No reverse
Discussion in 'General Tundra Discussion' started by Steveklssr9, Feb 28, 2021.
  1. Feb 28, 2021 at 5:21 PM
    Steveklssr9
    Steveklssr9 [OP] New Member
    Hi my truck has no reverse. Ok heres the deal. I replaced the pressure control solenoid it cost me $200.00. I refilled the 5 Quarts that the pan holds with Amsoil Synthetic. Before replacing this solenoid I got codes saying that solenoid D And B are bad. I replaced Solenoid D which was the pressure control solenoid. I now no longer get the codes. They have actually come on twice but before theyd come on ever half hour. So now I have no reverse. This started not long after I got the codes for the transmission.i did find a little pin inside trasmission I think that is where it came from because I had the oil pan sitting on my tailgate and when cleaning up found the pin in the snow next to where the pan had been sitting so I'm thinking when I wiped the old oil out it got stuck to the paper towel and that's where it came from. So no reverse! When I put it in reverse before the truck would just roll but now it just sits there but won't rool but won't back up! Could it be the torque converter by any chance? Could it be another Solenoid? I will list all of the codes I've gotten and erased. Oh BTW it would always flash 4Lo when the codes came on too. So codes I got today first day driving after I replaced this stuff: P0977 red code Fault. P0705 GREEN CODE Pending Fault. P0705-powertrain Trasmission Range Sensor circuit Malfunction (PRNDL Input) Red code. Which means current fault. P0756 green code Shift solenoid B Performance or stuck off. P2714 Pressure control Solenoid D Performance or stuck off.
  2. Feb 28, 2021 at 5:39 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Picture of pin with object of known size (coin) for reference. Maybe someone else who's done similar work will recognize whether it belongs in the transmission or not. Attached is the procedure for checking the transmission fluid level, they're kinda sensitive to that.
  3. Feb 28, 2021 at 5:40 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  4. Feb 28, 2021 at 6:03 PM
    Steveklssr9
    Ok I attached a file thankyou. I was wondering why people say you have to put the thermostat in neutral if you actually had to why is this?
  5. Feb 28, 2021 at 6:09 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    LOL, it's kind of tricky to know what size the object is, but maybe someone will recognize it.
    Opening the thermostat for the transmission cooler will allow the fluid in the entire system (including the cooler) to get to the prescribed temperature that is needed to get the level set correctly.
  6. Feb 28, 2021 at 6:14 PM
    Nick T
    Nick T New Member
    Nick
    What year and engine ?
    Wynnded likes this.
  7. Oct 14, 2022 at 7:11 AM
    Rcsb2012
    Rcsb2012 New Member
    Found a solution to this? I got p0756 and no reverse as well. Car almost in limp mode.
  8. Jan 9, 2023 at 11:03 AM
    alainaube90
    alainaube90 New Member
    The pin you found is a solenoid lock on your trans valve bank and Had same issue with my parts truck a 2008 5.7 ab60f transmission stuck forward no park ,neutral or reverse was C1 clutch was burnt welded together my driving trulck has the same issue will check if its the same C1 clutch that is burn't or either C2 or C4 will confirm after removal hope this helps others there is not much about this specific problem online and i had to have 2 lucky me lol...20230108_210320.jpg 20230108_210312.jpg 20230108_220331.jpg
    Wynnded likes this.
  9. Jan 11, 2023 at 8:13 AM
    alainaube90
    Here are the results of my 2007 Tundra AB60F TransmissionNo codes stuck forward in P,N,D and no Reverse. Burn't C1 Forward clutch.20230110_191152.jpg ACH]20230110_191345.jpg
    Wynnded likes this.
  10. Jan 11, 2023 at 8:18 AM
    …op only posted once in 2/2021 and hasnt been back
    alainaube90 likes this.
