New to me 2001 4x4 5spd V6
Discussion in '1st Gen Tundras (2000-2006)' started by Bmktw2, May 16, 2023.
  1. May 18, 2023 at 9:06 AM
    #61
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Did the truck come with an owners manual? That should help explain the 4WD system. It may also be written on your driver side sun visor. You're lucky in that you have a manual transfer case instead of the push button most of us have.
    Bmktw2[OP] likes this.
  2. May 18, 2023 at 9:13 AM
    #62
    Bmktw2
    Bmktw2 [OP] Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    This is on the visor
    shifty` likes this.
  3. May 18, 2023 at 9:17 AM
    #63
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I had not looked in the glove box before.
    I found all this:
  4. May 18, 2023 at 10:29 AM
    #64
    That is literally what most of us would love to see in ours, especially the maintenance folder.
  5. May 18, 2023 at 11:07 AM
    #65
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Porn isn't allowed on the forum. You need to remove this pic. :D
  6. May 18, 2023 at 2:04 PM
    #66
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    JasonC. and shifty`[QUOTED] like this.
  7. May 18, 2023 at 2:15 PM
    #67
    Thankfully not one of my vices.
    dbittle and bmf4069[QUOTED] like this.
  8. May 18, 2023 at 8:18 PM
    #68
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Would this be a good choice?
  9. May 18, 2023 at 8:20 PM
    #69
    Are they for an AC?
    Bmktw2[QUOTED][OP] likes this.
  10. May 18, 2023 at 8:23 PM
    #70
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Yes a 4x4 used daily driving all around
  11. May 18, 2023 at 8:27 PM
    #71
    I mean are those specific shocks you posted for an AC? The springs will be different for an AC and a DC.
  12. May 18, 2023 at 8:28 PM
    #72
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
  13. May 18, 2023 at 8:44 PM
    #73
    Hmmm. Doesn’t specify. Does say fits 2000-2006, and the DC wasn’t available until 2004.
  14. May 18, 2023 at 8:47 PM
    #74
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I want to daily drive this truck to work, keep the ride height right around stock. Don't want more than 1"-2" lift max. Due to rust, I need to replace the UCA, front shock assembly, rear shocks and leaf springs. Could someone please recommend me a good setup and a reliable place to purchase them from?
  15. May 18, 2023 at 8:50 PM
    #75
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    bmf4069 and Bmktw2[QUOTED][OP] like this.
  16. May 18, 2023 at 9:02 PM
    #76
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If you want no lift the link you posted to the yellow 4600s with springs on them are a great choice. If you go with these, all you need is stock style UCA's. Unless someone on here is willing to sell you their old OEM arms (after they upgraded) you'll probably want to go aftermarket on these, I feel like OEM Toyota will be pricy but you'd have to check.
    If you want any lift that's a whole other can of worms with many different options. If you'll never go more than 1 or 2 inches then you'll be fine with a stock UCA regardless.
    I'd jump on those lower ball joints ASAP even if you do those before everything else. You really don't want those to come apart. Looks like you definitely need new bolts. 9008010066 (QTY 8) is what you'll need for that. These are single use only bolts (there's a thread about this but it's a little long winded).
    As far as leaf springs, unless they are about to rot away completely, are cracked, or you're planning to tow a lot, I'd leave them be.
  17. May 19, 2023 at 6:06 AM
    #77
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Here some shots from under the truck.
    I can't find the fill plug on the front diff and also there seems to be some sort of electrical device attached to the differential. I wonder if anyone knows what that is?
    Also the motor oil has a wired drain valve looking thing. Is that normal?
  18. May 19, 2023 at 6:14 AM
    #78
    Weird drain valve thing is a Fumoto style easy drain valve. Not a bad thing.
    The electrical thingy on the front diff is likely an actuator / position indicator for the 4wd system so it knows if it’s engaged or not. Your transfer case is manual but the front diff still needs an actuator since you have full time engaged front hubs.
    The fill plug for the front diff is usually mid way up or so on the inner side of the diff closer to the output shaft on the right. Might be that visible rusty spot on your pic.
    shifty` and Bmktw2[QUOTED][OP] like this.
  19. May 19, 2023 at 7:23 AM
    #79
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Looks like a new front bumper was installed with the new chassis. But the paint Toyota puts on their metal is total junk. That's the problem with their chassis and parts rusting so badly is they don't paint their parts properly. I'm going to be taking this bumper apart and using some Rust-Oleum paint to make it decent ... I wonder if I can paint over the surface rust?
