No effing trans cooler?! I'm out Toyota
Discussion in '2.5 Gen Tundras (2014-2021)' started by Berettafan, Nov 14, 2020.
  1. Jan 10, 2021 at 8:49 AM
    #601
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    The post is about 300K miles is nice but towing every day statement is useless. What reasonable person would tow EVERYDAY with a 1/2 ton unless its a 2Klb landscaping trailer staying under 45 mph in neighborhood. Anyone that tows that much would use an HD Truck and make real money. Time is time, no more time to tow 15000lbs than 15,00lbs but 15,000lbs pays much better....
  2. Jan 10, 2021 at 8:50 AM
    #602
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Sorry brother but I think you miss understood what I was saying. I DO NOT believe that the lack of a auxiliary transmission cooler is going to cause any problems at all. Maybe under severe abuse but extremely rare none the less. I was simply stating the those who disagree with my thinking chalk it up a massive reliability issue (definitely not me).
    And for those that feel that way should speak with a engineer before making that assumption; that a lack of an auxiliary cooler is going to kill their truck...regardless of knowledge or expertise.
  3. Jan 10, 2021 at 8:53 AM
    #603
    blanchard7684
    blanchard7684 New Member
    I don't think reasonable is the issue. towing or not 300k miles in two years is simply effing nuts.
    Saltyhero13 likes this.
  4. Jan 10, 2021 at 8:54 AM
    #604
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Sounds like too many of you continue to compare the 1/2 ton Tundra ,to 3/4 ton others when it comes to towing , just like it said one of other posts on here where someone said putting a slide in camper, even the basic,stripped down one will max out and with full gear , over load the Tundra. But alot still do it , and it handles the call, or some pulling 30 ft loaded campers, still handles the call. Long story is ,we all push or Tundras because of what they are , and who we are, and from all the reading on here sounds like no matter what , you aren't going to beat the TUNDRA.
  5. Jan 10, 2021 at 9:03 AM
    #605
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    I agree with Bucks04 and IMO prior to 2012? Tundra was in line with 3/4ton truck. Not today. I put the cooler on, I learned many times a rebuilt transmission never ever shifts the same as one that was never rebuilt. Doesn't downshift the same, slams into gear blah blah blah. Since I have a transmission shift fetish, i installed a cooler and I do tow at times 500-600 miles at a time 6klbs at 75 mph. Bottom line is all 2019 and newer still under warranty, its buying one used out of warranty where the out of warranty buyer may have to pay for the transmission. Then again the new model will be out and and the current will slowly be forgotten with any issues it may have had.
    I just shocked my F250 diesel kept the trans temp pinned at 195F surprised as cheap as Ford is and they are CHEAP they still used a cooler....
  6. Jan 10, 2021 at 9:11 AM
    #606
    Can dolphins read ur mind?
  7. Jan 10, 2021 at 9:26 AM
    #607
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I think they’re called water puppies
    GODZILLA, Sumo91, RainMan_PNW and 4 others like this.
  8. Jan 10, 2021 at 9:27 AM
    #608
  9. Jan 10, 2021 at 9:45 AM
    #609
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited *sold*
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    @Berettafan i think the wait and see approach is warranted here. Toyota doesn't do anything without it working well and if they do something and it doesn't work or lacks something to be desired they constantly make changes to improve. I'd take the wait and see approach on it
    FISHN43 and Cpl_Punishment like this.
  10. Jan 10, 2021 at 11:12 AM
    #610
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I decided to not wait and see. Seeing what some people’s temps were unloaded in the summer made me think I’d rather just add the cooler and get it over with. It’s a pretty simple install. Just follow the fluid check procedure properly.
    I think it’s great that he went 300k on a 2019+ towing with no ext cooler and no issues.
    But isn't 300k miles in 2 years a lot different than 300k miles over a span of 10-15 years? Hopefully I will fall into the latter category, and I wanted the lower temps that an external cooler w/ a thermostat provide.
    Bronzeback and Black Wolf like this.
  11. Jan 10, 2021 at 11:55 AM
    #611
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    I’m with you here. My thought is that Toyota wouldn’t sacrifice their excellent reputation of reliability and dependability for an approximately $1000 trans cooler just for the heck of it. I’m sure they've done their diligence in research before deciding to eliminate it. I’ll at least wait out my factory warranty before deciding to add one or not. By then there will be many non-cooler Tundras with real-world testing.
    WILLINH and Cpl_Punishment like this.
  12. Jan 10, 2021 at 11:57 AM
    #612
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    BWAAAAAHAHAHAHA!!!!!
  13. Jan 10, 2021 at 12:28 PM
    #613
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I thought those were otters.
    GODZILLA, JMB, WILLINH and 1 other person like this.
  14. Jan 10, 2021 at 12:49 PM
    #614
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    or Beavers....
    GODZILLA, RainMan_PNW and WILLINH like this.
  15. Jan 10, 2021 at 12:50 PM
    #615
    Saltyhero13
    Saltyhero13 Throbbing Member
    Yes. It's why they are always jabbing people's genitals with their snouts.
    GODZILLA, Sumo91, hagrid and 3 others like this.
  16. Jan 10, 2021 at 12:52 PM
    #616
    Squatting Pigeon
    Holden
    North Texas
    Water kittens and cats respectively
  17. Jan 10, 2021 at 1:57 PM
    #617
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Faaaa love paaaa...
