New to me 2003 V8
Discussion in '1st Gen Tundras (2000-2006)' started by badbob, Apr 1, 2025.
  1. Apr 1, 2025 at 8:20 PM
    badbob
    badbob [OP] New Member
    Robert
    Rural Oklahoma
    2003 Tundra V8 4WD Regular Cab SR5 Phantom Grey w/tan interior 210k miles
    None
    I just got this thing. Rust free. I’ve ordered timing belt, water pump, plugs, valve cover gaskets and radiator, all oem. All fluids about to be changed and all 4 O2 sensors and an oem radiator.
    I’m removing the lift kit and installing bilsteins 4600 and Mickey Thompson Baja boss tires.
    two questions…what long tube headers and exhaust could I order to make it a little quicker and sound better, any recommendations? Is this worth it?
    Second question: should I order the polyurethane steering bushings and if so, from where?
    thanks for any info
    mcharfauros likes this.
  2. Apr 1, 2025 at 8:23 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  3. Apr 1, 2025 at 8:40 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Longtubes without tuning can become an emissions/o2 sensor headache, it is fun and improves performance.
  4. Apr 1, 2025 at 8:51 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    Keith @dirtydeeds could certainly give you some good advice on the headers and probably the bushings as well.
    He is a forum vendor.
    Dirty Deeds Industries
    KNABORES and ColoradoTJ like this.
  5. Apr 2, 2025 at 4:31 AM
    Bmktw2
    Bmktw2 Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    Don't overlook checking the LBJs
  6. Apr 2, 2025 at 5:12 AM
    badbob
    Robert
    Rural Oklahoma
    None
    The mechanics said the lbj’s look fine…maybe I should just have the replaced while it’s at the shop….
    but since I am removing this 3” lift kit I am wondering if I am going to neeed new sway bar links?
    if long tube headers and exhaust require tuning I’m probably going to pass on those
  7. Apr 2, 2025 at 6:24 AM
    LBJs fail on these trucks w/o warning. DO NOT, under any circumstance, allow anyone to install aftermarket / non-OEM LBJ. Read the first two replies of the thread @Bakershack shared. We as a community have seen some shit. A lot of the pictures of said shit (LBJ fail) are linked in that thread. It's not a joke in these trucks. It's not hype. Some people got lucky. Chances are, you or I won't be one of those lucky people.
    Depends what's on there now. Also depends on what size tire.
    What's the current 3" lift?
    What size tire are you planning on using?
    Are you planning on using a lifted spring with the 4600s?
    Need to know this to advise you. But again, see the link Bakershack gave. Be sure to read over the "suspension wheel & tire" section carefully.
    Long tube require cat delete. Unless you can find a way to O2 sim, or program out stuff in your ECU, you're going to be perpetually fighting with check engine lights related to AFR/O2/cat.
    The Black Mamba likes this.
  8. Apr 2, 2025 at 6:40 AM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    I haven’t seen much gain from Toyota engines with just headers. Now add forced induction of any type and yeah buddy gains. There’s the sound factor, but cat back can sound pretty Knarly too.
  9. Apr 2, 2025 at 7:02 AM
    badbob
    Robert
    Rural Oklahoma
    None
    The lift is a rough country or tough country i forget, it is using blocks.
    I bought the Bilstein 4600 set from a link I saw from Shifty on here right before I joined, they are stock height springs from suspensionlifts.com. The tires are Mickey Thompson Baja Boss 265/70/16's.
    (Bilstein 4600 Front Assembled Coilovers with OE Replacement Coils and Rear Shocks for 2000-2006 Toyota Tundra)
    I don't want it lifted, part of the appeal is the easy unloading/loading and smaller size of the 1st gen with the 8 foot bed.
    With shocks, tires and parts/labor I'm around 4500 bucks, these LBJ failure threads are concerning..
    **Is there a link to some good LBJ's I can order and from what you can tell from my info should I order new sway bar links or any other suspension items for the lift kit removal?
  10. Apr 2, 2025 at 7:57 AM
    There's a massive difference between Tuff Country and Rough Country. Rough Country usually uses silver shocks/struts with the N3 logo on them. Like THESE. They sometimes mix struts and strut spacers (which is a huge fucking no-no) to achieve lift. Their kits almost always use rear blocks.
    Look - if you want help, I'm going to reiterate this. Get us pics of your current setup. And fill in some blanks here:
    1. Multiple pictures of your front suspension: Top of the strut tower where the 3 bolts are so we can see if there's spacers, the swaybar links and LCA, the lower strut mounts, just shoot everything.
    2. Pics of your rear suspension: Overall shot of your rear axle so we can see what's at play back there for blocks/spacers, if there's anything else going on.
    3. And finally: Tell us your goal. Are you simply wanting to get back to OEM ride height? What size/type of tires are you wanting to run? Which wheels do you currently have, specifically, so we can figure out offset/backspace? Knowing this is the only way anyone here will be able to give you good, quality advice so you're walking out of this happy.
    If it were me, I think our trucks sit about ½"-¾" too low in the front from the factory, with OEM ride height. And I think the best possible upgrade anyone could run, to fill that gap, is the 4600 or 5100 Bilstein using OME's 2883 coil, which as someone covered recently, requires a different spring isolator (can get the part number), and of course, swapping out the springs.
