New VLED Amber DRL/Turn Signal Option - Thoughts?
Discussion in 'Lighting' started by MistrRoboto, Nov 7, 2017.
  1. Nov 7, 2017 at 1:48 PM
    MistrRoboto
    MistrRoboto [OP] '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Hey fellas,
    Thinking about adding these to the Christmas list.
    http://www.vleds.com/shop-products/v6-triton/amber/v6-triton-kit-a.html
    New Tundra DRL/Turn Signal LEDs, amber. No cutting required. Add in a "hyperflash fix" for like 20 bucks. Seems pretty sweet.
    I know nearly nothing about lighting, other than I want to sport my amber DRLs nice in bright in the sea of LED light strips on the roads these days.
    Thoughts?
    -Jim
  2. Nov 7, 2017 at 1:58 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    I've had nothing but good luck with VLEDS. I've had the V3 amber in the front and the V3 red in the back for over a year. I've got a set of V6's on order and if I'm impressed enough I'll pick up a set for the back.
    Prostar 190 and MistrRoboto[OP] like this.
  3. Nov 7, 2017 at 2:04 PM
    TheBeast The Beach
    I love vleds products. I have all their LEDs inside the cabin
    MistrRoboto[OP] likes this.
  4. Nov 7, 2017 at 5:51 PM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    I have the VLED DRL Switch backs I bought from a member on here and love them. Best Buy ever.
  5. Nov 7, 2017 at 5:56 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I have two sets of v3’s. One for my truck and other for wife’s truck. Preordered the v6’s. All interior lights are vled.
    MistrRoboto[OP] and TheBeast like this.
  6. Nov 7, 2017 at 6:00 PM
    JRPro
    JRPro Snappin’ necks & cashin’ checks
    Rich
    Austin, TX
    17 TRD Pro CM Cement
    What is hyperflash? I could probably google this, but I’m here...
  7. Nov 7, 2017 at 6:07 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Hyper flash is what happens when you switch from incandescent bulbs to led. Led take way less current to light up. If you don’t put in a “hyperflash” fix aka a 6ohm resister your turn signal will blink rapidly. The resistor burns off the extra current as heat hence the reason for the heat sinks or fins on the outside.
  8. Nov 8, 2017 at 8:20 AM
    MistrRoboto
    Virginia Beach, VA
    Similar to when you see the guy in front of you turning, and his rear blinker is flashing at double the speed of everyone else... you know his front blinker bulb is dead, reducing the load, causing the rear to blink faster.
    JRPro[QUOTED] likes this.
  9. Nov 8, 2017 at 12:07 PM
    MistrRoboto
    Virginia Beach, VA
    How bright am I going to be with these things? I want distinct bright - not annoying/blinding during the day amber DRL bright.
