New TRD Pro grill and 32 Inch light bar installed.
Discussion in 'Lighting' started by chiphardbody, Apr 30, 2017.
  1. Apr 30, 2017 at 11:32 AM
    chiphardbody
    chiphardbody [OP] New Member
    Nick
    Virginia Beach
    2017 Tundra Crewmax TRD SR5
    TRD Pro Grill Weathertech Floor Mats 32 Inch LED light bar in grill
    Just installed my TRD Pro grill and 32 inch light bar. I have a question though for all my Tundra buddies, i'm not that good with wires and electronics but, When i wired my harness into the cab, I just kind of moved the big main grommet on the driver side over and slide my wiring harness through there. I feel like thats not entirely right and maybe I should have drilled a hole in there and put it through the middle. I have no idea haha any input ?
    Voyagermike likes this.
  2. Apr 30, 2017 at 11:53 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    I would have cut slit in rubber, but that looks fine. You could clear silicone gaps in that edge. RTV would be too permanent.
  3. Apr 30, 2017 at 11:54 AM
    chiphardbody
    Nick
    Virginia Beach
    I think I'll probably just cut a hole, do I need to silicone around where the slit is where i'm running the wire?
  4. Apr 30, 2017 at 12:05 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Under the bundle of wires in that main grommet there should be a rubber "nipple". If you cut the end of it off you'll have an open path through the grommet.
  5. Apr 30, 2017 at 12:10 PM
    duece292
    Greg
    Green Bay, WI
    Grill and light bar look kick ass btw! :thumbsup:I've been looking at doing the same with mine. What light bar did you go with?
  6. May 1, 2017 at 7:44 AM
    chiphardbody
    Nick
    Virginia Beach
    Thanks ! I ended up just cutting a slit in the grommet, got a little close to the bundle of wires but I don't think I cut any, I mean I haven't smelt anything bad yet lol but I got it from Amazon. Like a 4D LED 32 inch light bar. 32" 4D LED Light Bar 300W with 8ft Wiring Harness Kit, Straight Fish Eey Lens 27000 Lumens Offroad Automotive Spot & Flood Combo Beam Work Light + Adj https://www.amazon.com/dp/B06XFTCHHN/ref=cm_sw_r_cp_apip_z124X82gSyKsv
    Bongskie likes this.
