New To Forum
Discussion in 'New Member Introductions' started by SW72, May 22, 2017.
  1. May 22, 2017 at 9:47 AM
    SW72
    SW72 [OP] New Member
    Shane
    Kansas City
    2013 Tundra RW
    Biltsein 5100 shocks, BFG 315/70/17, tinted windows, TRex billet grille insert, more to come.
    I think I just fell down a worm hole, and my wallet will never be the same. I have a 2013 Tundra Rock Warrior. All stock at this point. However, I will be getting the Bilstein 5100 Ride Height Adjustable shocks, and new BFG K02s as soon the shop (4Wheel Parts) can fit me in. Looking at other mods too.
    I can tell you all the subjective qualities of this makes my head spin a bit. I knew better than to jump in with "will it fit question", I have read, and lurked for a week or so now, and I have an idea what may be possible...but still not sure. I am still not sure that 315/70/17 will "fit" with the Bilstein set up? The thought of some midieval guys with a pair of pliers and blow torch on my truck does worry me a bit.
    I see that very little is black and white...lol
    I am considering:
    Borla Cat-Back System with rear exit
    Cold Air Intake
    Tuner
    New Grill
    And who knows what else I can't afford. But reading thru here, I may actually be more confused than when I started. Half the people seem to think these things don't "work", the other half swear by them. What is a new guy to do?
    Shane
  2. May 22, 2017 at 9:48 AM
    Welcome! What offset wheels do you have?
  3. May 22, 2017 at 9:49 AM
    SW72
    Shane
    Kansas City
    2013 Tundra RW
    The stock RW wheels, 50 is what I think they are?
  4. May 22, 2017 at 9:54 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Welcome from TN!
    Yeah you're gonna need spacers with a 50 offset
    zcarpenter92 likes this.
  5. May 22, 2017 at 9:55 AM
    Bienvenidos de Tejas! Without any pics...:worthless:
  6. May 22, 2017 at 10:00 AM
    SW72
    Shane
    Kansas City
    2013 Tundra RW
    I will get some up, figured I would snap the before/after when it goes in. It is just the basic white RW. Hoping to work on that though. Honestly, even though I have read lots, I still don't even know what some of these terms mean. I think I understand the concept of spacers and offset. But I am not absolutely sure how it is measured, and what it really means. I assume the spacer makes the wheel project further from the body of the truck? oh....so much to learn. Be gentile, even though I know it is going to hurt.
  7. May 22, 2017 at 10:04 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    1.25" spacers will push your wheels out to roughly 18 mm offset.
    The more offset, the more it tucks in the wheel well and the less offset the further it will stick out. 25 offset tucks in more than 0 offset and -20 will stick out less than -30. Make sense?
  8. May 22, 2017 at 10:10 AM
    SW72
    Shane
    Kansas City
    2013 Tundra RW
    So...the bigger the + offset, the closer (more tucked), the smaller the offset (moving into negative numbers) the further it sticks out?
    zcarpenter92 and Law323 like this.
  9. May 22, 2017 at 10:15 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO.
    @aramirez73 , BOOM, another white truck. That's how we do it :duel:
    Law323 and TXRailRoadBandit73 like this.
  10. May 22, 2017 at 10:18 AM
    Bet... another MGM joins by end of this coming weekend o_O
    Law323 likes this.
  11. May 22, 2017 at 10:23 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    welcome bud. If you stick with a 295 or 285, you can probably fit without spacers.
    Law323 likes this.
  12. May 22, 2017 at 10:30 AM
    SW72
    Shane
    Kansas City
    2013 Tundra RW
    I came stock with the 285/70/17 Size. The trusty interwebz tells me the 315/70/17 is about 1" taller, and about 1"+ wider. My little pea brains tells me that 1/2" in both directions is "no big deal". However, my little pea brain is often wrong. I am a bit conflicted with trying to get bigger tires, and leveling the truck without going too much rubber on a 17" wheel, and then not wanting to pony up an additional $800 for new rims when the RW wheels are acceptable visually. However, 17" wheels feel a bit small.
    Oh where will the spending end? going further and further down the hole.
    Law323 likes this.
  13. May 22, 2017 at 10:31 AM
    TXMiamiFan
    Jose
    Doesn't end. But if you do get off this forum, the less ideas you will get :rofl:
    Darth Tundra, MotoTundra and Law323 like this.
  14. May 22, 2017 at 10:32 AM
    SW72
    Shane
    Kansas City
    2013 Tundra RW
  15. May 22, 2017 at 10:33 AM
    SW72
    Shane
    Kansas City
    2013 Tundra RW
    That actually feels like an unmistakable fact!
    MotoTundra, Law323 and TXMiamiFan like this.
  16. May 22, 2017 at 10:57 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    bingo. it's that simple (also, offset is always measured in mm in respect to rim width) such as a 9 inch wide wheel will not have the same position as a 10 inch wheel of the same offset.
  17. May 22, 2017 at 11:06 AM
    millerstone
    millerstone New Member
    2017 TRD Pro DC Cement
    Welcome from UT!
  18. May 22, 2017 at 11:24 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Welcome and good luck with your upcoming mods!
  19. May 22, 2017 at 12:42 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Shane, welcome to the website/wormhole/forum from Las Vegas!!! :transformer:
  20. May 22, 2017 at 12:56 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Welcome Shane...from Oregon.....No one on the Forum will think ANY of your questions are DUMB !!!...Quit the contrary !!!...If anything you are SMART for doing your research and asking people who have been there, done that !!!...
  21. May 22, 2017 at 12:57 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Spelling error above...meant to say " Quite the contrary "....not Quit....FAT FINGERS !! :goingcrazy: :goingcrazy: :goingcrazy: :goingcrazy:
  22. May 22, 2017 at 7:28 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Hey Shane welcome from San Diego, CA. Stick with the RW wheels. A very strong and good looking 17" wheel. Lots of tire options too.
  23. May 22, 2017 at 8:21 PM
    SlickRick2013Tundra
    SlickRick2013Tundra #10
    Rick
    Mandeville, LA
    13 TRD CM MGM 4x4
    Toytech Boss 3in Lift kit Iron Cross side step TRD Sway Bar TRD Cold Air Intake Blacked out Badges Blacked out front and rear bumpers
    Welcome from springfield,mo I'll so be running rw
  24. May 22, 2017 at 9:23 PM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    Welcome!
  25. May 22, 2017 at 9:48 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Welcome
  26. May 22, 2017 at 10:55 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome Shane. Your RW wheels are fairly highly sought after. The 17" wheel should make your tires a little less expensive and, the extra side wall helps protect the wheels when you're off road. The modifications to make bigger tires fit aren't that bad. The most difficult in the bmc or cmc, body mount or cab mount chop..... Two names for the same thing. The plates are available from one of the vendors here for about $25. The cutting and welding are minor and won't hurt you truck as long as the welding is done slowly enough to not melt the nearby rubber mount and you paint it before it rusts. BTW, as far as CAI.... you've already got one. I haven't found any info that makes me wanna spend $400 to replace the air intake I've already got. But, that's just my opinion. Best of luck, can't wait to see some pics.
