New Tundra= new lighting
Discussion in 'New Member Introductions' started by Wardo714, Dec 30, 2020.
  1. Dec 30, 2020 at 10:58 AM
    Wardo714
    Wardo714 [OP] New Member
    Ryan
    2021 White Trail Edition Crewmax 4x4
    Morning all,
    just picked up the new tundra last week. I have the halogen lighting and I’m looking for recommendations on LED conversion kits. I like at the 6k-6500k lights with the hints of blue to them. Anyone know any good LED conversion kit bulbs out there. Going to do headlights and fog lights.
    here’s a picture of the new rig:
  2. Dec 30, 2020 at 11:00 AM
    chaddydubbs
    chaddydubbs New Member
    Chad
    Omaha, NE
    2017 MGM Tundra SR5 Crewmax
    Tyger running boards, black badge overlays, stubby antenna, TRD Pro grille, window tint, LED interior lights
    Welcome from Omaha! Get the '19 TRD Pro LEDs and use a @iHacker harness :thumbsup:
    ElNopal likes this.
  3. Dec 30, 2020 at 11:25 AM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Welcome from Western NC.
  4. Dec 30, 2020 at 11:35 AM
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
    How Much are you looking to spend? A cheap conversion will be just purchasing the LED bulbs from V-Leds, Headlight Revolution, or Amazon Beamtech or Auxlight...Basically 100-200 bucks to get you all setup.
    The OEM LED lights will run you about $560.00 for the pair, and then you'll need fogs as well. If you're going to get the OEM headlights, you might as well get new fogs from someone like Diode Dynamics, Rigid, or Baja Designs- they all make a great products. Those fogs are anywhere between $200-500 depending.
    There are numerous threads about all of the info I just laid out.
    I personally went with the Beamtech LED lights from Amazon 40.00 bucks, and Diode Dynamics Sport Fog lights 200.00 bucks from amazon.....Both work well, and provide plenty of light. Hope that helps.
    Wardo714[OP] likes this.
  5. Dec 30, 2020 at 12:05 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  6. Dec 30, 2020 at 12:07 PM
  7. Dec 30, 2020 at 12:14 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  8. Dec 30, 2020 at 12:32 PM
    grandmabetty
    grandmabetty New Member
    MN
    2021 Barcelona Red SX
    Interested in this too as I just purchased an SX. So let me understand this correctly. To get LED headlights you can either switch out the entire headlight unit, which is costly, or simply swap out the bulbs and leave the headlight unit untouched (for a low price)
  9. Dec 30, 2020 at 12:48 PM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    Yes, but the OEM LED headlights are intended to be LED and the light will go where it’s supposed to vs. just putting LED bulbs in halogen housings and spraying light everywhere including into oncoming drivers eyes.
  10. Dec 30, 2020 at 12:49 PM
    grandmabetty
    MN
    I see. Thanks for that information. Nothing i hate more than being blinded by an oncoming car. Dont want to be one of those assholes
    Rube207[QUOTED] likes this.
  11. Dec 30, 2020 at 1:56 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  12. Dec 30, 2020 at 2:26 PM
    Most bulbs will create glare in a halogen reflector. Vleds Micros are pretty good. I had them in my 2013. Link is for a 2020.
    https://www.vleds.com/shop-application/application-dual-beam/h4-9003-hb2/micro-evo-h4.html
  13. Dec 30, 2020 at 4:11 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  14. Dec 30, 2020 at 4:46 PM
    Welcome from NY.
  15. Dec 30, 2020 at 5:40 PM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    Welcome and Happy New Year from Central Texas!
    Check out Alla Lighting, a member in here. There was an older post about LED lighting.
    I used JDM Star with no issues for bulb replacement. I have received purchased some Alla bulbs to see how they operate.
    Cannot help you on interior lights because I bought some years back and we're on my 2015. I purchased them off of eBay. When I picked up my new truck, I just switched the out before the '15 left my possession.
    Good luck and congratulations!
  16. Dec 30, 2020 at 7:00 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA.
  17. Dec 30, 2020 at 7:18 PM
    Wardo714
    Ryan
    can I just plug and play or do I need a resistor/canbus type device to install also. I’m being a little lazy and dunno if the 2021 is canbus or not and if it’ll throw error codes if I just plug in an LED bulb without anything else.
  18. Dec 30, 2020 at 7:43 PM
    Welcome from Ohio
  19. Dec 30, 2020 at 8:01 PM
    Shaff777
    Justin
    Boise
    2020 cement SR5
    Just plug in the bulbs- no adapter required for the 2021
  20. Dec 31, 2020 at 10:48 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
  21. Jan 1, 2021 at 2:03 PM
    Wardo714
    Ryan
    Went ahead and bought the VLEDS this morning with the new year 20% off. I’m still not sure what fogs to get. Does anyone have the VLEDS fog bulbs? Any other recommendations ?
