New wheels for the fat girl
Discussion in 'Wheels & Tires' started by SullyMoto19, Apr 16, 2018.
  1. Apr 16, 2018 at 10:47 AM
    SullyMoto19
    SullyMoto19 [OP] New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    Had the new wheels installed for our event at Benchmark Customs. 22x14 with a -76 offset. Love the new stance, makes the truck beefy as hell.
  2. Apr 16, 2018 at 10:51 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Nice!
    SullyMoto19[OP] likes this.
  3. Apr 16, 2018 at 11:24 AM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Nice set up! What size tires and lift?
    Curious how far these stick out?
    I thought about 14 wides myself but figured some fiberglass fenders might be needed as most of those fenders give 4-5” more width.
  4. Apr 16, 2018 at 11:26 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Did you go 38's? Damn awesome!
  5. Apr 16, 2018 at 12:19 PM
    SullyMoto19
    Tyler
    Houston, Texas
    Im running an 8" ready lift on 37x13.5s. They stick out pretty good since its -76 offset. I would say 6" at least. It does rub a full crank, but honestly not nearly as much as I thought it would.
    I haven't yet.. my plan is to have it on 38x15.5s by Christmas lol fingers crossed!!
  6. Apr 16, 2018 at 12:24 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Nice! Sounds like a fiberglass fender may help.
    How much room is there in the inside? Is there room to tuck in more with less negative offset?
    Curious cause I Was thinking of a 14-15 wide tire vs that 13.5 your running.
    Haven’t found many folks running a 355 (14”) or 375 (15”) wide tire. Lol
  7. Apr 16, 2018 at 12:35 PM
    SullyMoto19
    Tyler
    Houston, Texas
    I have a good amount of room right now, but there is a lot still left to be done.. I believe fox coils will be next, as well as a 3" body lift. Once I adjust the coils and throw on the BL, should be sitting 12-13" in the front. Should give me plenty to run the tires.
    The 15.5 wides will eat up the body/frame/bumper if I don't get some more height. I want to run the tread down a little more on these 37s anyways, so im not in the biggest of hurries.
  8. Apr 16, 2018 at 12:41 PM
    H**Y CR*p!!!!! MGM + STTs!!!!!
  9. Apr 16, 2018 at 1:34 PM
    Notachickmagnet
    Notachickmagnet New Member
    Just, just. Fricking awesome truck!
    Berdine likes this.
  10. Apr 16, 2018 at 3:26 PM
    Berdine
    Binghamton, NY
    Are happy with the ride now? I remember before you weren't too happy with the way it rides.
  11. Apr 16, 2018 at 3:34 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
  12. Apr 16, 2018 at 3:49 PM
  13. Apr 16, 2018 at 3:54 PM
    CJ21
    CJ21 CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    That's Bad Azz I wanted to upgrade my wheels also I am 20x12 -44 off set I am about a 9' lift on 35's :bowdown: Your truck looks amazing!!
  14. Apr 16, 2018 at 5:24 PM
  15. Apr 16, 2018 at 8:32 PM
    SullyMoto19
    Tyler
    Houston, Texas
    Thanks!!
  16. Apr 16, 2018 at 8:33 PM
    SullyMoto19
    Tyler
    Houston, Texas
    Lmaoooo
  17. Apr 16, 2018 at 8:34 PM
    SullyMoto19
    Tyler
    Houston, Texas
    I'm not sure what is was.. with the last wheels, there was a ton of bed bounce at 65mph+... so I swapped the shocks and it got a little better.. but once we put these new wheels on, bed bounce is gone. Cruising at higher speed feels like I'm floating. Night and day difference, but couldn't tell you what was wrong
    CJ21 likes this.
  18. Apr 16, 2018 at 8:35 PM
    SullyMoto19
    Tyler
    Houston, Texas
    You'll be happy if you do, especially on a 9".. I honestly can't wait to get a little more lift and go bigger lol
    CJ21[QUOTED] likes this.
  19. Apr 16, 2018 at 8:35 PM
    SullyMoto19
    Tyler
    Houston, Texas
    Thanks brotha!
  20. Apr 16, 2018 at 8:36 PM
    :thumbsup:
  21. Apr 17, 2018 at 11:55 AM
    CJ21
    CJ21 CJ-21
    DELAWARE
    What Size wheels would you go with? When you say you would like to go bigger.
  22. Apr 17, 2018 at 1:13 PM
    SullyMoto19
    Tyler
    Houston, Texas
    once i get everything situated and I get the right amount of ride height, im going up to a 38x15.5 tire. but that probably wont be until christmas
