New Tundra Owner with Questions
Discussion in 'New Member Introductions' started by TundraGuy66, May 18, 2020.
  1. May 18, 2020 at 2:21 PM
    TundraGuy66
    TundraGuy66 [OP] New Member
    Mat
    2020 Cement Tundra TRD
    Hi All. First time Tundra owner here. I got my new cement Tundra SR5 with TRD off road back in January and like a lot of you I have the modification bug. So I am starting with swapping out the grille to a Limited insert (purchased used) with the color matched surround which I got from Roman in Cool Springs. Interesting thing......the Limited grille is from a 2020.....upon removing my current grille, also a 2020, I noticed that the emblems are different on the back side where they attach. After searching the part numbers on the emblems I realized that my new truck has a Land Cruiser grille! (insert at least) Is this a common practice for Toyota? Has anyone ever heard of this happening before?
    Prostar 190 likes this.
  2. May 18, 2020 at 3:30 PM
    Welcome from NY.
    Read Roman's ultimate parts list, he talked about the grill changes.
  3. May 18, 2020 at 4:37 PM
    TundraGuy66
    Mat
    Thank you!
    I did read the "Ultimate Parts" thread and also the "Tundra Grille How To Get What You Want" thread before I started the project and they helped me out a lot.
    If I understand correctly, based on Toyota parts, all 2020 emblems are the same part number regardless of the Tundra build so I expected my 2020 SR5 emblem to swap over to the 2020 Limited insert. It won't fit because it has a different tab configuration so I looked up the part number and found that the emblem from my 2020 Tundra is a Land Cruiser emblem. According to Toyota it does not fit any of the Tundra models.
    Toyota Part 53141 71010 is what is on my Tundra, it should be 90975 02159.
  4. May 18, 2020 at 4:39 PM
    TR15UCK
    TR15UCK New Member
    2020 Cement Limited
    Hey, so here's something I just found out in the past week in speaking to another user. I also have 2020 and bought a 2018 grille but it swapped PERFECTLY, the emblem was a match. Turns out, my truck VIN reveals it came off the production line Summer of 2019. Whereas yours might have come off the production line a little later. They switched the emblems mid-production year!
  5. May 18, 2020 at 4:51 PM
    TundraGuy66
    Mat
    You nailed it....the part number that I listed above does show that it fits a 2019 Tundra.....Thank you!
  6. May 18, 2020 at 4:52 PM
    TR15UCK
    TR15UCK New Member
    2020 Cement Limited
    Yep! Another user even messaged Roman with MY order number and Roman said it shouldn't fit... but once you run the VIN, you see the discrepancy in months that they came off of the line. Pretty shitty of Toyota, but I'm glad I didn't have to buy a new emblem! Anyway, if you need the older style grille, I'm selling my Limited one!
  7. May 18, 2020 at 4:53 PM
    TundraGuy66
    Mat
    Funny that Toyota does not list the Tundra in the fitment section of the part page though!
  8. May 18, 2020 at 4:53 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  9. May 18, 2020 at 4:56 PM
    TundraGuy66
    Mat
    Thank you but I already have purchased the Limited insert...luckily it came with the emblem so I won't have to break the bank on that....I will have to break the bank on other mods!
    TR15UCK likes this.
  10. May 18, 2020 at 6:00 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Welcome from Ontario Canada
  11. May 18, 2020 at 6:50 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Howdy from DFW and :worthless:
  12. May 18, 2020 at 6:58 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  13. May 18, 2020 at 7:03 PM
    Welcome from Ohio
  14. May 19, 2020 at 1:42 AM
