Nitto ridge grapplers 35x12.5R18 tire pressure
Discussion in 'Wheels & Tires' started by Jimes, Dec 14, 2018.
  1. Dec 14, 2018 at 10:37 AM
    Jimes
    Jimes [OP] New Member
    Bay Area, California
    2015 toyota tundra trd pro
    so I decided to hit up nitto directly for tire pressure recommendations on the ridge grappler 35x12.5R18s and they said 32 PSI cold in front and 34 PSI cold in the rear. I attached the response. Hope that helps someone. Dealership put mine at 36 PSI all the way around. I told them my weight and tires I have on. My truck weighs 6780 LBS with everything on it. At least that’s what the scale said at the dumps after I unloaded my dump run. That’s with 35s and full size spare, bed rack, RTT, and all my accessories. EFF841A9-919A-4E9B-A24F-C0DBA3707401.jpg
    Watt maker likes this.
  2. Dec 14, 2018 at 11:10 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Frankly, I think that that is low. But watch how they wear. And are you by chance running load range E?
    Since 1985 I have run 35 psi on my truck tires. When I got my 2017 Tundra with Terra Grapplers I did that and didn't like how they were wearing. I saw some others mention 44/45/46 psi (front, rear) and I bumped up to that. I've been happy with the wear since then.
  3. Dec 14, 2018 at 11:21 AM
    Jimes
    Load range F. and ya I thought that was low too. But that’s cold PSI. wonder where that will put the tires at when hot.
  4. Dec 14, 2018 at 11:07 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I've contacted them numerous times over the past couple of months to see if they were consistent and they've told me the same thing each time as well. I have the exact same tires as you. I keep mine at 42 all the way around though. 32/34 seemed sluggish.
  5. Dec 14, 2018 at 11:15 PM
    Jimes
    How are yours wearing out at that PSI?
  6. Dec 14, 2018 at 11:18 PM
    Sas
    OKC, OK
    Wearing even as far as I can tell, but I've only put 5k miles on it since I've owned it.