  18. Jan 10, 2021 at 1:58 PM
    #618
    JMB
    Chesapeake, VA
    Are you sure? I thought otters are river weasels.
    GODZILLA likes this.
  19. Jan 10, 2021 at 2:08 PM
    #619
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    I'd like to know all of his maintenance...has he changed the transmission fluid and when, gear oil changed and when, etc
  20. Jan 10, 2021 at 2:09 PM
    #620
    Squatting Pigeon
    Holden
    North Texas
    Just oil changes according to the OP
    GODZILLA and Ronin73[QUOTED] like this.
  21. Jan 10, 2021 at 2:09 PM
    #621
    Squatting Pigeon
    Holden
    North Texas
    It’s a fine line :monocle:
    GODZILLA and JMB[QUOTED] like this.
  22. Jan 10, 2021 at 2:22 PM
    #622
    Bradleybb
    Bradleybb New Member
    Georgia
    2021 CM TRD OR
    Transmission cooler TRD REAR SWAY RCI front skid
    Vin# would show all maintenance
  23. Jan 10, 2021 at 2:28 PM
    #623
    Terndrerrr
    Music City
    6UR-FE
    Imagine the trans cooler cost them $700 more in parts than the thermostat-shaped spacer that is in there now. They sold 100,000 trucks in 2020. If they saved $700 in parts per truck, that is $70M in savings in 2020 alone.
    Now think about the drivers grab handle they deleted in what, 2014? Say they saved $50 in parts deleting the handle. That’s $5M in savings for 2020 alone. Same story for all the years prior since they deleted it.
    Of course they’ve added features since (CarPlay, safety sense, etc), but these features are a lot easier to spend $$ to R&D when you decide to delete something seemingly small or inconsequential or unnecessary from the truck.
    I hate to say it as a Toyota fan, but I agree with the others in this thread who do not see it as an engineering decision resulting from careful data analysis but rather as a cost-saving decision emerging from a boardroom.
    The transmission is the same as 2018. The fluid is the same. Nothing was done to offset the deletion, just a thermostat-shaped spacer added to seal off the thermostat port.
    Soooo, the way I see it: either they’re wrong now, or they were wrong before. The worship of the almighty Toyota engineer here is kind of weird. Just my two cents.:anonymous:
    tundraterrence likes this.
  24. Jan 10, 2021 at 2:30 PM
    #624
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Not if the owner did their own maintenance.
  25. Jan 10, 2021 at 2:41 PM
    #625
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Wow. We had a member here who changed his transmission fluid on a ‘19 I believe after a significant amount of towing. I don’t remember who it was. He sent a sample of the old fluid to Blackstone. The results indicated the fluid was fine. We have a ‘19 Tundra with almost 300,000 miles and lots of towing and the transmission is fine. Yet we still have people saying Toyota is cutting corners and ripping people off by deleting the cooler. I don’t care what any individual does with their truck. You can put several auxiliary coolers on it if you like, it’s your truck. But please stop criticizing Toyota in the process. They’ve earned the benefit of the doubt IMO.
  26. Jan 10, 2021 at 2:44 PM
    #626
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    You are talking about 300000 plus trucks sold since 2019 , I am pretty sure they though pretty good before removing the external cooler , just imagine the cost of lawsuits and recall they have to cover ...
    tttrdpro and Cpl_Punishment like this.
  27. Jan 10, 2021 at 2:50 PM
    #627
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Just because a change saves money doesn't mean it isn't backed by sound engineering judgment.
    GODZILLA, Saltyhero13 and tttrdpro like this.
  28. Jan 10, 2021 at 2:56 PM
    #628
    Terndrerrr
    Music City
    6UR-FE
    300k trucks sold without coolers at $700 savings each would be $210M saved. For perspective, Toyota was awarded $25M by Dana for the decade of faulty Tacoma frames Dana produced for them.
    Agreed. But are you then saying the engineers were wrong for years before?
    Edited to add: just because a change was made by Toyota doesn’t mean that change is correct.
    I say all this as a Toyota fan. I love my truck. I wouldn’t drive any other half ton. I’m just not convinced the decision to delete the cooler was made with longevity of the transmission in mind. Seems more a way to save a bit (or a lot, rather) of money as they R&D the new model.
  29. Jan 10, 2021 at 3:13 PM
    #629
    Jtundra81
    Joe
    are you saying that the number one company in the world known for its reliability would risk it all for 70M a year ??
    Cpl_Punishment and tttrdpro like this.
  30. Jan 10, 2021 at 3:36 PM
    #630
    Terndrerrr
    Music City
    6UR-FE
    I don’t think they’re “risking it all” with deleting this cooler. For most people, it’ll be fine. There’s a couple examples here that appear to be fine. That does not mean the decision was driven by engineering. And if it was, they have egg on their face for all the years beforehand where they said the truck needed it.
    Speaking of money: for perspective, Toyota was paid $25M by Dana for all those years of Tacoma frames prematurely rusting. Are you saying that pocketing $70M/yr for the last three years of an aging 14-yr model run of a truck that only sells better than Nissan is inconsequential?
    Again, I love my truck, and I am a Toyota fan. But like all companies out there, I don’t think every decision they make is the 100% best possible decision every time. I do think this decision was financially driven rather than engineering driven. I’m happy to be shown to be wrong. To me that would include showing me how the 2019+ transmission and/or cooling system is different since it no longer needs the ext cooler that these very same Toyota engineers said it needed for years prior.
