New to me 2001 4x4 5spd V6
Discussion in '1st Gen Tundras (2000-2006)' started by Bmktw2, May 16, 2023.
  1. Aug 9, 2023 at 11:59 AM
    #661
    Looks so much skinnier. Is it greasable? I'm not seeing zerks.
    NFC what that cap was, unless that's what was covering the carrier bearing, what they used to pump it with grease or something before assembly? I don't recognize it, but virtually every driveshafts I've picked up was single-piece, taken off a used vehicle, and if it needed shortening, I carried it to a shop.
    Pro tip: Doublecheck the torque on your bolts after 100, 200, 500 miles, with special attention to the two carrier bearing bolts. Just make sure they're in-spec. If you didn't already have TQ numbers, someone here can grab for you (or you can look in the FSM, which I think you have already)
    Bmktw2[OP] likes this.
  2. Aug 9, 2023 at 12:12 PM
    #662
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Look in your old driveshaft And see if Theres a plate that keeps grease in the splines and out of the tube.
  3. Aug 9, 2023 at 12:40 PM
    #663
    Bmktw2
    Bmktw2 [OP] Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    There's one grease fitting on the back for the yolk.
    The rest are lifetime
    shifty`[QUOTED] likes this.
  4. Aug 9, 2023 at 1:33 PM
    #664
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Just got off the phone with the Doorman company. They have good customer service. They said the loose part is a dust cap for the back of the slip yolk... He said he could replace the whole driveshaft or I could tack weld the cap in place... I decided to weld the cap in
    G_unit3000 and JasonC. like this.
  5. Aug 12, 2023 at 12:26 PM
    #665
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Welded the cap on the slip yolk. Truck running smoothly. Now heading to ginnie springs then ponte vedra FL on Sunday night to start my new job Monday morning.
    G_unit3000, dbittle, bmf4069 and 3 others like this.
  6. Sep 2, 2023 at 10:18 AM
    #666
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Got a 19' TT for work in Pensacola.
    The Tundra does great pulling it.
    With cruise control in 4th gear at 3k rpm does 65mph no problem without any weight distribution bars
  7. Sep 3, 2023 at 11:22 AM
    #667
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Just over 3,000 miles on this oil and it is still hunny color. What a great engine
    G_unit3000, JasonC. and Silet like this.
  8. Sep 3, 2023 at 11:28 AM
    #668
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    The v8 does it too. My trucks used oil gets used in mowers & chainsaws & whatnot.
  9. Sep 3, 2023 at 12:47 PM
    #669
    Silet
    Silet New Member
    It was always like that. Switched to synthetic when I first got it.
  10. Sep 8, 2023 at 1:15 PM
    #670
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Working on installing this trailer brake controller
  11. Dec 22, 2023 at 6:48 PM
    #671
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Working great. Drove to West Virginia for Thanksgiving in the mountains. Had to use the 4x4 and it did awesome. I've put 14k miles on the truck since I fixed it this summer with only issue being the junk-yard alternator went out on me while driving from st.pete to Pensacola. Slept in the parking lot overnight at orielies and replaced the alternator in the morning and was back on the road
  12. Dec 24, 2023 at 6:09 AM
    #672
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Spent the night with a Waterfront
  13. Dec 24, 2023 at 6:59 AM
    #673
    Wait …. Is the cab swap done? Did I miss something in the last couple pages? Need to go flip back thru.
  14. Dec 24, 2023 at 7:29 AM
    #674
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    No cab swap yet shifty
    I'm working on this fuel filter but the lines are rusted and seized. I wonder if the v8's share the same lines
    UPDATE: Yes the V8 and V6 have identical fuel lines from the tank up to the fuel pressure regulator
    w666 likes this.
  15. Dec 24, 2023 at 7:33 AM
    #675
    Good question, I’m not sure on that one. And yeah, that’s pretty f’n gnarly. Maybe has already been replaced once too? I’d be curious to see the paper filter inside to see how gnarly that is, after this recent aftermarket one we saw sliced open.
