new to forum- battery dead 2018 Tundra after 1.5 years
Discussion in '2.5 Gen Tundras (2014-2021)' started by oldskool, Sep 30, 2019.
  1. Sep 30, 2019 at 7:42 AM
    oldskool
    oldskool [OP] New Member
    2018 - 1794 Tundra
    Thought this might be of help to others: Back to dealer in 4 days with truck screen going blank, speedometer goes to zero, when simple braking. First time they told me it was a rheostat that needed to be adjusted. Thought they quit using those in the 70s??? After rechecking today, told me first thing is battery is toast. Having to replace that, of course not covered under warranty. Tech belief is that when braking, alternator reduces output and battery failure did not allow all to be powered properly. Will post additional info if available as far as fix.
  2. Sep 30, 2019 at 8:01 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I had a similar issue with my Tacoma when the alternator wasn’t charging and the battery was losing voltage.
    I remember watching my temp gauge slowly creep down and the lights go dim as I was doing 70 on the freeway. Thankfully the battery survived and worked fine after I replaced the alternator.
  3. Sep 30, 2019 at 8:05 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
  4. Sep 30, 2019 at 8:09 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Yep, factory batteries are shit. Get a Northstar
  5. Sep 30, 2019 at 8:09 AM
    KTM Hauler
    KTM Hauler New Member
    Rich
    Santa Clarita
    2017 SR5 Tundra 4x4
    Method 306 18"x9" Nitto Ridge Grapplers 275/65r18 Leveling kit
    Mine died at 2 years. I only had 32K on the clock and the dealer covered it...is your truck out of warranty?
  6. Sep 30, 2019 at 9:15 AM
    Dano8855
    Dano8855 New Member
    2018 Tundra Limited
    I would think it would be covered under warranty if the truck is a 2018?
  7. Sep 30, 2019 at 9:27 AM
    OV-1794
    OV-1794 New Member
    Should be covered. My wife's Sequoia had a bad battery and was replaced.
  8. Sep 30, 2019 at 9:32 AM
    Your battery should be covered under warranty.
    Welcome from NY.
  9. Sep 30, 2019 at 9:38 AM
    KTM Hauler
    Rich
    Santa Clarita
    2017 SR5 Tundra 4x4
    That's what I was thinking too...they give you the same piece of crap battery but at least it's free.
