New to me 2001 4x4 5spd V6
Discussion in '1st Gen Tundras (2000-2006)' started by Bmktw2, May 16, 2023.
  1. May 29, 2023 at 11:47 AM
    #211
    Bmktw2
    Bmktw2 [OP] Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    These are the original knuckles just cleaned
  2. May 29, 2023 at 1:06 PM
    #212
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
    So I got on car-part.com just to check, and searched for my truck (2001 4x4 w/ABS) for "Steering Knuckle" and the description in the parts that turned up is "Spindle/Knuckle Assembly, Front", and it shows me everything from 3rd gen 'Runners to 1GTacos to our trucks to 1GSequoias. So it could be something where the junkyard interchange number is the same for those, idk?
    Bmktw2[QUOTED][OP] likes this.
  3. May 29, 2023 at 1:44 PM
    #213
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I think the early model years with the smaller lower ball joints might be interchangeable.
    Bmktw2[OP] and Casper421 like this.
  4. May 29, 2023 at 4:45 PM
    #214
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    small ball crew in the house!
    Jack McCarthy and Bmktw2[OP] like this.
  5. May 29, 2023 at 6:34 PM
    #215
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Tonight I purchased new wheel bearing, inner and outer seals, an inner axle boot, a thermostat and fipg sealant. I'm going broke!
    shifty`, w666 and Jack McCarthy like this.
  6. May 30, 2023 at 3:23 PM
    #216
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    So here I am with the passenger side CV axle.
    I drained the fluid, pryed the axle a little then drive wedges in opposite sides behind the shaft until it popped free.
    Upon observation I'm wondering if this may be a good time to replace the outer differential seal?
    How difficult is that to do? Looks pretty straight forward. Pry out and tap new in ...?
    Secondly, I noticed the retaining clip looks pretty loose and a little beat up. What does this clip originally look like? Is this normally so loose?
    My plan is to replace the outer CV axle dust seals and the inner CV boot.
    The Black Mamba, bmf4069 and w666 like this.
  7. May 30, 2023 at 4:48 PM
    #217
    Those clips are pretty loose on the CV, yours are probably fine.
    The outer seal is easily removed with a seal puller tool. Replacement is easy, but you have to set it back at the right depth.
  8. May 30, 2023 at 7:44 PM
    #218
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Please note @Bmktw2 you have to set it at the right depth this is no joke. Exactly back to where it belongs. I had to do mine twice.
    bmf4069, w666 and Bmktw2[OP] like this.
  9. May 30, 2023 at 9:28 PM
    #219
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Clips are designed to be lose
    you should check prices on both half shaft, it's not that expensive
  10. May 31, 2023 at 5:45 AM
    #220
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Last I checked they were $500 each from Toyota. Either way this truck project is over budget and so just going back in with some new seals and a boot. Will get the new CV axles knuckles and brakes maybe next year
  11. May 31, 2023 at 8:57 PM
    #221
    NickB_01TRD
    Nick
    KY
    You can get reman axles for somewhere around $90 IIRC from Toyota. A few guys on here have gotten them and reported good quality. Though I understand why you might wait to save on the funds.
    Link about reman axles LINK
  12. Jun 5, 2023 at 11:46 AM
    #222
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I used a headlight restore kit to clean up the headlights. Here's before and after.
    Jack McCarthy, Silet, Mr.bee and 3 others like this.
  13. Jun 5, 2023 at 11:50 AM
    #223
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Thanks to Silet (the PO) gave me a Chilton's manual and the original window sticker for the truck yesterday
    N84434, Silet, w666 and 3 others like this.
  14. Jun 5, 2023 at 11:54 AM
    #224
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Bought a Toyota boot kit. Cleaned and regressed the CV then replaced the boot.
    Tapped the new dust seal on with rubber mallet and the old inner knuckle seal
    Silet, DJenerated, Mr.bee and 3 others like this.
  15. Jun 5, 2023 at 12:30 PM
    #225
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I removed all the badges off the truck...
    Then got a slick little decal to install on the bed.
  16. Jun 5, 2023 at 7:22 PM
    #226
    NickB_01TRD
    Nick
    KY
    How did the paint look underneath? Still able to see where they were?
  17. Jun 5, 2023 at 7:30 PM
    #227
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    Who's your friend?
  18. Jun 5, 2023 at 8:44 PM
    #228
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I pressure washed the old double-sided tape residue but have not done anything beyond that. Going to use goo-gone or alcohol to remove the last bit of it then maybe wax the truck with a buff wheel, either way it looks fine.
    NickB_01TRD[QUOTED] likes this.
  19. Jun 6, 2023 at 2:23 AM
    #229
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  20. Jun 6, 2023 at 9:00 AM
    #230
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I pressed the old spindle out and on it's way it crushed the bearing into pieces and bent the c-clip. The bearing race seems to be siezed on the spindle.
    Now I have to figure out how to get the old bearing race off. None of my bearing separators fit this size...
  21. Jun 6, 2023 at 9:12 AM
    #231
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I just went with new hubs when I did mine.
    Jack McCarthy and shifty` like this.
  22. Jun 6, 2023 at 10:04 AM
    #232
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Used my metabo grinder, cut the bearing race paper thin, used a chisel and hammer started a crack and just beat it out with the hammer and chisel.
  23. Jun 6, 2023 at 10:43 AM
    #233
    My man is resourceful.
    FirstGenVol and Bmktw2[OP] like this.
  24. Jun 6, 2023 at 10:50 AM
    #234
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    He's like Scotty, link ur channel let us sub...:D:D
    Bmktw2[OP] likes this.
  25. Jun 7, 2023 at 12:28 PM
    #235
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Moving along...
    Done
  26. Jun 8, 2023 at 6:24 PM
    #236
    Looks good, but I'm a little sad, my OCD's jimmies are rustled over that spot you missed on the top of the knuckle.
    bmf4069 and Bmktw2[OP] like this.
  27. Jun 8, 2023 at 8:14 PM
    #237
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Shifty,
    Two-tone knuckle
    shifty` and bmf4069 like this.
  28. Jun 10, 2023 at 6:06 PM
    #238
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Got it back on its wheels.
    Seems taller than what it used to be... Lots of wheel well here
  29. Jun 10, 2023 at 6:55 PM
    #239
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    So I'm looking at these lower control arm camber adjusting eccentric because I noticed the passenger side wheel sits perfect but the driver side wheel seems to be too much positive camber.
    Can anyone tell me, by looking at these photos something?
    Drivers side
    Passenger side
  30. Jun 10, 2023 at 7:41 PM
    #240
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Pass is fully outwards. Drivers is about halfway and 2/3 way inwards.
