No more volume on OEM radio?
Discussion in 'Audio & Video' started by DarknessReigns, Apr 29, 2020.
  1. Apr 29, 2020 at 6:31 AM
    DarknessReigns
    DarknessReigns [OP] New Member
    Hey guy's,
    I just installed a full system upgrade but kept the OEM radio.
    It was working fine for about a week and this morning when i started the truck, no more volume.
    The radio turns on, I see the screen, the bluetooth music is diplayed, but when I twist volume up or down, there is nothing that comes up on the screen and no sound.
    The steering wheel controls also don't have any affect on this.
    I heard that these OEM JBL radio's shit the bed every now and then.. Is this the symptoms that others have had as well?
  2. Apr 29, 2020 at 6:44 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    What did you install?
  3. Apr 29, 2020 at 6:47 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Did you lose power to your amp? Check your fuses.
  4. Apr 29, 2020 at 6:49 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    make sure the volume is up on your phone.
    texasrho83 likes this.
  5. Apr 29, 2020 at 7:11 AM
    DarknessReigns
    It's not volume on the phone. Even FM radio, CD etc.. All sources are the same.
    I installed two amps, all new door components, dash speakers, a sub box, a rockford DSR1.
    Everything worked for a week and this morning, the radio doesnt show volume or allow bass, treble, mid and fader adjustments.
    I unplugged the truck battery for 5 mins and re-connected it and the volume is now back and sound is working again. However the settings for (front - rear, bass, treble, mid) is not adjustable anymore.
    This OEM radio is just so so bad...
    Any ideas?
    Thought the close to 6K I spent in audio upgrades was going to be enough, but it's starting to look like no matter what, I will have to change the factory radio :/
  6. Apr 29, 2020 at 7:38 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I don't have the JBL system so can't confirm this, but I've heard that the factory amp did a lot of that processing. Not sure why it would look fine for a week and then shit the bed though if that were the case. I'd pony up a little more money and dump the factory HU.
  7. Apr 29, 2020 at 8:41 AM
    Danimal86
    Daniel
    Sacramento, CA
    jebus......you have a parts list of everything you installed?
    since its across all the sources, i would think somethings up with the dsr1. did you do the install yourself?
  8. Apr 29, 2020 at 8:58 AM
    AZBoatHauler
    So.Arizona
    Trying to figure how you can spend $6k without touching the crappy HU...
    Danman34 and texasrho83 like this.
  9. Apr 29, 2020 at 8:58 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  10. Apr 29, 2020 at 9:10 AM
    Danimal86
    Daniel
    Sacramento, CA
    Nothing wrong with wanting to keep the stock head unit. If the OP wants to get rid of his stock head unit, he's only out the cost of the dsr1. Not bad
  11. Apr 29, 2020 at 9:17 AM
    AZBoatHauler
    So.Arizona
    It’s more of an accounting question than a philosophical debate. $6k... that’d be $1k in each door $1k for amp and $1k for subs?? That must be one hell of a system.
    Tundyfundy likes this.
  12. Apr 29, 2020 at 9:18 AM
    degs
    degs New Member
    2020 MGM Crewmax
    following
  13. Apr 29, 2020 at 9:19 AM
    DarknessReigns
    CAD, not USD,
    Tripple sound proofed entire cabin + closed cell foam, top end cables, Focal gear, JL Stealthbox, custom made Steel amp racks etc.
    Not sure why you find it funny.
  14. Apr 29, 2020 at 9:20 AM
    Danimal86
    Daniel
    Sacramento, CA
    Probably had a shop do the install. For a full system overhaul, i bet it would cost $1500 in labor
  15. Apr 29, 2020 at 9:21 AM
    Danimal86
    Daniel
    Sacramento, CA
    Be careful with this. I've heard this can be the source of some issues with sound quality (not the issue you are having now).
  16. Apr 29, 2020 at 9:37 AM
    DarknessReigns
    Thanks for the heads up, I'll do some research.
  17. Apr 29, 2020 at 9:43 AM
    AZBoatHauler
    So.Arizona
    I don’t know enough about the JBL system to be helpful but if I were you I’d get in touch with James Taylor as he is the resident expert on Tundra audio. I’d bet he has heard of this issue...
    @james@tech12volts
    Email-
    tech12volt@gmail.com
  18. Apr 29, 2020 at 9:47 AM
    AZBoatHauler
    So.Arizona
    This explains a lot. $6k CAD is roughly $4.3k USD.
    Tundyfundy and texasrho83 like this.
  19. Apr 29, 2020 at 9:55 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Still a good amount of coin to put into an audio overhaul!
  20. Apr 29, 2020 at 11:54 AM
    AZBoatHauler
    So.Arizona
    My understanding is all of these functions are controlled by the stock JBL amp system so if you removed the stock amp it would make sense you would lose all these functions. Not sure about the volume.
  21. Apr 29, 2020 at 11:57 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Snap a pic of the controls being inoperable on the HU plz
  22. Apr 29, 2020 at 11:58 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    mine are still there.. so something is off
    AZBoatHauler[QUOTED] likes this.
  23. Apr 29, 2020 at 11:59 AM
    AZBoatHauler
    So.Arizona
    I know a lot of people place a new amp downstream of the JBL amp to try and get everything to play nice... Are you sure your stock amp has been removed?
  24. Apr 29, 2020 at 12:03 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Yup, did the install myself with a dsr1. Amp is sitting in my toolbox.
    my question is: is this true across all sources since I believe each source has different programmable bass/treble/etc.
  25. Apr 29, 2020 at 12:24 PM
    DarknessReigns
    No that isn't the case.
    Everything worked for a week. All the factory radio settings worked, treble, bass etc..
    I played with them to fine tune the sound.
  26. Apr 29, 2020 at 12:41 PM
    DarknessReigns
    So quick update... Went out in the truck turned the key and all settings work again.
    Mind blown.. I think this HU has a mind of it's own. If this repeats itself I may just bite the bullet and replace it.
  27. Apr 29, 2020 at 12:53 PM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    I have the JBL HU but aftermarket DSR-1/AMP/Speakers. About 10% if the time when I turn the truck on everything starts up as expected - amp has power, HU is up and running but no sound. When this happens there's no number displaced for the volume on the HU so I know it's the HU. If I restart the truck everything is fine.
    ToyoMafia likes this.
  28. Apr 29, 2020 at 2:09 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    The truck is a 2020? Take it to the dealer? If they give you sh*t because you changed the amp tell them to prove that it is the cause. You could just throw the stock amp back in and see if you get signal unless you cut the factory harnesses which in that case you shouldn’t have done that.
  29. Apr 29, 2020 at 2:13 PM
    ToyoMafia
    Magic carpet.
    If you can swap the amp to test factory amp you will know about the HU. If the systems sound is back then I really think there is an issue with the Dsr1 I will check the status light on mine and confirm. Can you get to the Dsr1?
    Mater likes this.
  30. Apr 29, 2020 at 2:38 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    I would leave everything flat on the HU and make all your adjustments in the Perfect Tune app. The EQ in the DSR1 can do everything and more with regard to bass, treble, time alignment....
