Next mods...what would you do looking back?
Discussion in '2.5 Gen Tundras (2014-2021)' started by AxeHeadTradition, Jan 17, 2019.
  1. Jan 29, 2019 at 4:36 PM
    Rubberdown
    It’s kind of true. Actually it shocking that I’ve gotten this far in life.
  2. Jan 29, 2019 at 5:58 PM
    JakeyTheMost
    JakeyTheMost New Member
    Jake
    2018 Cement Tundra
    No BMC, only had to remove the small mud flap on the front bumper in front of the wheels. Have had no rubbing issues with moderate off-roading either.
    If you have any other questions or want to see a different angle just let me know.
  3. Jan 30, 2019 at 7:01 AM
    DiegoC
    DiegoC New car smell
    Diego
    2016 White Tundra Limited
    ReadyLift SST 3/1 Level Lift W/ sum 35's
    I’d go rear sway bar. It’s pretty cheap and does help the drive a lot for the crew max if your keeping it on the street or dirt roads
    AxeHeadTradition[OP] likes this.
  4. Jan 30, 2019 at 7:09 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Here is another stock suspension with 285/65 toyo at II. No bmc, front mud flaps removed. No rubbing. On 18x9 +20 offsetIMG_20180610_134758388.jpg IMG_20180502_152857874.jpg
  5. Jan 30, 2019 at 1:43 PM
    AxeHeadTradition
    AxeHeadTradition [OP] New Member
    2018 Tundra Crewmax
    Nice!
  6. Jan 30, 2019 at 1:57 PM
    DiegoC
    Diego
    I think I follow you on instagram
  7. Jan 30, 2019 at 9:43 PM
    jsfost
    jsfost New Member
    Take a look at this one
  8. Jan 30, 2019 at 9:45 PM
    jsfost
    jsfost New Member
    I wanted to do something moderate. After Harvey hit, I wanted to add some height but didn’t want to go crazy and start changing stock angles.
  9. Jan 30, 2019 at 10:50 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    I’d get the rear TRD sway bar,
    Led puddle lights for the mirrors if your truck has them. Don’t get big rims if you don’t want to deal with issues that come with “ filling the wheel well “ that will leed to a lift and other expensive goodies.
    LED head lights or other bulbs, interior goodies are also easy installs. Left hand side grab handle,
    K&N air filter, don’t get TRD one
    New front TRD sway Bar.
    My list is long....:anonymous:...:popcorn:... time is short. Good luck
  10. Jan 31, 2019 at 4:14 AM
    scgrab21
    scgrab21 New Member
    Maryland
    Tundra CM | Limited | TRD | Cement
    That is a nice setup. Well done!!
    JakeyTheMost[QUOTED] likes this.
  11. Mar 6, 2019 at 1:10 PM
    AxeHeadTradition
    2018 Tundra Crewmax
    Got some mods from the most recent deal that was posted.
    The air flow accelerator and TRD drop in filter.
    And.. TRD rear sway bar
  12. Mar 6, 2019 at 2:39 PM
    EverydayTundra
    EverydayTundra New Member
    Jay
    NY
    2016 magnetic grey Tundra TRD
    2.5 inch level, 33 inch tires, air bag kit in rear, color match grill
    Where did you get the Ted air flow accelerator?
  13. Mar 6, 2019 at 3:13 PM
    AxeHeadTradition
    2018 Tundra Crewmax
    Hendrick Toyota when they had the parts and shipping sale.
  14. Mar 6, 2019 at 3:17 PM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    agreed. stay away from the 701 if you don't want to do a chop. 0 offset limits your tire size. get the 6112/5150 setup and a set of scs wheels. they are all +25 so they will allow you to run a 295ish tire. that's a solid start.
  15. Mar 6, 2019 at 4:15 PM
    Heeler13
    Heeler13 21MGM
    Eastern NC
    2021 Sr5 XP
    Bilstein 5100 Front @ middle setting Bilstein 5100 Rear @ stock height Oem older Pro wheels 285/75/18 Maxxis Razr a/t
    This.
