Noise in engine
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Rax, Jan 9, 2020.
  1. Jan 9, 2020 at 1:21 PM
    Rax
    Rax [OP] New Member
    2017 tundra trd pro
    None
    Hey guys I have a 2017 toyota tundra trd pro and it's making a weird noise and I'm not sure what the problem is. The dealer says there is nothing wrong but that noise doesnt sound normal here is a link to the noise: https://youtu.be/OstKdbQN934
  2. Jan 9, 2020 at 1:22 PM
    Blueknights75
    Ron
    Clayton, NC
    Doesn’t sound right to me...
    Pinay and Rax[OP] like this.
  3. Jan 9, 2020 at 1:23 PM
    Rax
    Rax [OP] New Member
    2017 tundra trd pro
    None
    I've been twice to the dealer and they keep saying there is nothing wrong and its normal
  4. Jan 9, 2020 at 1:38 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    What rpm was that? And which side did you do the recording?
  5. Jan 9, 2020 at 1:42 PM
    Rax
    Rax [OP] New Member
    2017 tundra trd pro
    None
    That was at cold start and between 2 and 3 and you hear it on both sides but the recording was done on the driver's side
  6. Jan 9, 2020 at 1:53 PM
    SprinterAE86
    Ian
  7. Jan 9, 2020 at 1:59 PM
    Rax
    Rax [OP] New Member
    2017 tundra trd pro
    None
    Rica25 likes this.
  8. Jan 9, 2020 at 2:01 PM
    SprinterAE86
    Ian
    Tensioner bearing on the serpentine belt?
    Rax[OP] likes this.
  9. Jan 9, 2020 at 2:04 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    My 16 has a ticking sound sometimes. The 5.7 is a noisy engine.
  10. Jan 9, 2020 at 2:23 PM
    Rax
    Rax [OP] New Member
    2017 tundra trd pro
    None
    I will tell that to the dealer
  11. Jan 9, 2020 at 2:32 PM
    Blueknights75
    Ron
    Clayton, NC
    Start up a new truck at the dealer...my 5.7 does tick as well but does not sound like yours.
  12. Jan 9, 2020 at 2:33 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
  13. Jan 9, 2020 at 2:33 PM
    Blue4x2
    Blue4x2 New Member
    2007 SR5 Double Cab
    AMP power steps Corsa catback exhaust BHLM Toytec Boss Aluma series Leveling kit 295/60 Falken WildPeak AT3 20” XD Monsters II w/ 0 offset
    Rax[OP] likes this.
  14. Jan 9, 2020 at 2:49 PM
    Rax
    Rax [OP] New Member
    2017 tundra trd pro
    None
    Yeah it just started and the dealer cant find a problem with it
  15. Jan 9, 2020 at 3:40 PM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    FYI My engine never really sounded like that.
  16. Jan 9, 2020 at 3:53 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Man that noise is either a pinhole exhaust leak from a header gasket or something rotating. Is there any debris stuck around any pulley? A piece of tape or something?
    Pinay likes this.
  17. Jan 9, 2020 at 4:05 PM
    Rax
    Rax [OP] New Member
    2017 tundra trd pro
    None
    I'm not sure to be honest the dealer has it again I want to see what they tell me this time but that noise is strong and they are saying it's fine which I know for a fact that noise isn't fine
  18. Jan 9, 2020 at 4:40 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    It sounds very different than our loud noises that are normal
  19. Jan 10, 2020 at 3:50 AM
    blanchard7684
    blanchard7684 New Member
    On the video it sounds like some sort of resonance. Like the engine is causing something else to vibrate. Is that video inside a garage or something? See if the sound is replicated with nothing else around.
  20. Jan 10, 2020 at 5:30 AM
    sundance
    sundance New Member
    Sounds like the air pump is running faster on your startup. Maybe related to conditions. The air pump does get noiser the colder it gets. If its louder at the passenger side then that's it.
  21. Jan 11, 2020 at 8:57 AM
    Rax
    Rax [OP] New Member
    2017 tundra trd pro
    None
    The
    I went to the dealer and said that there is nothing wrong with the car but that noise isn't normal so I'm going to call toyota care i cant figure out where the noise is coming from
  22. Jan 11, 2020 at 9:05 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I listened a couple days ago, its not a "super bad" type sound, meaning doesn't sound like deep internals of engine. More rotation of something rubbing or wearing out on the externals of engine, I'm hoping anyway. The dealer won't do anything with that sound - has to be a hammer like knock (rod bearing).
    Yeah have your own trusty mechanic check it out, they should be able to at least isolate the sound.
    Luck. : ^ )))
    Hbjeff likes this.
  23. Apr 5, 2024 at 9:55 PM
    PKL92
    PKL92 New Member
    Did you ever find out the issue to this sound? My is making the exact sound.
    2mchfun and OHwendTrd like this.
  24. Apr 5, 2024 at 10:13 PM
    2mchfun
    Remove the belt and then start up. That will help you isolate it.
    yakeng likes this.
  25. Apr 5, 2024 at 10:15 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Well now I’m invested in a 4 year old thread and there’s no closure.
    Leo's first, yakeng and 2mchfun like this.
  26. Apr 5, 2024 at 10:16 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    sounds like a bad breakup. free hugs from @hagrid
  27. Apr 5, 2024 at 10:22 PM
    2mchfun
    Welcome from OKC!
    When you get it figured out please post your findings for the next person in need. TIA!
  28. Apr 15, 2024 at 3:06 PM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    Sounds like a bad bearing to me, but these recordings are hard to diagnose. Removing the belt is a good idea.
  29. Apr 15, 2024 at 6:09 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Ex-squeaze me?
    Ass, grass, or gas. Everyone pays for Spraynard's tender affections.
    OHwendTrd[QUOTED] likes this.
  30. Apr 15, 2024 at 7:06 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Hagrid the hooker.
