Nitto Ridge Grappler vs. Toyo At2 extreme
Discussion in 'Wheels & Tires' started by Muleycrazy13, Dec 29, 2017.
  1. Dec 29, 2017 at 2:51 AM
    Muleycrazy13
    Muleycrazy13 [OP] New Member
    Buckeye, AZ
    2024 Chevy Silverado 2500HD Duramax
    Just about time for new tires on the rig. Currently have the bfg ko2s have almost 50k on them. They are the 275/70r18. I am looking to probably go with 295/70r18 this time around and I'm debating on the 2 tires I mentioned in the title of this thread. I also realize that there is definitely a big level of difference as far as aggressiveness between the two. I think both are a great tire. I live in Phoenix az and spend about 80% on road vs 20% off-road. My off-road can't get rough at times getting into my hunting areas. Anyway just thought I would see what you all had to say. Thanks.
  2. Dec 29, 2017 at 4:20 AM
    Zero One Actual
    Toyo. Look at the weight difference. Plus the 295 is the extreme tread pattern which is the more aggressive toyo pattern. 50k warranty and a 500 mile try out period. SDHQ swears by them on all their trucks. The weight savings alone is worth it for mpg purposes.
  3. Dec 29, 2017 at 6:09 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    i'm a fan of the AT2's but have never tried the RG's, so can't give a solid opinion between the two.
    Grumpy Uncle likes this.
  4. Dec 29, 2017 at 7:22 AM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Put the A/T2 on my sons truck he is loving them says they do really good off road. He was running Bfg Ko2
  5. Dec 29, 2017 at 9:00 AM
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    Where can I find the weight? All the sites that I have looked at don't seem to show the weight of the Toyo.
    Thanks, Mike
  6. Dec 29, 2017 at 9:27 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    i like tiresize.com they give you the weight and specs of MOST tires.
    Patriot, Sunnier and Zero One Actual like this.
  7. Dec 29, 2017 at 9:32 AM
    Grumpy Uncle
    Pat
    CO
    4wp and discount tire used to post wts on their sites. I also run KO2, REALLY like them. That said, I might be trying Toyo AT2s when it's time.
    FlashCulprit likes this.
  8. Dec 29, 2017 at 9:44 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    Any reason you aren’t considering the Toyo r/t’s?
  9. Dec 29, 2017 at 9:57 AM
    BayRunner
    2017 Tundra Platinum
    Have not tried the Toyo, but am completely satisfied with my Ridge Grapplers. Smooth and quite on the road and aggressive enough for the trail running I do. Also did well in the last snow storm we had.
    Muleycrazy13[OP] and Law323 like this.
  10. Dec 29, 2017 at 10:13 AM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    Same here ... haven't tried Toyo but love my RGs. Smooth and quiet on the road and aggressive enough to handle anything I throw at them. Highly recommend them.
    Muleycrazy13[OP] likes this.
  11. Dec 29, 2017 at 10:34 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    You have any pictures of your setup from further out?
  12. Dec 29, 2017 at 10:44 AM
    BayRunner
  13. Dec 29, 2017 at 10:47 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    looks good! what size are you running?
  14. Dec 29, 2017 at 10:51 AM
    BayRunner
    I'm running 285/65-18. Wanted to keep it closer to stock size in order to keep the speedo as accurate as possible. These are a little larger than stock but the speed is right on when compared to gps.
  15. Dec 29, 2017 at 10:53 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Looks great. I’m considering these. The guys that are installing my 6112/5160 are pushing the Pro Comp AT Sport but I have no experience with Pro Comp.
  16. Dec 29, 2017 at 10:56 AM
    Zero One Actual
    From tiresize.com. So really, the weight difference is only about six pounds per tire for a total of 24 extra total pounds rotating. I would think that's not a noticeable difference for MPGs. I eat 24 pound meals. Or tell your girl to diet and call it even. That's sarcasm by the way.
    Those RGs look good and aggressive, so be ready to fight when you get out of the truck. Otherwise go with the Toyos.
  17. Dec 29, 2017 at 11:23 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    I’ve got the ridge grapplers and am more than happy with them! Good traction and smooth on the highway. They’ve done amazing in the snow and ice so far this winter
    757TUNDRA likes this.
  18. Dec 29, 2017 at 12:21 PM
    BayRunner
    Just for FYI sake, I'm running the 6112/5160 setup in the pic I just posted above. The 6112s are set at the 1.9" notch. Should give you a decent visual to see what the look would be with the RG.
    BTBAKER[QUOTED] likes this.
  19. Dec 29, 2017 at 12:28 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Thanks! Looks awesome. Just had mine installed and put about 30 miles on. So far so good. I’ll report back with pics.
    Any issues with rubbing?
  20. Dec 29, 2017 at 12:31 PM
    BayRunner
    No rubbing at all. The ride is firmer which is exactly how I like it.
  21. Dec 29, 2017 at 12:49 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Ridge all day, I sell about 7 sets to every 1 set of AT2's at work. Perfect combo for street and trail use, just like the Toyo RT is..
    757TUNDRA and BTBAKER like this.
  22. Dec 29, 2017 at 1:43 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Does the RG have a mileage warranty?
  23. Dec 29, 2017 at 3:11 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Not at the moment...That I'm aware of
    That is a + for the AT2!
  24. Dec 29, 2017 at 3:12 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Agreed. Discount tire has always stood by it for me so it will be a tough decision.
  25. Dec 29, 2017 at 3:17 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I know you can always purchase a road hazard which will cover any tire and you're just liable for the prorated amount of life after >50% tread is gone plus m/b'ing.
    BTBAKER likes this.
  26. Dec 29, 2017 at 6:18 PM
    Muleycrazy13
    Buckeye, AZ
    So Toyo weighs in a at 64 pounds a piece in the 295 size and the ridge graps weigh 69 pounds a piece
  27. Dec 29, 2017 at 6:23 PM
    Muleycrazy13
    Buckeye, AZ
    Seems like most everyone who has posted generally goes towards the ridge graps but no one has anything bad to say about either tire
  28. Dec 29, 2017 at 6:33 PM
    Justin9
    Justin9 New Member
    Justin
    Utah
    2017 Cement TRD Pro
    Nitto Ridge Grapplers 295/70/18’s on my Pro and have no complaints. B27244FF-4E1E-46AE-BFD0-9D40978E3D7F.jpg
  29. Dec 29, 2017 at 8:55 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Do you have a bigger lift? Seems lifted more than stock. Any rubbing with the 295?
    TheBeast likes this.
  30. Dec 30, 2017 at 7:50 AM
    Justin9
    Justin9 New Member
    Justin
    Utah
    2017 Cement TRD Pro
    I have a 4” Ready Lift then added a bumper spacer and no rubbing. I also had the plastic mud guard that went behind the front tires removed also those had to come off anyway with the flares being added.
    Noodle and ARES like this.
