New trd pro owner needs advice!?!
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by 2DBoyz, Sep 14, 2018.
  1. Aug 3, 2019 at 11:18 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Learn something new every day.
  2. Aug 3, 2019 at 6:09 PM
    Andrew19
    Andrew19 New Member
    Andrew
    Baytown TX
    2019 TRD PRO
    Stock
    My advice is....when you go to Lowe's your supposed to park here.20190803_200532.jpg
  3. Aug 3, 2019 at 8:27 PM
    georgiey22
    georgiey22 SW Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Are you running “spat” with your 285’s and Bilstein
    setup at 1.9”? I took mine off with the exact same setup and I also installed a CB bumper spacer. Thinking I may throw them back on but don’t want to rub. Thanks in advance OR18TRD.
    OR18TRD[QUOTED] likes this.
  4. Aug 4, 2019 at 6:44 AM
    Andrew19
    Andrew19 New Member
    Andrew
    Baytown TX
    2019 TRD PRO
    Stock
    Love ur truck Everytime I see it. Man that color...
    Watt maker likes this.
  5. Aug 5, 2019 at 1:39 AM
    Airfire06
    Airfire06 New Member
    2016 trd pro
    Nothing yet
    295/70r18 nitto G2
    Front fender flare remove
    1.25 spidertrax spacer
    It can be done
    Watt maker and jewsNbrews like this.
  6. Aug 6, 2019 at 5:59 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Virginia welcomes you! To me, spacers or a rim with different offset and thicker tires are the best option if you want to keep the stock Fox suspension. Great looking truck btw. :thumbsup:
  7. Aug 6, 2019 at 7:08 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    Welcome from New Hampshire!
  8. Aug 7, 2019 at 2:01 PM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    I had the dealer put on 295/70/18 Ridge Grapplers and they fit fine on my 19 Pro. No rubbing at all. I'm about a fingers width from my UCAs. I did take all the mudflaps off eventually because it makes the truck seem a bit lower than it actually is with them on. Getting my Coachbuiler +3 shackles and 1" shims put on next week and will probably go with 285/75/18 Duratracs for a true 35.
    jewsNbrews and Watt maker like this.
  9. Aug 8, 2019 at 5:43 AM
    Ccwf9787
    Ccwf9787 New Member
    2019 Tundra TRD PRO
    285 70 R18 BF Goodrich MK3, no trimming, no spacers. AWESOME!
  10. Aug 8, 2019 at 3:01 PM
    Andrew19
    Andrew19 New Member
    Andrew
    Baytown TX
    2019 TRD PRO
    Stock
    Can I see an enlarged picture of your setup
