Newbie with torque converter trouble!
Discussion in '2nd Gen Tundras (2007-2013)' started by tundramaster50, Feb 21, 2021.
  1. Feb 21, 2021 at 2:42 PM
    tundramaster50
    tundramaster50 [OP] New Member
    mark
    2007 tundra double cab 4x4
    3 inch lifth
    hello, my beloved 2007 tundra 4x4 with the 5.7 have developed a shudder when the lock up for the torque converter occurs. I already replaced transmission fluid and filter, no change, and my vin number is directly related to the tsb for the torque converter. also the transmission is working a little hot, in the 235f range, by the torque application. mine does not have the cooler, by the way. so, look like the torque converter is fried. now, what you recommend as far as a good torque converter replacement that is not going to break the bank?
    blackdemon_tt and YardBird like this.
  2. Feb 21, 2021 at 2:47 PM
    timsp8
    NY
    I’d say either a junkyard, auto store, or a performance one. Junkyard would be the cheapest. Auto stores usually carry the same brand that is renamed for oem. I remember seeing a website that sold performance ones but don’t remember it now. It all depends on how much you want to spend. I just searched google and found some on eBay and partsgeek for $300 or less vs $1000 or more for oem.
  3. Feb 21, 2021 at 2:53 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  4. Feb 21, 2021 at 3:51 PM
    Welcome from NY.
  5. Feb 21, 2021 at 3:54 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Welcome.
    My 2007 would shudder going from 4th to 5th every now and then, my solution is to drive it in S4 shifting into S5 & S6 as needed while driving, and back to S4 when stopped. I have not experienced a shudder since driving in this fashion.
    Give it a try.
  6. Feb 21, 2021 at 4:38 PM
    tundramaster50
    mark
    3 inch lifth
    thanks for the answer's and the welcoming, I want to go the new converter route, but I can not find much about who makes the oem converter, since this vehicle is put together in the states, it can be really any manufacturer!
  7. Feb 21, 2021 at 4:42 PM
    tundramaster50
    mark
    3 inch lifth
    it is honestly getting worse, and also afecting the transmission, since instead of locking up, it slip's , them it overheats the oil, I tried everything from driving manually in sport to what you recommend, but every time the flex lock up intervenes it do the rumble thing.
  8. Feb 21, 2021 at 4:44 PM
    tundramaster50
    mark
    3 inch lifth
    is too much work to put a used one, that may be a really good one, or not. I can not find who makes the oem. thanks for replying!
  9. Feb 22, 2021 at 8:46 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    For the gigantic PITA that it is to change out a torque converter, I would buy a Toyota OE one.
  10. Feb 23, 2021 at 6:10 AM
    tundramaster50
    mark
    3 inch lifth
    yes, i think is better to play safe here with such a important part of the engine/transmission!
  11. Mar 25, 2021 at 3:38 PM
    tundramaster50
    mark
    3 inch lifth
    hello,just to let everybody know that it was the torque converter, and now she runs like a dream! thanks to you all!
  12. Mar 25, 2021 at 4:40 PM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Good to hear you found the trouble.
  13. Mar 25, 2021 at 8:06 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    Glad you got it fixed! How much did it set you back for the repair?
  14. Mar 26, 2021 at 2:57 PM
    tundramaster50
    mark
    3 inch lifth
    647 for a toyota converter and 550 for my mechanic to change it!
    MTRock, blackdemon_tt and Oey12 like this.
  15. Mar 27, 2021 at 5:57 AM
    Rph74
    Rph74 New Member
    Springfield,MO
    Not bad at all!