  16. Dec 24, 2023 at 9:11 AM
    #676
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I'm sure this filter is going to be basically clogged seeings how I am having fuel problems under heavy load
  17. Dec 24, 2023 at 9:16 AM
    #677
    If it were me, I’d slather some naval jelly all over that rust and let it hang out for 20-30 minutes before rinsing away. If no improvement, I’d hit it up two 2x more.
    I’d also consider cutting or busting the nuts on the filter itself. Once you get the filter off it’ll be easier to deal with the rust on the line itself.
    EDIT: But be ready to wear a face full of gasoline.
  18. Dec 24, 2023 at 9:18 AM
    #678
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I'm going to replace the lines around the filter with something. Not sure exactly what yet but thinking partial rubber
  19. Jan 5, 2024 at 10:50 AM
    #679
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Wanted to show how I installed the topper.
    I had to remove the plastic bed cap to get the topper on metal. The holes I covered with a sealing tape. I used self tapping screws with washers to screw the front and back of the rails down directly to the bed then used the two supplied clamps for the middle. I also used a camouflage net for a bug netting which I like.
    Silet and shifty` like this.
  20. Feb 11, 2024 at 7:43 AM
    #680
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    282,497 miles still making money
    G_unit3000, KNABORES, bmf4069 and 5 others like this.
  21. Mar 17, 2024 at 2:42 PM
    #681
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    A squirrel chewed a pin hole in a plastic fuel line causing a leak just above the gas tank.
    This opened a can of worms because I've been fighting the clogged fuel filter and the rusty lines
    Decided it was time to scope the junkyard...
    Row83 encountered a 2001 V6 totally rust free, with a perfect bed on it! (that still thinking about getting.)
    Didn't have much time so climbed right under and removed all the fuel lines except one of the main hi-pressure lines which someahole cut the end off with pliers and ruined what I needed. I got everything except that one last hi-pressure line...
    Here is what we have so far:
  22. Mar 18, 2024 at 12:40 PM
    #682
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    A 2000 v84x4 but rusty
    Got the last piece of the fuel line from this blue v6 manual 2wd
    The Black Mamba likes this.
  23. Mar 18, 2024 at 12:47 PM
    #683
    Damn, @bmf4069 needed that driver's side door handle, and someone done took it!
  24. Mar 19, 2024 at 7:15 AM
    #684
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I told you! I'm not replacing that door handle! It adds to the patina.
    Bmktw2[OP] and shifty`[QUOTED] like this.
  25. Mar 19, 2024 at 7:38 AM
    #685
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    I am seriously needing a driver's side grab handle, but Houston don't have any.... Florida is kinda far.... damn it damn it
  26. Mar 19, 2024 at 8:30 AM
    #686
    @Bmktw2 has a freaking goldmine nearby. We rarely have any trucks hit my local yards. I have an alert setup with the major area chain for Seqs and Tuns. Rarely ever get emails, less than half dozen per year.
  27. Mar 19, 2024 at 8:33 AM
    #687
    Ghost Rider
    Ian
    Cypress, Texas
    Goldmine is understating that fact, tbh.....
    @Bmktw2 can you, if you have time and happens to visit a yard, look for a grey 2021 or 2nd-2.5G Tundra driver's side handle (both handle and trim piece, hardware<bolts> optional) and let me know how much?
    It might be cheaper to have you get it and I pay shipping to get it here..... and quicker....lol
  28. Mar 19, 2024 at 5:03 PM
    #688
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Saw this guy there. Not sure if the door is still on it or not...
  29. Mar 19, 2024 at 5:09 PM
    #689
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Taking apart the old line is literally impossible. It's all rusted together. Here's how it came off
    My fingernail picked a piece of rust off and it opened this hole. It was just moments away from failing on its own...
    Little by little removing it all the lines are frozen up. The could not even get the fuel filter bracket bolts were gone so had to just rip the rusty bracket off with pliers.
    All on the nice new chassis :rolleyes:
    G_unit3000 likes this.
  30. Mar 19, 2024 at 5:45 PM
    #690
    Toyota saving some pennies to lend to headache.
