No driver seat back pocket? And what's this clip?
Discussion in '2.5 Gen Tundras (2014-2021)' started by HBdirtbag, Mar 19, 2017.
  1. Mar 19, 2017 at 1:48 PM
    HBdirtbag
    HBdirtbag [OP] New Member
    Walnut Creek, CA
    2017 limited cm
    Things I'm starting to notice now that I have a few hundred miles on the truck. No backseat pocket? Is this on all trucks or do the 1794 and platinum have them. Pretty mind boggled on this one as I've never seen a car without them that intended to have people in the back.
    Also, notice on the back driver seat this clip on both sides doesn't look like it was installed correctly, what is it?
  2. Mar 19, 2017 at 2:20 PM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    My 1794 CrewMax has pockets on the back of the seats. Don't know about those clips. Will have to check. Hopefully someone else will know what those are and if it's in correctly.
  3. Mar 19, 2017 at 3:23 PM
    Motor71
    Motor71 teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    Platinum has seat pockets.
  4. Mar 19, 2017 at 3:30 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    My impulse buy has fucked me again, lol
    Next your going to tell me the platinum seats have better thigh support to! (I'm about to put washers under my seat to raise the front up as I've got a back injury that kills me on long drives)
    I wonder what the reasoning to only put them on the passenger side was
  5. Mar 19, 2017 at 3:44 PM
    Tufftruck
    Tufftruck New Member
    2015 Bronze 1794
    My 1794 CM has the same clips with nothing attached. Looks identical to your picture. I don't know about "better" thigh support as I haven't driven anything to compare. Mine does have a separate switch that pumps up that area of the seat. I have major back issues too and it does help.
    HBdirtbag[OP] likes this.
  6. Mar 19, 2017 at 3:47 PM
    Motor71
    Rob
    New Jersey
    I can only assume that they feel if you need to reach for something you can only reach the other side and not behind your own chair
    HBdirtbag[QUOTED][OP] likes this.
  7. Mar 19, 2017 at 3:49 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    My platinum has seat back pockets.
  8. Mar 19, 2017 at 4:04 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    This is what you get for going to the grocery store and buying a truck instead, lol. Didn't even occur to me. Oh well.
    Cat3ILS and Krezz like this.
  9. Mar 19, 2017 at 4:06 PM
    Tufftruck
    2015 Bronze 1794
    Correction on the clip. I was looking at the wrong piece (that double hook thingy). The flat/clip with the white line shown in your picture just above the double hook thingy appears to be bent over onto itself. The top piece on mine goes straight up at 90 degrees (perpendicular) to the bottom piece and is attached up underneath where I can't see. It looks like yours just needs to be unfolded and attached.
    Cat3ILS and HBdirtbag[OP] like this.
  10. Mar 19, 2017 at 5:33 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Right on. It's like that on both sides and your description makes total sense
  11. Mar 19, 2017 at 8:52 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I wish i had a seat pocket behind the drivers seat especially since Toyota deleted the rear door pockets.
    2cID likes this.
  12. Mar 20, 2017 at 8:11 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    My '14 SR5 DC had no backseat pockets either, that was one of the things I made sure they put on when I got my custom leather seats.
  13. Mar 20, 2017 at 12:03 PM
    davesnothere
    davesnothere New Member
    Dave
    Down South, Texas
    2016 Tundra Limited 4x4 5.7ffv
    Pro Comp stage 2 6" lift- 20" XD Rockstars- 35" pro comp a/t sport- Hypertech Interceptor- 7" BA Muffler- 4.88 Yukon gears
    Man I was bummed to find out the little deletes they have done to the limited as well. I had a 07 limited and it was top of line before they made platinum and 1794, had both seats electric, power mirrors, and the back pocket. Traded in for my 16 and it didn't have any of that. Didn't even think to look as well it's a limited
  14. Mar 21, 2017 at 1:28 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I'm sure Toyota dropped that feature for "safety reasons",like the Driver's Side Grab Handle, Amber Flashers, Adjustable Console and Lights in the doors instead of Yugo-Like reflectors.:thumbsup:
  15. Mar 22, 2017 at 3:35 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    No powers mirrors on a Limited WTF?
  16. Mar 22, 2017 at 3:46 AM
    NickyF25
    NickyF25 New Member
    Nick
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    I'm guessing he meant it doesn't have power folding mirrors?
  17. Mar 22, 2017 at 6:48 AM
    chphilo
    chphilo Tundra addict
    Western PA
    The limited trim used to be the top dog during 2007-2009. When they introduced Platinum trim in 2010, their limited trim got pushed down. Now, the limited trim seems to be only slightly better than what SR5 used to be. With limited trim, they get the dual climate control which used to be standard in all Tundras back then, and so on.
