No Dome Lights this morning…
Discussion in '3rd Gen Tundras (2022+)' started by rizico, Apr 4, 2022.
  1. Apr 8, 2022 at 6:44 AM
    RetiredTundra
    RetiredTundra New Member
    Gary
    2020 Limited TRD
    NO to the higher fuse. You can get the same result by running wire directly to the battery, melted wires or a fire.
    pwpblue and rizico[OP] like this.
  2. Apr 8, 2022 at 6:54 AM
    articdesert
    articdesert Will work for truck parts
    23 1794 MGM
  3. Apr 21, 2022 at 6:14 AM
    rizico
    rizico [OP] New Member
    Johnny-Don
    Luling, Tx
    '22 Capstone 4x4
    Update: Short was in the harness in the headliner. Toyota Service replaced entire headliner and harness. So far so good.
    only downside, that distinctive Toyota 'new car smell' is gone and replaced with a different 'new' smell of the headliner :(
  4. Apr 21, 2022 at 4:53 PM
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    Too bad it wasn't suede.
  5. Jul 14, 2024 at 5:09 PM
    rmumme
    rmumme New Member
    Ross
    2022 Tundra Platinum
    Rough Country eboard power steps.
    Rizico- did this issue ever come back? My 22 Platinum is doing the exact same thing and the dealer hasn’t yet found anything.
  6. Nov 17, 2024 at 5:36 PM
    jonathan_curtis33
    jonathan_curtis33 New Member
    I’m having an issue with my dome and footwell lights as well.
    Last night I was going to upgrade my footwell lights to a brighter LED from the dim blue ones that are on my 2024 Tundra Hybrid Limited trim.
    So I went underneath the driver side and located the blue led currently plugged in. I unplugged it and saw it was a circuit board style with two metal prongs that plug into a two prong plug from the harness. One prong is (+) and one prong is (-). So, to test the new LED I placed the corresponding wires to the correct port in the female plug from the harness and the LED turned on perfectly.
    So, I went to the back of my truck to my toolbox to grab some more solid connectors…because how I was testing it the wires just fall out without me holding them in place. So when I walked back to the front and discovered an issue…the new LED was not even connected to the plug or anything. So right away I noticed my dome lights and both driver and passenger footwell lights were not on and would not come on even when toggling the (off-door-on) switch by the front map lights. However, I noticed some accent lights were still working which I thought was odd. So basically:
    Lights that are NOT working are:
    1. Front and rear overhead dome lights/map lights
    2. Driver and passenger side footwell lights
    Lights that still work are:
    1. Blue leds in center console
    2. Blue led under radio that shines on the wireless charger
    3. Blue LED near the SOS button in the center of that map light assembly
    So far I have:
    1. Replaced both DOME and DOME CUT fuses at the fuse box under the glove box (even though neither appeared to be blown)
    2. Stopped and restarted the truck and closed all doors and opened them just in case there was like some timer issue that turned them off.
    3. Unhooked the negative on the battery for a couple minutes and hooked it back up to see if that would reset something
    4. Visibly inspected the plug where I was testing the LED and looked at wires and nothing appears abnormal.
    There are no notices that pop up, no check engine lights, and everything else appears to be operating perfectly fine in the truck.
    So at this point I’m open to suggestions of other things to try…or maybe somebody knows of another fuse to check or something that could be causing this issue? I tried googling for info about this but I haven’t had much luck…
  7. Dec 10, 2024 at 1:48 PM
    Siblue
    Siblue Old member
    Ryan
    25 Tundra TRD pro
    Did you ever solve this issue?
