Nitro 5.29 Gears or Sierra 5.29 Gears?
Discussion in 'Performance and Tuning' started by cementsharktrd, Mar 11, 2022.
  1. Mar 31, 2022 at 11:34 AM
    BruteForceBeWithYou
    BruteForceBeWithYou New Member
    Stephen
    2019 Cement Grey DC
    Most guys go with bigger tires on their trucks even if it's incremental. As I have experienced over the years, ANY tire size change affects the vehicle dynamics of how it was engineered. I hear a lot of friends complain about how their Tundra operates after these changes, but always put up with it because of its reliability.
    They change it to make it look better and then hate how it drives after. I've heard guys say the truck is "happy" after the proper gears and that is the best way to put it. After having the 5.29s installed, my truck operates so well that MPG isn't as big of an issue, whereas when I was lugging the tires around I hated how it operated AND hated the MPG. Now the truck is wayyy more confident, wayyy more fun to drive. These trucks are almost like a living organism, give it what it wants and it in turn gives you what you want.
  2. Mar 31, 2022 at 12:43 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Anyone have a link on Sierra gears?
  3. Mar 31, 2022 at 12:43 PM
    2mchfun
    Might talk to Keith about them.
  4. Apr 7, 2022 at 2:51 PM
    19greysport
    19greysport New Member
    2019 crewmax sport
    I got some 5.29 gears nitro brand new in the box I’m thinking about selling. And a auburn lsd. Anyone interested?
    pandapro likes this.
  5. Apr 7, 2022 at 3:30 PM
    pandapro
    pandapro New Member
    Should go quick! Unless you “know what you got”.
    texasrho83 likes this.
  6. Apr 7, 2022 at 4:57 PM
    bmtrujillo98
    bmtrujillo98 New Member
    I have 4.88s from Nitro on my truck, found them on a website for an RV outfitter in California for about a grand. My 2013 with 35x12.5x18 KO2s drives much closer to stock now, averages 15 MPG going up to Eisenhower tunnel here in Colorado. Very little, if any, gear hunting. Lots of torque off the line. Pretty happy with them.
    GODZILLA likes this.
  7. Apr 7, 2022 at 5:02 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Hit me with a price for both and separately plz
  8. Apr 7, 2022 at 5:03 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Keep in mind that if the gears are noisy, you will be paying the additional labor to change them out unless ordered through the installer. I found this out the hard way.
    pandapro, texasrho83 and 2mchfun like this.
  9. Apr 8, 2022 at 5:43 AM
    TXTundra2722
    2015 Black Tundra
    If you have any kind of exhaust...... you're not going to hear any gear noise.
  10. Apr 8, 2022 at 5:53 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'd be more worried about mechanical failure
    TXTundra2722[QUOTED] likes this.
  11. May 9, 2022 at 8:05 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm still in my 500 mi break-in but plan to use some really good stuff after the drain and fill. I was looking at Nitro's recommendations and they have 80W-140 para-synthetic GL-5 type stuff. Has anyone used any 80W-140 with their Nitro gears? Could it possibly help with the noise issue?
  12. May 9, 2022 at 8:33 AM
    TXTundra2722
    2015 Black Tundra
    I don't remember what oil I got from Nitro..... but it's whatever they recommended. Once again....I hear zero gear noise with my DD exhaust
    :spy:
    bflooks and texasrho83[QUOTED] like this.
  13. May 9, 2022 at 8:38 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm with you on the radio/exhaust drown out method but I want these gears to be in their prime habitat. You probably got the 80W-140. No issues?
  14. May 9, 2022 at 3:27 PM
    TXTundra2722
    2015 Black Tundra
    No issues for me. I've heard a few with issues and a few others did some kind of treatment to them before installation.... but I don't remember what it's called. Usually with gears the only time there is an issue is when they aren't installed correctly....unfortunately we're all human so even the best installers can make a mistake
  15. May 9, 2022 at 3:36 PM
    bflooks
    bflooks New Member
    Metrowest MA
    This is what I got from Nitro when asking about towing break-in and Lucas 85w-140 (what I'm running).
    NO THATD BE GREAT IM SURE , HERE WE RUN AN 80W-140 MADE FOR US BY SCHAFFERS; HAS A PARAFINIC BASE SO THERES NO NEED FOR FRICTION MODIFIERS.
    I THOUGHT IT WAS FUNNY WHEN I LEARNED THAT’S WHAT WE USE HERE , MY GRANDFATHER WAS AN EXCAVATOR AND USED THAT BRAND OF OIL IN EVERYTHING HE OWNED HAHA. THE TOP OF THE LINE SYNTHETICS CAN DECREASE THE HEAT INSIDE THE DIFF BY UP TO 35 % , THAT’S THE MOST IMPORTANT PART ABOUT IT
    Sumo91 and texasrho83 like this.
  16. May 9, 2022 at 3:39 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Great to hear! @Sumo91 was using Schaeffer's and swore by it. I do think Nitro is overcharging for their qts though :monocle:
    Sumo91 and bflooks[QUOTED] like this.
  17. May 9, 2022 at 5:01 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Yes sir! I ran Schaeffers for years in everything I've owned. It's great stuff!
  18. Feb 23, 2024 at 6:11 AM
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    I have a 2021 Tundra with 5.29 gears running 35s and it’s been amazing. However, I would recommend buying a tuner to get the ecu adjusted because you really start to noticed how slow the transmission shifts with this gear setup.
    gabex35 likes this.
  19. Feb 23, 2024 at 8:04 AM
    #49
    gabex35
    gabex35 2020 Limited 4x4 with mods coming...
    San Diego
    2020 Cement Limited 4x4
    Is there a recommended tuner? I have the same setup with a heavy camper and could benefit from one. Thanks
  20. Feb 23, 2024 at 8:29 AM
    #50
    Ctaylor76
    Chaz
    Houston
    HP Tuners, but I would recommend using someone with experience to build a custom tune for you, if you have a local place that can do it on a dyno even better.
  21. Feb 23, 2024 at 5:03 PM
    #51
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    100% hit the nail on the head. I thought my new gears were awesome till I had my truck tuned and dug into the trans controls. Really made a huge difference.
