Noob bed question (wait, that didn't sound right...)
Discussion in '2nd Gen Tundras (2007-2013)' started by mihallo, Apr 10, 2021.
  1. Apr 10, 2021 at 8:18 AM
    mihallo
    mihallo [OP] New Member
    Dubai, UAE
    2012 Silver Tundra SR5
    Hi all. A really silly noob question - how do you attach things to sidewalls of the bed? Screw things through the liner to metal sides? Or are there dedicated threaded places under the liner?
    There - used "noob", "bed" and "screw" all in one post ;)
    Cruiserpilot likes this.
  2. Apr 10, 2021 at 9:13 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
  3. Apr 10, 2021 at 9:17 AM
    mihallo
    Dubai, UAE
    Thanks. The hooks are good for putting a net - i do that to hold camping gear in place, but I what i meant is things like axe/shovel holders etc.
    Those rails - they look ok, but holy moly - 200 bucks...
  4. Apr 10, 2021 at 9:28 AM
    audiowize
    Paul B.
  5. Apr 10, 2021 at 9:40 AM
    mihallo
    Dubai, UAE
    That panel looks great! So what does it bolt onto? I see a number of bolts/screws holding it in place...
  6. Apr 10, 2021 at 9:47 AM
    audiowize
    Paul B.
    mihallo[OP] likes this.
  7. Apr 10, 2021 at 10:13 AM
    ezdog
    ezdog New Member
    Gateway To The West
    I install RivNuts where needed and then bolt in what I need too.
    There are also a few spots where there are hokes just waiting for them.
    I also use the threaded hokes fir the bed rail kit to hang strut, piece of cake!
  8. Apr 10, 2021 at 12:12 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    I just installed the victory 4x4 bed molle panel. Easy as can be. You already have the 6mm bolt holes in your bed.so it bolts to those holes. Two holes need to be drilled at the bottom bracket and you need a second person to help thread the bolt on from behind the tail light. Or you can just use some heavy duty self tapping bolts/screws