  16. Mar 6, 2019 at 5:12 PM
    AxeHeadTradition
    2018 Tundra Crewmax
    Yeah I'm leaning towards the Ray 10s.
  17. Mar 6, 2019 at 5:21 PM
    Erichudgins
    Eric
    Murfreesboro, TN
    solid choice...and because of the above post, im going to inform you that im in no way going to tell you how to spend your money. the list that I told you that I would choose is strictly based on COST EFFECTIVE parts that are PROVEN to perform well on and off road. ive earned the right to defend that because I had a spacer lift first with ZERO intentions of offraoding the truck. 10k dollars later ive completely changed the direction of my build. the kit I suggested is a solid, relatively inexpensive way to get a great driving truck, on or off road with extreme dependability. had you said you wanted to build an offroad overlanding beast of a rig, id made a lot different suggestions :)
    jewsNbrews likes this.
  18. Mar 6, 2019 at 5:23 PM
    AxeHeadTradition
    2018 Tundra Crewmax
    I appreciate all the suggestions. Any input is always welcome. Thats what the forum is for right?
    Erichudgins[QUOTED] likes this.
  19. Mar 6, 2019 at 5:28 PM
    #49
    Erichudgins
    Eric
    Murfreesboro, TN
    exactly. I wish id asked this question long ago lol
  20. Mar 6, 2019 at 5:30 PM
    #50
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Good call. :bowdown:
  21. Mar 13, 2019 at 1:36 PM
    #51
    AxeHeadTradition
    2018 Tundra Crewmax
    Rear TRD Sway installed too
  22. Mar 21, 2019 at 8:43 AM
    #52
    AxeHeadTradition
    2018 Tundra Crewmax
    Question for those that installed the TRD rear sway on a stock SR5 suspension, did you have the same responsiveness that is talked about on the forums. I can definitely tell the truck takes turns like it's on rails. However on the straight away I feel like the ride is rougher, not crazy but just enough to make it feel off. Almost like it is skipping.
  23. Apr 5, 2019 at 8:09 AM
    #53
    AxeHeadTradition
    2018 Tundra Crewmax
    Does anyone have pics of SCS SR8s on Falken Wildpeak AT3'S? Also where is the best place to get Falkens? Thanks in advance.
  24. Apr 8, 2019 at 1:35 PM
    #54
    AxeHeadTradition
    2018 Tundra Crewmax
    Just picked these babies up! Thanka to the guys at SCS. Can't wait to get them installed. Best place in the Bay Area to get Falken Wildpeak At3s? And installed?
    jewsNbrews, GiantsFanDan and DiegoC like this.
  25. Apr 8, 2019 at 2:45 PM
    #55
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    If I knew then what I know now, what mod would I have done?
    Bought a 1-ton.
    Nice truck, BTW. :thumbsup:
  26. Apr 8, 2019 at 3:45 PM
    #56
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
  27. Apr 9, 2019 at 7:39 AM
    #57
    AxeHeadTradition
    2018 Tundra Crewmax
  28. Apr 9, 2019 at 5:01 PM
    #58
    davescarp
    davescarp New Member
    Massachusetts
    '18 DC TRD OR
    Baja fogs were one of the first and best things I've done. Really want leather seats w heaters right now. Bed lights, footwell lights, and better LED front blinkers we're pretty cheap and very functional mods too.
  29. Apr 9, 2019 at 6:37 PM
    #59
    jsfost
    jsfost New Member
    Davescarp, could you tell me about your foot well light mod. I’ve been looking into this, that and the buttons for the switches on all door panels passengers because they aren’t lit
  30. Apr 9, 2019 at 6:57 PM
    #60
    Mgmtundra
    Mgmtundra MGM Crew
    9003553F-C049-45C5-A88B-66783D2BD959.jpg SR8 w machine lip
