New truck, questions and concerns
Discussion in 'General Tundra Discussion' started by Bronzeback, Feb 27, 2020.
  1. Feb 27, 2020 at 4:21 AM
    Bronzeback
    Bronzeback [OP] New Member
    New to me 2017 platinum, coming from a bunch of ford trucks with eps. For guys that used to drive f150s, or Had them, does the tundra’s steering feel much lighter/looser? I realize it’s not a sports car but it’s kind of sloppy. Also, in my other trucks when I shut the climate controls to “off” no air came out. On this truck regardless of the mode setting, I get hot air trickling out of the vents even while off, Not a big deal just want to know if it’s normal Thanks
  2. Feb 27, 2020 at 4:26 AM
    CyberViking
    CyberViking New Member
    The Ozarks
    2018 MGM Tundra TRD Sport
    Yes and yes
    Lake.Life24 likes this.
  3. Feb 27, 2020 at 5:05 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Welcome from Florida!
    I may have gotten used to the sloppy steering on my '16, but i was coming from an '05 with 255/65k. But you might be due for a shock replacement/upgrade.
    I upgraded my shocks and sway bar on my '20 @ 600miles. Made a big difference in the steering response compared to oem.
  4. Feb 27, 2020 at 5:22 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Welcome from CO.
  5. Feb 27, 2020 at 6:20 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Yes, unfortunately it is normal. It is the only thing I hate about the Tundra. Makes no sense that they choose to design it this way.
  6. Feb 27, 2020 at 6:23 AM
    timsp8
    NY
    The steering feels looser than other vehicles, but I think it’s just the power steering assisting more. I think it’s designed that way to make turning the wheel easier.
  7. Feb 27, 2020 at 6:33 AM
    Welcome from NY.
  8. Feb 27, 2020 at 6:37 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    Welcome! Coming from a '15 silverado and same thoughts. Steering is looser but it reminded me of my '04 silverado which I loved so I am cool with it. The vent thing is annoying to me as well, but something I will live with.
  9. Feb 27, 2020 at 6:52 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    On the vent deal I try to turn the temp up or down, depending, about 5 degrees before I turn the system off. So if I'm running heat/defrost at 80 and I want to turn it off I'll drop it to 75 and when I feel the change I'll turn the system off.
  10. Feb 27, 2020 at 11:58 AM
    Bronzeback
    Thank you, just trying to set a baseline
  11. Feb 27, 2020 at 12:13 PM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    To stop the air coming through the vents turn the recirculating switch on.
    Tundyfundy, Mostel and Black Wolf like this.
  12. Feb 27, 2020 at 12:23 PM
    spn4125
    spn4125 New Member
    ^^ This! I learned this trick years ago on my Xterra which felt like the fan was on low even when it was off.
    Tundyfundy likes this.
  13. Feb 27, 2020 at 12:34 PM
    Ronin73
    Ronin73 New Member
    This doesn't work on my Tundra. :monocle:
  14. Feb 27, 2020 at 12:59 PM
    Tzvia
    Tzvia Just an old woman in a pickup truck.
    Los Angeles County
    2019 5.7L Limited TRD Off Road 4x4
    Just a Bed Rug and Snugtop XTRA Vision
    My current Tundra's steering felt quite a bit 'mushier' when it had the original P rated Michelin tires on it. I swapped out to LT tires and the steering feels much better. Still softer than my 2002 Tundra, but at least it wanders less and tracks better at highway speeds. Before it felt like the tires were marshmallows. My 2002 came with KYB shocks what wallowed a bit like a soccer mom SUV on the high seas and that squishy feeling diminished when I put Bilstein shocks on it. A lot of things can combine here to make or break how the truck feels. Even air pressure in the tires.
  15. Feb 27, 2020 at 2:31 PM
    Mostel
    Mostel New Member
    2020 tundra plat
    Agree w poster who said turn recirculating air on--we have a Lexus and had an Acura--all Japanese vehicles that we have had need this button hit to stop the air coming in
  16. Feb 27, 2020 at 3:32 PM
    Bronzeback
    Lol me either
  17. Feb 27, 2020 at 3:32 PM
    TTund16
    TTund16 New Member
    a little fresh air coming in is good for your health. :D
    i really like the steering response. better than my SUV and Tacoma.
  18. Feb 27, 2020 at 3:35 PM
    Bronzeback
    Swapped the P rated for BFG KO2 in 275/70/18. The wheel just feels like shit at higher speeds.
  19. Mar 4, 2020 at 12:28 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    This alspo works for me. It cuts off outside air.
  20. Mar 6, 2020 at 7:08 PM
    Hayabusa1340
    Hayabusa1340 New Member
    2019 Toyota Tundra TRD Pro
    When you Turn your AC to Off make sure you hit then Button with the Picture of the Car with the Circle in the Middle. It Basically Turns off the Air from the Outside. If you don't Hit that Button it will still Bring in hot Air.
    Basically hit the Recirculation Button. The same Button you hit in the Summer When it 100 Degrees Outside and your want to keep all of you Cool air in.
  21. Mar 8, 2020 at 1:12 AM
    dusted_tundra
    dusted_tundra New Member
    Samuel
    2015 Toyota Tundra SR5 Crewmax
    Icon Stage 5 Suspension Toyo AT 2 Xtremes 35s 18” method Race Wheels
    If it makes you feel any better I removed my sway bar for a smoother ride Offroad
  22. Mar 8, 2020 at 5:21 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome from Central Pa.
