New to Tundras.com
Discussion in 'New Member Introductions' started by Cbsg78, Jan 16, 2021.
  1. Jan 16, 2021 at 1:36 AM
    Cbsg78
    Cbsg78 [OP] New Member
    Clint
    01 RCLB White v6
    Level kit, bed liner, push bar/brush guard
    Hello all!
    My name's Clint. I love my First Gen Tundra. It's a 2001 V6 Regular Cab Long bed 2x4. It has most of the upgrades available for the base model including tilt wheel, door panel tweeters, cargo lamp, 4speed automatic with overdrive bypass, mud flaps, tow hitch/trailer harness, and locking gas cap. It was originally purchased by Trailer Service & Rental, to be my father's work truck. They made a few modifications by adding ¼" steel plate to the bed rails with 3 steel D-rings welded along each side, a heavy duty headache rack, a cargo rack and bed liner. He drove it for 6 years delivering trailer parts around the Middle Tennessee area. They ran a forklift into the driver side bed but that's just cosmetic lol. They ended up retiring the truck and my dad bought it from them for a great deal considering the wear it had been through. He really only used it to pull his boat around and to haul larger loads than his smaller truck could. In 2014 he gave it to me so I wouldn't have to do construction work out of a minivan any more . Since then I have cut the rack off, swapped out the plastic skid plate for a metal one, added a ram bar/brush guard from a police car, installed a wench, nerf bar step rails, AM-FM/CD/Bluetooth stereo, catalytic converter delete, all new ball joints and bushings/front coil-overs/rear shocks/lower control arms/sway-bar linkage/inner and outer tie-rod ends/wheel bearings/steering rack, and 1" coil-over front lift spacers with 1.5" leaf spring rear lift blocks ( I fear the leaf springs are shot as it's still higher in the front end ).
    The original drivetrain just rolled past 300,000 miles a month ago and it's still running strong. I suspect the rear main is leaking about a half quart of oil every 2-3 months but it's had a bit of a rough truck life so it's to be expected. Overall this truck is bad-ass for a V6 and I love it! I have several other mod projects that I'd like to do with this truck and this forum is great for ideas! Thanks!IMG_20200419_175957.jpg
  2. Jan 16, 2021 at 2:20 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Welcome from Maryland :hattip:
    Sounds like that Tundra has had a HARD life !!
    But glad to hear it’s taking a licking and keeps on ticking
    Good luck with your endeavors
    Cbsg78[OP] likes this.
  3. Jan 16, 2021 at 2:22 AM
    18" TRD Off Road Wheels
    Quite the adventures for that rig. Here's hoping that you have many more with it!
    Welcome from Wyoming.
  4. Jan 16, 2021 at 2:23 AM
    TXTundra2722
    2015 Black Tundra
    Welcome from TX
  5. Jan 16, 2021 at 3:06 AM
    Welcome
  6. Jan 16, 2021 at 4:34 AM
    Welcome from Ohio
  7. Jan 16, 2021 at 4:45 AM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Welcome from Florida.
  8. Jan 16, 2021 at 5:47 AM
    Great intro! Welcome from Colorado.
  9. Jan 16, 2021 at 6:04 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome, Clint, from LA (Lower Alabama)!
  10. Jan 16, 2021 at 6:18 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  11. Jan 16, 2021 at 6:19 AM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  12. Jan 16, 2021 at 6:29 AM
    Welcome from NY.
  13. Jan 16, 2021 at 7:13 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  14. Jan 16, 2021 at 7:47 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  15. Jan 16, 2021 at 8:31 AM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  16. Jan 16, 2021 at 9:50 AM
    ToyAddict802
    ToyAddict802 #ShallowPockets w/BigDreams
    GreenMt. State
    2023 SR5 DC,2023 Tacoma Sr5
    3.5 TRD Lift, TRD 20” wheels with 295/60/20 Falken Wildpeaks
    Welcome
  17. Jan 16, 2021 at 11:24 AM
    CreekDweller
    CreekDweller Not so new ...
    2020 MGM 1794 TRD Off-Road
    Welcome to the forum. One question: How much did it cost to install the 'wench'? ;) I hear they can be expensive.
    Cbsg78[OP] and RainMan_PNW like this.
  18. Jan 16, 2021 at 11:38 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA.
  19. Jan 20, 2021 at 10:51 AM
    Cbsg78
    Clint
    01 RCLB White v6
    I bought a 3500 lb winch with nylon rope from Amazon for $350. It came with a mounting plate that installed without much fuss to the ram bar that I have already installed.
  20. Jan 20, 2021 at 10:53 AM
    Cbsg78
    Clint
    01 RCLB White v6
    On a related note as I was towing the u-haul trailer back a giant deer decided to how hard he could ram into my driver door. Ouch! Takes a licking and keeps on ticking
    Midnite72[QUOTED] and YardBird like this.