  11. Apr 2, 2025 at 8:17 AM
    badbob
    Robert
    Rural Oklahoma
    None
    IMG_8584.jpg IMG_8583.jpg IMG_8582.jpg IMG_8580.jpg IMG_8579.jpg IMG_8577.jpg IMG_8574.jpg IMG_8572.jpg I want oem as of right now. Here are the pics, thanks for taking the time to help me.
  12. Apr 2, 2025 at 8:19 AM
    badbob
    Robert
    Rural Oklahoma
    None
    the tires i ordered are 265/70/16
  13. Apr 2, 2025 at 8:24 AM
    Ok looks like no spacers up front and a 2" block in back. Ultimately it's their 2.5" lift kit. The PO even installed it correctly with the LSPV relocation bracket. That's nice to see, even if the lift isn't great.
    You'll want to pull the blocks out back when you install your 4600s, if that's the route you're going. You'll need shorter U-bolts to boot, something stock length (I can get OEM part# if you need it).
    If lowering the rear, you'll want to pull that LSPV relocation bracket while you're in there.
    I think you should be able to run that tire size with minimal rubbing, but there are two factors in whether that is truth: 1) Your alignment numbers and 2) your wheel specs.
    What's the current tire size? Do you know which model of whell that is?
  14. Apr 2, 2025 at 8:32 AM
    badbob
    Robert
    Rural Oklahoma
    None
    Current tire size is 286/75/16
    Here’s a pic of the wheel. It’s 17” diameter from outside edges of the lipIMG_8585.jpg
  15. Apr 2, 2025 at 8:39 AM
    badbob
    Robert
    Rural Oklahoma
    None
  16. Apr 2, 2025 at 8:39 AM
    I think those are the Toyota 4Runner 16" Enkei wheels?
    I'd need to dig up specs. Running out to a job, though. I'll check in on it later if nobody else is able to answer. More than anything, I'm just wondering what the width and offset are so we can figure out backspacing and see if the upsized tire @ 265/70r16 (@30.6" so stock) won't be a rub risk, given there won't be any lift involved.
  17. Apr 2, 2025 at 9:07 AM
    badbob
    Robert
    Rural Oklahoma
    None
    Thanks a LOT for the help. Just ordered the correct color drivers side female seat belt assy to get rid of the flashing light. The contact cleaner didn't work. The burned out "D" light on the dash can wait. I assume the 265/70/16's wont rub at oem height??? It didn't occur to me these wheels weren't oem, I've only had it 2 weeks.
    I could use those number for the U-bolts if you have em, I'll order them
  18. Apr 2, 2025 at 10:08 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    That is stock size so as long as your wheel offset doesn't screw you then it should be fine. You should be able to recoup some of your money reselling your current tires that look nearly new, as well as selling your lift kit you have now.
  19. Apr 2, 2025 at 11:10 AM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Where did you get those blue PU sway bar bushings from? (asking for a friend)
  20. Apr 2, 2025 at 12:10 PM
    badbob
    Robert
    Rural Oklahoma
    None
    Shoot I just noticed them when I was taking the pics! I just recently purchased this.
  21. Apr 2, 2025 at 1:12 PM
    Shit, I plugged 17 in the calculator instead of 16. You're right.
  22. Apr 2, 2025 at 1:17 PM
    badbob
    Robert
    Rural Oklahoma
    None
  23. Apr 2, 2025 at 1:19 PM
    badbob
    Robert
    Rural Oklahoma
    None
    anyone have part #'s for stock U bolts and some good LBJ's? Those failed lbj pics on this site got me worried...
  24. Apr 2, 2025 at 1:25 PM
    To go full OEM again?
    Exploded EPC for random V8 2003 RCLB @ https://toyota-usa.epc-data.com/tundra/gsk50/3906/chassis/4804/
    You'll need four of these: 90117-A0004
    And eight of these: 90178-A0050
    And eight of these: 94622-51400
    NOTE: That website is going to show you the **MSRP** price, not the final price.
    If you want free shipping and no tax, order the parts from THIS NATIONAL SITE and you should be able to get out the door for right around $100 given the 25% off sale they have going on for the next week or so, and their already-substantial discount below MSRP.
    The full discount WILL NOT show up until you reach the "Checkout" page.
    Kalannar97 likes this.
  25. Apr 2, 2025 at 1:35 PM
    Fedtime
    Fedtime New Member
    Another option: a local spring shop.
    My local spring shop made up a set of unbolts, and supplied new nuts and washers for well under $100CDN. They fit perfectly and were very heavy duty. The shop does spring work for transport trucks, dump trucks, etc so everything they do seems to be good quality.
    rouxster70 and shifty` like this.
  26. Apr 2, 2025 at 1:36 PM
    badbob
    Robert
    Rural Oklahoma
    None
    just ordered them for 100 bucks, looking for lbj's on there now, do they need new bolts or anything?
  27. Apr 2, 2025 at 1:38 PM
    badbob
    Robert
    Rural Oklahoma
    None
    upload_2025-4-2_15-38-3.pngthis all I need?
  28. Apr 2, 2025 at 2:17 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
  29. Apr 2, 2025 at 2:29 PM
    Always new bolts.
  30. Apr 2, 2025 at 4:00 PM
    badbob
    Robert
    Rural Oklahoma
    None
    got everything ordered. Can't think you guys enough, thanks Shifty. I'll send pics of the spectacular OEM build in a few weeks! Also will have a lift kit and new tires I'll need to unload if anyone wants it cheap, I am near OKC
    shifty` likes this.