  20. May 19, 2023 at 8:38 AM
    #80
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Start with this.
  21. May 19, 2023 at 9:09 AM
    #81
    4600s will keep you at stock height, so same setup as now, a little natural 0.5-1.5" rake toward the front, depending. I beleive you can pair the 4600 with lifted springs if you want a bit more, but don't quote me on that. Josh @ 1stGenOffroad should be able to answer that. If I were you I'd probably look to stuff an OME 2883 spring in there, and Josh can pre-load for you, I believe. He's got the setup in his shop to do it. OME 2883 with your access cab, 4WD, and V6 should give you about an inch up front, +/- 0.25". Not enough to need new UCA or extended links.
    I was about to comment on the drain too - @Bmktw2 find a rubber hose that'll fit into the tip of that. To drain your oil, all you need to do is open the valve while the tube is in your drain pan. I'd recommend leaving that thing on there, no need to change your drain plug bolt or washer as a result!
    Also, looks like your transfer case ("TC") could use a wipe down and potentially new washers. It looks like whoever drained/filled the fluid last time either didn't clean up after, or used old washers, or didn't torque to spec. Careful, don't over-torque on the TC drain/fills, you can definitely strip them. Here's the drain/fill plugs (always open fill plug first, don't want to get caught with no way to refill!!) and the oil staining in question ... seems to start below the fill, so maybe it's from its last refill, but ... take a close look in this area to be sure. Brass brush will get all this shiny again.
    And depending what finish you're going for, their outdoor is great. This satin matches OEM frame and body paint perfectly in its sheen and color - but maybe you don't want to go flat-ish looking. Lay down the stuff he linked, sand it, use prep to clean, then lay this.:
    JasonC. and Bmktw2[QUOTED][OP] like this.
  22. May 19, 2023 at 9:14 AM
    #82
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I just left the store and notice the post. I hope this will work just as well. I plan to wire wheel the rust first then hit it with this primer and paint
  23. May 19, 2023 at 9:14 AM
    #83
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Clean everything as good as you can. Like several days and multiple applications of degreaser and elbow grease. Once everything is clean leaks are easier to find. Everything is easier to eyeball.
    just dont forget to regrease the stuff that needs it. And tread lightly near electrical or vacuum stuff. Dont wanna dry out thise hoses.
  24. May 19, 2023 at 9:30 AM
    #84
    It's perfectly fine. All depends on the look you're going for. Also, get a can of paint prep spray, lint-free towels, and a wet/dry sand variety pack if you want a better-than-backyard result.
    I've probably D-A sand or wire wheel the rust off. Smooth sand to finish in the 150-300 grit range, paint prep the face, then lay down several light coats of the rusty metal primer within the recoat window given on the can (have a timer ready), or use whatever process they recommend. Respect the cure time on the can once the last layer goes down. After a full cure period, sand any runs to smooth it out, then paint prep the face again, and repeat the previous instructions with the gloss, again respecting the recoat window and cure times. Full cure time may be days, not hours, enamels tend to be a little soft and easy to dent for days and sometimes weeks after. They also maintain elsaticity for years after that.
    If you want to paint-match, I've used https://www.automotivetouchup.com/ on a couple of vehicles now and generally been happy with their product. Just don't go too overboard, you can get a new front bumperskin for less than $200, even in chrome. I got my rear bumper in chrome shipped from Summit Racing for $196 + free ship + tax a few years back, brand was Coast to Coast International, who makes a lot of aftermarket bumper skins. It's held up really well, chrome seems nice and stout.
    And a few coats with a wait time in between will bring back that grey ass trim to its original dark charcoal grey color: https://www.griotsgarage.com/black-shine-trim-restorer-8-ounces/
  25. May 19, 2023 at 9:37 AM
    #85
  26. May 19, 2023 at 9:40 AM
    #86
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Allow me a decent distraction.
  27. May 19, 2023 at 10:06 AM
    #87
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Clean
    Primer
    bmf4069, shifty` and KNABORES like this.
  28. May 19, 2023 at 10:07 AM
    #88
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    That looks super clean!
    You removed the plastic parts?
  29. May 19, 2023 at 10:25 AM
    #89
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    He did. I just removed everything.
    Tacoma-Tundra likes this.
  30. May 19, 2023 at 10:40 AM
    #90
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    That's a good look. Should take the hood off too that would be epic
    SharkDog, bmf4069, shifty` and 2 others like this.