  18. Mar 22, 2017 at 7:03 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    My 15' SR5 has pockets. Still not sure about that damn clip!!!
  19. Mar 22, 2017 at 3:13 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I think the clips hold the cables that run the extra thigh support on the platinum edition
  20. Mar 22, 2017 at 5:28 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Lol
  21. Mar 22, 2017 at 5:55 PM
    Tufftruck
    2015 Bronze 1794
    Since we're bashing, how about no lighted mirror controls on the dash. They're a bitch to find in the dark. No back seat storage is just plain rude as well.
    Batel likes this.
  22. Mar 22, 2017 at 8:02 PM
    Fishin1981
    Fishin1981 New Member
    2015 tundra limited crewmax
    Pop and lock, esp storage, access lorado, front tints
    I have a '15 limited. My '13 Tacoma limited had better features then my current truck. Should have held out for a platinum. Not even an upgraded sound system.
    tdosthp likes this.
  23. Mar 23, 2017 at 8:49 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    At least Tacomas have under and behind seat storage. No lighted mirror controls either. There are several switched not lit for some reason. Why the 4x4 is in other models but not Tacoma beats me. I think Toyota engineers are on drugs.
  24. Mar 24, 2017 at 11:49 AM
    Cat3ILS
    Cat3ILS The cheese goes on the bottom bun
    2014 platinum CrewMax 4x4 5.7L - white
    2.5 level, 285 Toyo OC, Or-Fab trans/cat skid, X2 Revolver, ESP storage, Husky's, Lock'er Down safe, OCD organizer, Interior LED's (red drivers), Glove and safe motion LED's, Rhino lined
    Plats have an electric thigh adjustment that makes a HUGE difference. Drivers side only. Honestly it was one of the biggest features that pushed me to a plat.
    And Yeah, my clip looks like that too. Always wondered...
  25. Apr 5, 2017 at 5:39 PM
    RW-3
    RW-3 May the Mods be with you
    Rob
    16 Black TRD CM 4x4
    Lights: 2018 OEM Black Chrome LED’s Morimoto XB Fogs Interior LED upgrade - VLED’s LED reverse / cargo - VLED’s Footwell lights, vanity lights, break lights, rear turn signals, 3rd break light - All VLED’s 30” Rough Country light bar hidden in bumper w/ Rago Fab Brackets Matt Gecko LED bed lights (red & white) and hood lights Exterior: Truxedo Lo Pro QT WeatherTech in-channel window deflectors Interior: Husky X-Act Contour front & rear Front, back and rear windows all tinted 10% Ceramic Heat Film on Windshield 70% OCD console organizer OCD console tray TRD 4x4 inserts on Husky mats by Achuop Tacoma TRD Pro shift knob with TRD leather boot AJT Design vent ring trim - chrome delete Center console wireless charger Drivers side grab handle Performance: Dirty Deeds BA Muffler 12” Budget Standard System TRD Rear Sway Bar AFE Pro Dry S Air Filter Bilstein 6112 1.9” clip Bilstein 5100 - rear Coachbuilder +1’s Nitto Ridge Grapplers 285/70/18 Audio: Infinity dash speakers Tech12Volts custom center dash speaker Hertz Uno door speakers JL Audio RD 900/5 amp 2 JL Audio 10w-0 v3 10” subs in custom Tech12Volts box Protection: McGuard Tailgate Anti theft lock OEM tailgate lock w/ Dynamat TRD Pro skid plate SNS ARB sensor guards Misc: TRD key fob case AJT Designs Rear diff breather mod Fortin remote start with Car Link CL6 TRD battery bracket by Coupe TRD valve stem caps TRD interior handle inserts by abomb60 (Adam)
    I have a 2016 crew max limited and the passenger side has a pocket but the drivers side doesn't. Hadn't really noticed it until I saw this thread but it is very weird that one side has it and the other doesn't!:notsure:
  26. Apr 5, 2017 at 5:40 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    My SR5 has the same setup but from what I've read some dont. Guess I got lucky.
    RW-3[QUOTED] likes this.
  27. Aug 1, 2019 at 10:39 AM
    2chains
    2chains New Member
    Southern Ablerta
    Just saw that I don't have a driver side rear pocket either on my 2019. Is Toyota cheaping out?
  28. Aug 1, 2019 at 11:18 AM
    greggm
    greggm New Member
    Gregg
    Los Gatos, CA
    2019 CM TRD 4x4
    My 19 SR5 CM, only has the pocket on the passenger side, I thought it was weird too...
    Rabidllamas likes this.
