No windshield rain channel
Discussion in '2.5 Gen Tundras (2014-2021)' started by TTund16, Apr 21, 2017.
  1. Apr 21, 2017 at 1:49 AM
    TTund16
    TTund16 [OP] New Member
    When it is raining relatively good (not a mist) the wipers push the water right into the driver's side window near the mirror ... if it is on and off rain and dusty, it gets muddy and dries off on the side window!
    This doesn't happen in my Tacoma so I looked and noticed that the Tacoma has a raised gasket (maybe 1/8" or more) on the sides of the windshield and provides a rain channel and water cleared by the wiper goes up on top of the car and away from the window! This rain channel thing was listed as a part of outdoor or off-road package in my Tacoma. it keeps water off of the side windows and instead channels it up and over the roof and also if the windows are cracked, the water doesn't come in.
    Tundra gasket lays flat compare to Tacoma.
    is there a Tundra outdoor package or do the Platinum or 1974 models have a raised gasket?
    also I know there are side window shades/deflectors but do they block this water from coming in. The deflectors don't go all the way down and I see water coming from near or above the mirror area, not sure if the deflectors go that low or block the water before buying one.
    btw, is it too hard to swap engines between Tundra and Tacoma? :rain:
  2. Apr 21, 2017 at 3:17 AM
    chphilo
    chphilo Tundra addict
    Western PA
    By swapping engines, you mean putting Tundra engine in a Tacoma, right? There have been a number of people who were interested, but I have not read of single success. I am sure with deep enough pocket, anything is possible.
    I have window visor and have had no problem that you describe. The visor comes down just above the mirrors as can be seen here.
    TTund16[OP] and NewImprovedRon like this.
  3. Apr 21, 2017 at 3:21 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    Never had this problem, if it helps I don't have a pic but the weathertech visors go all the way down past mirror
  4. Apr 21, 2017 at 4:17 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've noticed the way the water seems to hang there on the side window too. Haven't thought much on what, if anything to do about it though....
  5. Apr 21, 2017 at 9:53 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Mine does that as well, especially when I use the windshield washer. I take it as an excuse to go faster so the wind drys it. Vent visors are probably your only other option.
