No lift help needed
Discussion in 'Suspension' started by Toyfan2, Feb 2, 2019.
  1. Feb 3, 2019 at 10:41 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    P
    Would be a fantastic option for you! If you want them and could cancel your other order that would work great. 5100’s performance will be above the 4600’s but they would still be excellent compared to worn out ones.
    Toyfan2[OP] likes this.
  2. Feb 3, 2019 at 10:55 AM
    Toyfan2
    Toyfan2 [OP] New Member
    FL
    would a Gen 3 shock set fit a Gen 2 Tundra?
    kparrow likes this.
  3. Feb 3, 2019 at 11:02 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Yes.
  4. Feb 3, 2019 at 11:37 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Yes, gen 2 and gen 3 mechanically are the same. Same frame, suspension, motor. Just look different
  5. Feb 3, 2019 at 11:38 AM
    15whtrd
    15whtrd Mr. Blonde
    Except for a few discrepancies. Transfer case is different as well as the airbox. A few different tweaks here and there but suspension etc. like you said is the same.
    kparrow[QUOTED] likes this.
  6. Feb 3, 2019 at 11:44 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    100% True! Switched to a Borg Warner t-case if I remember right. Didn’t know the air box changed, learn something new everyday!:thumbsup:
    15whtrd[QUOTED] likes this.
  7. Feb 3, 2019 at 11:54 AM
    15whtrd
    15whtrd Mr. Blonde
    Yeah me too. I knew they were different part numbers from when I had to order a air filter. Just recently in a thread someone showed a picture of both generations air boxes side-by-side. Second GEN air box is bigger and in my opinion more desirable now.
  8. Feb 4, 2019 at 10:50 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    OP, end up getting the OEM TRD takeoffs?
  9. Feb 4, 2019 at 11:23 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Trucks are starting to come from the factory with a 2" level option so between that and everything I've read, it doesn't hurt the truck. I'm still on the fence between the 5100 or 6112 but these are your best options.
    Toyfan2[QUOTED][OP] likes this.
  10. Feb 4, 2019 at 3:15 PM
    Toyfan2
    FL
    I'm waiting for him to send me a shipping estimate. By the way I'm not sure why My user name has an OP behind it, at least it's not FNG...
  11. Feb 4, 2019 at 4:13 PM
    jwl019
    jwl019 New Member
    N.E., Louisiana
    2016 Tundra CM 4wd TSS
    Tacotunes SQ1 package Bilstein 5100's @ 1.5" plus 2 shims Toyotec Shackles at 1" Firestone Ride Rite Airbags SCS SR8's 285/70r18 Nitto Ridge Grappler's Bed Cover Tow Mirrors Windows Tinted Window Visors Weathertech Floor Mats
    OP = original poster or something along those lines would be my guess since you started the thread
  12. Feb 4, 2019 at 4:38 PM
    Toyfan2
    FL
    Duh, That makes sense. I'm still a newbie.
    Thanks jwl.
  13. Feb 4, 2019 at 4:43 PM
    jwl019
    jwl019 New Member
    N.E., Louisiana
    Lol, I am not too far behind you on being a newbie.
    If you don't work out a deal on the other stock ones, I will be pulling off the black stock shocks to install 5100's really soon. I have 30k miles on my '16 TSS. Ordered the kit this weekend, so once it arrives I will be installing it this weekend or next.
