New to me 2001 4x4 5spd V6
Discussion in '1st Gen Tundras (2000-2006)' started by Bmktw2, May 16, 2023.
  1. May 26, 2023 at 5:10 PM
    #181
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Got some.
    Also have a set of regs from bmf. Are the regs 650lb/in?
    bmf4069 and Bmktw2[OP] like this.
  2. May 26, 2023 at 5:24 PM
    #182
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Grandpa is a pretty smart fella, added some twisted wire to the boot flanges.
    Zoroaster and Bmktw2[OP] like this.
  3. May 26, 2023 at 5:27 PM
    #183
    Bmktw2
    Bmktw2 [OP] Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    Mr.bee likes this.
  4. May 26, 2023 at 5:29 PM
    #184
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Wholly shit theres alot of yankee on that truck.
    Zoroaster, bmf4069, shifty` and 2 others like this.
  5. May 26, 2023 at 5:33 PM
    #185
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I thought mine were bad. Now I don't feel so bad anymore. :D
    bmf4069 and Bmktw2[QUOTED][OP] like this.
  6. May 26, 2023 at 5:46 PM
    #186
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Superleggera.
    bmf4069 likes this.
  7. May 27, 2023 at 6:26 AM
    #187
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I 100% agree. Way to many scam parts on scAmazon. Put good eyes on all those parts and put up pics.
    Bmktw2[OP] likes this.
  8. May 27, 2023 at 9:26 AM
    #188
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
  9. May 27, 2023 at 9:35 AM
    #189
    Ugh, I assumed it was Rancho based on the boot. What shit.
    Notice any obvious difference in the ride? I'm assuming it should be a little less harsh with those Ranchos off.
    Bmktw2[QUOTED][OP] likes this.
  10. May 27, 2023 at 9:41 AM
    #190
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    When I compressed the ranchos they we're pretty much stuck down and really difficult to pull up.
    I'm sure these will make the suspension move much more freely and responsive
    I think she is due for a couple new leaf packs soon
  11. May 27, 2023 at 2:18 PM
    #191
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Pulled the front tires off for the first time ...
    One of the CV axle boots is torn wide open
  12. May 27, 2023 at 2:19 PM
    #192
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Those look like 13wl brakes to me. Score!
  13. May 27, 2023 at 2:32 PM
    #193
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Yes Silet the previous owner put the later newer style better brakes on it
    JasonC. and Mr.bee[QUOTED] like this.
  14. May 27, 2023 at 3:38 PM
    #194
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
    That slanged-out grease probably kept some of that rust at bay! Did you see if any grease still in there? A few threads on here about replacing CV axle boots. General consensus seems to be that our original CV axles are better/heavier than anything aftermarket, and thus if you are replacing more than just the boot, the remanned ones are the way to go.
  15. May 27, 2023 at 7:26 PM
    #195
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    While I'm waiting for the timing belt kit, I decided to do the suspension work.
    The parts were so rusty and stuck together. It took my breaker bar, penetration spray, lots of grunts and cuss words to get these parts off. It was one heck of a fight, but I am victorious
    Soupbean77, Mr.bee, Silet and 3 others like this.
  16. May 28, 2023 at 8:05 AM
    #196
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    And the passenger side:
    JasonC., bmf4069, shifty` and 2 others like this.
  17. May 28, 2023 at 10:33 AM
    #197
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Really dissatisfied with the condition of this part.
    Left and right are both equally very rusted. The dust shields are completely gone.
    Is this a junkyard part?
    What is it called?
    Is the 2wd part the same as the 4wd part just with a plug on the back?
    Don't want to go back with this part, looking to replace somehow if possible. Thanks
  18. May 28, 2023 at 10:41 AM
    #198
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  19. May 28, 2023 at 10:48 AM
    #199
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You can still buy them from Toyota last I looked but they were around $400/side.
    There is a guy making custom ones with new wheel bearings pressed in. Not sure what he charges. His name is Jim Smola.
    I would not install those back on my truck either. You could try to pull some from a junkyard too. Maybe consider having new bearing pressed in.
    Jack McCarthy and Bmktw2[OP] like this.
  20. May 28, 2023 at 1:08 PM
    #200
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Can I get these hubs from a late 90's 4runner? There's several at the u-pull junkyard in my town. Zero tundras.
  21. May 28, 2023 at 1:21 PM
    #201
    The steering knuckle is probably not the same between the T4R and Tundra. One way to verify would be to pull the part number for your Tundra, and look at parts compatibility lists online to see if it's the same.
    Note that 2WD trucks came with spindles, which won't work with your 4WD. Same part for 4WD is typically called the steering knuckle or just "knuckle". Donor would therefore need to be 4WD, since a knuckle doesn't exist on 2WD.
    I tend to agree, these won't sandblast out and should be replaced. The steel is flaking off in droves, which is no bueno.
    You may also want to try searching at www.car-part.com for a donor vehicle near you.
  22. May 28, 2023 at 1:30 PM
    #202
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Thats an older Toyota pickup or Tacoma thing. The 2wd ones that were 5 lug instead of 6.
    Iirc our first gens use the same knuckle assembly for 2wd and 4wd, just the 2wd has a cap to keep the wheel bearing clean.
    shifty`[QUOTED] and Bmktw2[OP] like this.
  23. May 28, 2023 at 3:06 PM
    #203
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Thats what I though is the 2wd has the same knuckle with a removeable cap on the inside...
    The advertisement Mr. Bee listed for the steering knuckle says it's interchangeable with the 1996-2002 4runner also. I saw a couple 4runners at the junk yard I might go get them
  24. May 28, 2023 at 6:05 PM
    #204
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    The scamazon asin timing kit showed up. Here's the photos. Looks legit to me. The bearings are sealed and have the holograms etc...
    w666 likes this.
  25. May 29, 2023 at 8:48 AM
    #205
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Chiseled off the bolts, all the flaking rust off and then wire brushed. Going to paint and reuse for now. I'm over budget on this project.
    For now just getting these knuckles get cleaned up and reboot the CV axle with torn boot. Next year I'll get new oem CV axles, knuckles, splash field, wheel bearing kit and new brakes
    Primer
    And paint
    ...and of course the seal is bad:
  26. May 29, 2023 at 9:06 AM
    #206
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Are those 4runner knuckles? Identical?
  27. May 29, 2023 at 10:10 AM
    #207
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    Oh this reminds me, I've been wanting to ask: what paint/primer/epoxy/whatever stuff do you folks -- especially interested in our Yankee driveway engineers' input here -- use for suspension components? I will be taking as many of mine as I can down to bare metal if possible and I'd like to paint/coat them when I'm done.
  28. May 29, 2023 at 10:24 AM
    #208
    This is what I originally recommended a few pages back, they cleaned up better than I thought. I was skeptical when I saw all that flaking and was 2nd guessing that reco with your most recent pics.
    If you have a simple tap & die set, be sure to clean out the holes after painting and before reinstall. You'll be thankful later. The same Rustoleum Satin you used on the bumper will lay look great on the knuckles.
  29. May 29, 2023 at 11:01 AM
    #209
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    dad used this on his dirtcar back in the 80's. When i find rust i hit it with a flap wheel & ospho, then paint.
    https://www.acehardware.com/departm...hHcp8pm3qLWfytLS93waAmmnEALw_wcB&gclsrc=aw.ds
    Bmktw2[OP] and JasonC.[QUOTED] like this.
  30. May 29, 2023 at 11:20 AM
    #210
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
