Newer amenites you'd like in your 1st Gen?
Discussion in '1st Gen Tundras (2000-2006)' started by Baller, Apr 15, 2021.
  1. Apr 16, 2021 at 5:19 PM
    #121
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    I added the GTA car kit that gave me BT and hands-free phone. I already have the radio controls on the steering wheel (which works perfect with the GTA car kit). I added wireless charging though I’m looking for a better way to mount it. I also added a reverse camera in the tailgate handle and a camera mirror so I’m done with the tech stuff.
    I would love power side steps to aid entry but then disappear and though I’ve seen them added to the 1st Gen it’s out of my price range.
    So yeah, we drive older non-fancy trucks but a lot of the tech stuff we can add. And the cool part is it can all be hidden (if you’re an OEM junkie like me you’d really appreciate that).
  2. Apr 16, 2021 at 5:22 PM
    #122
    ezdog
    ezdog New Member
    Gateway To The West
    To aid entry???
  3. Apr 16, 2021 at 5:26 PM
    #123
    abcinv
    Tommy
    South of ATL
    You know, climbing in and out of the cab. My wife is short-ish and is bugging me to install nerf bars. I’ll probably do it at some point but prefer the cleaner look I have now...
  4. Apr 16, 2021 at 5:32 PM
    #124
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    There's plenty that could be posted for a simple steering wheel swap, where it gets a little more entailed is if one does not have steering wheel controls presently. When you get serious and come to a problem, post it up, you know there's plenty here capable of helping.
    @shifty` made a great post last summer and at the bottom of that post are some very good threads to read over with a couple threads containing pictures, which were great for dummies like me :cool:
  5. Apr 16, 2021 at 5:34 PM
    #125
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Steering wheel controls are a must have for me. Maybe it’s because of how much I listen to music. Maybe it’s because of how many different cars I was in and out of when I was doing car audio.
    Let the hate flow, but this is the absolute best designed steering wheel of all time. The audio buttons are exactly where your hand rests, and the others navigate through the vehicle info so easily.
    Edit: sorry this was supposed to be a multi quote. Don’t think I can edit that in on mobile.
  6. Apr 16, 2021 at 5:35 PM
    #126
    ezdog
    ezdog New Member
    Gateway To The West
    No hate just confusion.
  7. Apr 16, 2021 at 7:28 PM
    #127
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    I meant that I was expecting hate for the GM wheel. Sorry that was poorly worded.
    Darkness likes this.
  8. Apr 16, 2021 at 7:33 PM
    #128
    ezdog
    ezdog New Member
    Gateway To The West
    Understood,plenty of dislike for many things GM!
    KarmaKannon likes this.
  9. Apr 17, 2021 at 2:17 AM
    #129
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I could drive by a bank, too, but I'm looking for a permanent solution. Whenever I drive over a wet bridge I'm in the habit of checking the air temp to predict whether I'm going to roll over the bridge or fly off it.
  10. Apr 17, 2021 at 2:57 AM
    #130
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Ah, I see. I'm sure @empty_lord has a solution for you.
    I was just gonna suggest this.
    w666[QUOTED] likes this.
  11. Apr 17, 2021 at 7:45 AM
    #131
    ezdog
    ezdog New Member
    Gateway To The West
    I can easily just press a button and leave the temp on the display as one of 4 parameters shown at all times on the Scan Gauge so no need for a bank with that one.
    Although I have to think that as the engine heats up that the intake temp also rises?
  12. Apr 17, 2021 at 11:20 AM
    #132
    Professional Hand Model
    Hand Protectors
    Unsure if its mentioned here already, but Blue Tooth Capability for the Stereo. Easy fix now with a BT Box that plugs in to the open CD Plug on the back of the OEM Stereo.
    HBTundra, onesojourner and jimf909 like this.
  13. Apr 17, 2021 at 12:08 PM
    #133
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    There are options for ambient temp gauges:
    Somewhat expensive, I believe a $20 sender is also required:
    https://www.bluesea.com/products/1741/Mini_OLED_Temperature_Monitor_-_Yellow
    Cheap, there are zillions of these...
    https://www.amazon.com/BALDR-Wirele...t=&hvlocphy=9057480&hvtargid=pla-665179509823
    Bu I think you may want a mirror with a temp/compass display, similar to what was installed as an option on mine. Cheaper alternatives are at a pick n pull...
