Nitto Ridge Grappler in 285/70r18?
Discussion in 'Wheels & Tires' started by Muleycrazy13, Sep 24, 2017.
  1. Nov 26, 2017 at 5:13 PM
    #61
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Any more pics of these tires on stock trd wheels???
  2. Nov 26, 2017 at 6:57 PM
    #62
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    On my 2007 I fit a 275/65/20 KO2 on a stock 20" wheel in my spare tire location with the removal of a small metal bracket that does nothing.
    Remove the bracket I've circled.
    equin, Watt maker and Quebec like this.
  3. Dec 3, 2017 at 7:36 AM
    #63
    scout495
    scout495 New Member
    Question, do you have to change anything with the Speedo to get an accurate reading when you run these tires?
    Thx!
  4. Dec 3, 2017 at 8:52 AM
    #64
    Marty McFly
    Morty McBoonJug
    I didn't change anything with the speedo. 285 is close to stock, so it should have a lower impact on performance.
  5. Apr 2, 2018 at 9:52 AM
    #65
    EDHCA33
    EDHCA33 New Member
    2010 Silver TRD 4X4
    Bilstein 5100 Leveling Kit
    I'm about to pull the trigger on Nitto Ridge Grapplers 285/70/18. I have the Bilstein 5100 leveling kit (2.5" front / 0 rear). Do you foresee any rubbing issues? Thanks!
    Marty McFly[QUOTED] likes this.
  6. Apr 2, 2018 at 10:03 AM
    #66
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Depends on wheel (rim) offset
  7. Apr 2, 2018 at 11:34 AM
    #67
    Marty McFly
    Morty McBoonJug
    Your set up is the same as my PRO so you shouldn't have issues with rubbing, but @JoshuaA is correct. It will heavily depend on the wheels and offset.
  8. Apr 2, 2018 at 12:00 PM
    #68
    scout495
    scout495 New Member
    FYI, I have a pro with 1.25 inch spidertrax spacers, Nitto Ridge grapplers 285/70/18 and I had to remove the front mud flaps because they were rubbing in reverse with the wheel cut all the way.
    equin likes this.
  9. Apr 3, 2018 at 10:05 AM
    #69
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I've got 275/70/18 ridge grapplers with a 2" spacer kit, and 18x18.5 wheels with a +25mm offset. I had to remove the rear front mud flaps because mine was rubbing. Once I took those off, it was fine. I will say it's still pretty close though, but I think my truck has settled over the last couple of years and I don't have the true 2" of lift anymore.
    equin likes this.
  10. Apr 12, 2019 at 7:42 PM
    #70
    Jrocker
    Jrocker New Member
    James
    2014 TRD Off-Road 4x4 Crewmax
    Need
    Did you ever get an answer on your spare under the bed?
