No trailer light power to plug in
Discussion in 'Towing & Hauling' started by Onefunfisherman, Apr 18, 2021.
  1. Apr 18, 2021 at 11:41 AM
    Onefunfisherman
    Onefunfisherman [OP] New Member
    Rick
    2001 Toyota Tundra
    Need help with trailer light circuit on 2001 Tundra I can’t find any bad wire connections or problems noticeable and not sure on fuse location in engine compartment fuse box. I have heard of a sensor located ? All help is greatly appreciated !I do not have the wiring change over kit as sold by auto parts it’s a direct plug in to factory wiring
  2. Apr 18, 2021 at 12:30 PM
    jrquist
    jrquist Canon Shooter
    Carlton, Minnesota
    2020 Tundra Sport Super Bright White
    More info would be helpful. Running lights, turn signals or nothing works at all. 7 pin or 4 pin connector for the trailer plug ? If nothing works at all it may not be a fuse but a missing ground.
  3. Apr 18, 2021 at 12:53 PM
    Onefunfisherman
    Rick
    2001 Toyota Tundra
    Thank you for your reply,I do have all lights on vehicle just no power to my 7 pin receptacle hadn’t used the trailer plug for a year and did check ground and receptacles with test light not a thing ? Last used and never a problem ?
  4. Apr 19, 2021 at 2:47 PM
    jrquist
    Carlton, Minnesota
    Now I would start checking fuses. My best guess its located under the hood vs inside the truck. Not sure what the label would be on the fuse box cover but maybe pull all of the 15 and 20 amp fuses first. Troubleshooting electrical issues is always a pain. Good luck and I hope its the first fuse you pull !
  5. Apr 19, 2021 at 3:37 PM
    Onefunfisherman
    Rick
    2001 Toyota Tundra
    Thanks for your help,I did check all the fuses and everything looks good,I used contact cleaner on all the plug ins and coated the contacts with dielectric grease no change
  6. Apr 19, 2021 at 4:05 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    My first gen knowledge is Tacoma not Tundra but just want to ask...
    Isn’t the trailer power wire on a 2001 switched? Are you testing with the key/engine on?
