and 831Tun like this.
  25. Dec 7, 2018 at 2:57 PM
    #2815
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Usually, don't need 'em if your tires are M+S. But, in extreme conditions, (Like has never happened to me) they could possibly be required. Usually the road is closed before you would need chains.
  26. Dec 7, 2018 at 3:17 PM
    #2816
    GodlessPro
    Matthew
    NorCal
    http://dot.ca.gov/trafficops/trucks/chains.html
    You are supposed to carry chains even if you have 4WD and M+S tires. Caltrans and CHP might technically be allowed to check that you have them, but I've never heard of that happening, they are usually busy with trucks.
    You would be required to put chains on for R-3 conditions, but as Warren said the road would probably be closed before that happens.
  27. Dec 7, 2018 at 3:50 PM
    #2817
    Cemented
    Cemented Function over Form
    Manuel
    2017 Cement TRD Pro
    @GodlessPro is correct that technically you are supposed to carry some with you if chain controls are in place even if 4x4. But, I’ve never been asked or checked for them and have certainly never needed them over many years. Just flash them 4 fingers at the chain inspection spot and they will wave you through.
  28. Dec 7, 2018 at 5:47 PM
    #2818
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks Matt, I didn't know that technically I need to carry chains. I do carry a recovery chain;)
  29. Dec 7, 2018 at 6:02 PM
    #2819
    GodlessPro
    Matthew
    NorCal
    Don't tell anyone, but I don't have chains either.
  30. Dec 10, 2018 at 8:33 AM
    #2820
    GodlessPro
    Matthew
    NorCal
    Looking for a couple Sacramento area members to get together this Saturday for karting. Let me know if you are interested.