    "When the temperature is at or below 37 degrees the display will indicate \"ICE\" for a period of one minute."
    https://www.amazon.com/Gentex-GENK2...ta+temp+rearview+mirror&qid=1618686303&sr=8-4
    w666[QUOTED] and KarmaKannon like this.
  14. Apr 19, 2021 at 11:03 AM
    #134
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  15. Apr 19, 2021 at 11:04 AM
    #135
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    My CC doesn't do the 1 mph up and down either.
  16. Apr 19, 2021 at 8:30 PM
    #136
    jimf909
    Washington or Idaho
    Return it to Toyota and demand a full refund. It does require some time for the speed to change, or that function may have failed.
    Jack McCarthy likes this.
  17. Apr 19, 2021 at 8:33 PM
    #137
    jimf909
    Washington or Idaho
    You're welcome to your opinion, but in my mind steering wheel controls should allow the driver to use the control with minimal movement of their hand. I can't imagine ever holding a steering wheel where those lower buttons are accessible to my fingers. What are those buttons doing down there?
    FWIW, YMMV.
  18. Apr 20, 2021 at 9:44 AM
    #138
    Baller
    Baller [OP] New Member
    '05 Tundra SR5 DC
    Or get some lawyers together and sue them. Anyone recollect some dude on here, I think it was a 3rd gen guy, making a huge fuss that he was going to sue Toyota for not installing a trans cooler in the latest Tundras? It was an entertaining thread.
  19. Apr 20, 2021 at 10:34 AM
    #139
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I don't think this has been said yet, but automatic roll down on all five windows. I imagine it wouldn't be too hard to make happen.
    FrenchToasty, KarmaKannon and bmf4069 like this.
  20. Apr 20, 2021 at 10:36 AM
    #140
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Yep! The passenger side on the sequoia is auto roll down and I had no idea how much I'd like it.
    Tundra2 likes this.
  21. Apr 20, 2021 at 1:18 PM
    #141
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    And auto up if we're going that route.
    Tundra2 and BubbaW like this.
  22. Apr 20, 2021 at 6:15 PM
    #142
    Hny_Bdgr
    Hny_Bdgr New Member
    black 2000 toyota tundra sr5 v8 4x4
    If it fits it ships
    i want a key fob remote start and apple car play even though i can put all of that in there and i already have a different head unit i am just too broke to do it
  23. Apr 20, 2021 at 6:34 PM
    #143
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Next you'll tell me your cruise doesn't slow down 5mph after setting, downshift twice, speed to 5mph over your target speed, and eventually shift...
    FrenchToasty and bmf4069[QUOTED] like this.
  24. Apr 20, 2021 at 9:38 PM
    #144
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Actually, it does pretty good. There's only one hill it struggles with, and it just goes over when it crests the hill. But remember, it's super flat where I live. Pic somewhat related:
    I had to get a picture with a cow for a challenge.
    Lil Steve likes this.
  25. Apr 20, 2021 at 9:53 PM
    #145
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    See my earlier post on page 3.
    KarmaKannon[QUOTED] likes this.
  26. Apr 20, 2021 at 10:06 PM
    #146
    1stgentundradriver
    1stgentundradriver Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    I second this idea.
  27. Apr 20, 2021 at 10:35 PM
    #147
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    When I upgraded my stereo, the SW control adapter didn’t work, so I ditched it. Haven’t ever missed those controls.
  28. Apr 20, 2021 at 10:37 PM
    #148
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    i use to not understand it either. but after having them. its just wonderful being able to control the radio without looking at all
    BubbaW likes this.
  29. Apr 20, 2021 at 10:42 PM
    #149
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Hmmm. My cruise is pretty steady, even in hilly areas.
    Nope.
    DC things?
    1stgentundradriver likes this.
  30. Apr 21, 2021 at 3:01 AM
    #150
    KarmaKannon
    Utah
    Some junk
    I think it's more a 5 speed trans thing. Seems like pre 2005 guys don't mind their cruise. The issue presents itself on completely flat ground. If you throw hills in the mix with my tires and gearing... Forget about it.
