Newbie to Tundra Forum JB1950 - Towing concerns
Discussion in 'New Member Introductions' started by JB1950, Feb 23, 2020.
Tundra -5.7 with full towing pkg
Poll closed Mar 24, 2020.
  1. Towing experience with Travel Trailer
    2 vote(s)
    100.0%
  2. best unit for weight distribution
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Feb 23, 2020 at 7:44 AM
    JB1950
    JB1950 [OP] New Member
    2015 - 2017 Tundra - looking to buy
    Tundra 5.7L 2WD with FULL TOWING PKG - concern. Ready to buy 2017 to 2017 Tundra however need to be sure this truck can pull cross-country a travel Trailer approx 7500GVWR fully loaded. Looking for Tundra owner that has hauled suck a Travel Trlr. Appreciate any advise I can get before I buy Tundra. I'm long time owner of Toyota cars etc think they are the most reliable vehicles ....
    Ready to buy Tundra 2015 to 2017 model CrewCab with 5.7L 2WD and must have full towing pkg. Looking to travel across country with a approx 7500lb GVWR Travel Trailer includes our personal effects in total.
    I wanted to be sure that the TUNDRA would have no problem in towing such a trailer per my research Tundra with full tow pkg can pull up to 10,200lbs. I will install a weight distribution hitch as well.
    I'd appreciate any knowledge and/or experience before I actually BUY a Tundra
    Thank You,
    JB1950
    Prostar 190 and Y0TA PR0 like this.
  2. Feb 23, 2020 at 7:58 AM
    Welcome from NY.
    I have a 2018, 5.7, 4WD with the tow package. I tow a 20' trailer with my Camaro on it with no issues, don't even feel it behind me.
  3. Feb 23, 2020 at 8:17 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  4. Feb 23, 2020 at 8:18 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    WELCOME!
  5. Feb 23, 2020 at 12:10 PM
    Welcome from TEXAS
  6. Feb 23, 2020 at 12:17 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Howdy from DFW and :worthless:
  7. Feb 24, 2020 at 2:48 AM
    Welcome from Ohio
  8. Feb 24, 2020 at 7:17 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Payload and tow ratings for 5.7L with tow package will vary depending on model (CrewMax vs DC), bed length, drive config (4WD vs 2WD), gas tank size (38 or 26 gallon), and any other modifications that increase weight. A 5.7L Tundra should tow 7500 pounds with no trouble, but the 10200 pounds number sounds high for some Gen3 models.
    Tow ratings for some 5.7L CM (short bed) with tow package, 4WD, and optional 38 gallon tank can be as low as 8800 pounds. Without the tow package, tow ratings on some 5.7L models can be as low as 7800 pounds, less for 4.6L models. If you find a Tundra you like, get the model number off the driver door jamb sticker, and we can verify the specific payload/tow ratings for you from owner manuals.
    Welcome from the Texas Hill Country. :thumbsup:
    JB1950[QUOTED][OP] likes this.
  9. Feb 24, 2020 at 8:37 AM
    wakeboarder
    wakeboarder New Member
    13 Tundra
    Welcome. I tow a 21’ inboard boat regularly. It has a combined weight of roughly 6,500lbs (boat is 4K dry weight, trailer approx 2k, and around 500lbs of gas/gear). My ‘13 DC 5.7 pulls it like a champ.
  10. Feb 24, 2020 at 9:07 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    welcome from So Cal
  11. Feb 24, 2020 at 9:14 AM
    ColoradoBoo
    ColoradoBoo New Member
    Rick
    2014 Red Toyota Tundra 4X4 TRD Maxcrew
    Firestone Airbags; remote starter; replaced stock mirrors with larger, pull-out mirrors for towing; hard plastic sectional cover for bed.
    Smart move on the weight distribution hitch! You may, also, want to put some airbags in the rear of the Tundra which will help keep her level since you'll be towing near the max weight. We tow a 34-foot Ultra-Light Rockwood camper up/down our Colorado mountain passes the Tundra is a beast.
    JB1950[OP] likes this.
  12. Feb 24, 2020 at 10:51 PM
    JB1950
    U mentioned that you have a Rockwood ultralite we plan on getting same but somewhat smaller about 26ft. I'm not sure I understand we plan on getting the Tundra CrewCab with 5.7L and full Tow Pkg and the air bags sound like a good idea as well. I'm curious why you mentioned we'll be towing near the max i've looked at spec's I was under the impression that full tow pkg we could tow approx 10,000 lbs - we believe we'll be no more than 8,000 lbs. Am I missing something?
  13. Feb 24, 2020 at 11:40 PM
    MightyMax
    MightyMax New Member
    C
    2020 Tundra Platinum CM
    3/2 level kit, CM Canopy
  14. Feb 25, 2020 at 1:14 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I have a 27 foot travel trailer that weighs about 6000 dry. Fully loaded truck pulls it no problem. I have a rear sway bar and airbags.
  15. Feb 25, 2020 at 5:55 AM
    JohnLakeman
    Maybe you missed my post above? That's disappointing because I spent some time researching and composing that post for you. The "model-specific", "as-equipped" tow rating is what the owner manual says it is. Here it is again, read only the BOLD part below:
  16. Feb 25, 2020 at 7:06 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I believe the Path you take cross country will dictate much of the towing experience.
    Personally I'd avoid grades above 5 degrees in elevations above 5K feet, but that's me....
  17. Feb 25, 2020 at 7:24 AM
    ColoradoBoo
    Rick
    Oh because we never just tow with an empty truck and and empty camper. Water, food, clothes, BBQ stuff, etc, all adds up pretty quick...it's not hard to have 2,000 pounds of additional stuff when it all comes down to it. 50 gallons of water weighs over 400 pounds. So if you know you have a lot of weight, don't fill up the water tank in the camper all the way...just enough for basic stuff while you're driving to your location. (Washing hands, flushing toilet)
  18. Feb 25, 2020 at 12:20 PM
    twistedcricket
    twistedcricket New Member
    Paul
    Omahell, NE
    2014 SR5
    TRD rear sway bar, power fold tow mirrors, Firestone airbags, LED OEM fogs
    Welcome from Nebraska
