Noise when starting up steep driveway
Discussion in '2.5 Gen Tundras (2014-2021)' started by kms2060, Mar 8, 2020.
  1. Mar 8, 2020 at 7:34 PM
    kms2060
    kms2060 [OP] New Member
    2019 tundra crewmax
    I recently noticed the following noise, two separate times, a month apart in my 2019 crewmax with 9k miles on it:
    Both times i was on a flat road/parking lot, and pulling up to a steep incline in order to continue to another road. Each time i approached the start of the incline slowly and eased the accelerator. Both times, as i began to give it more gas the truck barely moved at first, likely because i was feathering it, and then i hear a very light bang from underneath the truck before the truck begins to drive up. Im absolutely sure i never struck any objects or scraped the truck. The noise wasn’t loud and did not shake or shudder the truck but it sounded strange for sure. Im not sure if it was a gear slipping due to the slow approach and then the push up the incline or another transmission issue as ive never had this happen before.
    No other noises come after and no lights on the dash and no visible damage when looking under truck.
  2. Mar 9, 2020 at 8:32 PM
    Rbohno
    Rbohno New Member
    Rich
    NC
    2020 Tundra CrewMax Limited
    Icon stage 5,method 18 x 9, BFG KO2s, Bushwacker flares, tinted windows,Havoc HST running boards,Weatherguard slimline box, DSR1, JL Audio 900/5 amp, two 10W0 subs in a box, hertz centro in the front and Hertz Uno in back doors
    I get the same thing exactly on my 2020, I was thing it was coil spring or a suspension knock. It only does it when the truck has sat for a few minutes and then I hop in and give a little goose and hear the knock underneath.
  3. Mar 9, 2020 at 8:44 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    It could be the ABS self test. There are a bunch of threads on it around here if you want to read up.
  4. Mar 9, 2020 at 9:03 PM
    Rbohno
    Rbohno New Member
    Rich
    NC
    Thank You Sir !
  5. Mar 9, 2020 at 9:05 PM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    Another thing to check is the carrier bearing and bracket. My '07 DC made a clunk sound when down shifting, or changing drive angles. Though I thought it was more because of the mileage my '07 had, which was almost 200K. However, since you are well under warranty, you may want to have them check the bolts are torqued to spec on your carrier bearing, and drive line. Something to look at anyway. Now I haven't noticed it on my '14 CM so not sure if I am used to it, or it's a DC vs CM thing.
    Rbohno likes this.
  6. Mar 9, 2020 at 9:11 PM
    Rbohno
    Rbohno New Member
    Rich
    NC
    Thanks you as well
